ATE-30S
ATE-30S
    AUTONICS(奥托尼克斯)
    RELAY TIME DELAY 30SEC 3A 250V
ATE-30S 数据手册
ATE Series DIN W48×H48mm Solid state ON Delay timer Features ● DIN W48×H48mm ● Easy and simple time setting ● Cost-effective ● Easy time setting ● Wide range of time ● Power supply • ATE : 110/220VAC 50/60㎐ • ATE1, ATE2 : 110VAC, 220VAC 50/60Hz, 12VDC, 24VDC(option) Please read “Caution for your safety” in operation manual before using. Ordering information ATE 10 S Time unit Time range Output Item S sec.(1, 3, 6, 10, 30, 60) M min.(3, 6, 10, 30, 60) H hour(3, 6, 12, 24) Number Max. time range No mark Time-limit SPDT(1c), Instantaneous SPST(1a) 1 Time-limit DPDT(2c) 2 Time-limit SPDT(1c), Instantaneous SPDT(1c) ATE ON Delay timer Specifications Function Control time setting range Power supply Allowable voltage range Power consumption Reset time Timing operation Control output Contact type Contact capacity Mechanical Electrical Repeat error SET error Voltage error Temperature error Insulation resistance Dielectric strength Noise strength Relay life cycle Vibration Shock Environ -ment S ATE2 S S ATE1 M M M H H H Power ON Delay sec.(1, 3, 6, 10, 30, 60), min.(3, 6, 10, 30, 60), hour(3, 6, 12 ,24) 110/220VAC 50/60Hz 110VAC, 220VAC 50/60Hz, 12VDC, 24VDC(option) 90 to 110% of rated voltage Approx. 10VA(240VAC 60Hz), Approx. 2W(24VDC, 12VDC) Max. 200ms Power ON start type Time limit SPDT(1c), Time limit SPDT(1c), Time limit DPDT(2c) Instantaneous SPST(1a) Instantaneous SPDT(1c) 250VAC 3A resistive load ATE - Model Mechanical Malfunction Mechanical Malfunction Ambient temperature Ambient humidity Unit weight Min.10,000,000 operations Min. 100,000 operations(250VAC 3A resistive load) Max. ±0.3% Max. ±5% ±0.05sec. Max. ±0.5% Max. ±2% 100MΩ(at 500VDC megger) 2000VAC 50/60Hz for 1 minute ±2kV the square wave noise(pulse width : 1㎲) by the noise simulator 0.75mm amplitude at frequency of 10 to 55Hz(for 1 min.) in each of X, Y, Z directions for 1 hours 0.5mm amplitude at frequency of 10 to`55Hz(for 1 min.) in each of X, Y, Z directions for 10 minutes 300m/s² (approx. 30G) in each of X, Y, Z directions for 3 times 100m/s² (approx. 10G) in each of X, Y, Z directions for 3 times -10 to 55℃, storage: -25 to 65℃ 35 to 80%RH Approx. 75g ※Environment resistance is rated at no freezing or condensation. K-72 Single Time Range Timer Parts description Time setting range OUT indicator Power ON indicator Time unit (sec, min, hour) Max. setting time Setting range 1sec 0 to 1sec 3sec 0 to 3sec 6sec 0 to 6sec 10sec 0 to 10sec 30sec 0 to 30sec 60sec 0 to 60sec 3min 0 to 3min 6min 0 to 6min 10min 0 to 10min 30min 0 to 30min 60min 0 to 60min 3hour 0 to 3hour 6hour 0 to 6hour 12hour 0 to 12hour 24hour 0 to 24hour (B) Fiber optic sensor (C) Door/Area sensor (D) Proximity sensor (E) Pressure sensor (F) Rotary encoder (G) Connector/ Socket (H) Temp. controller (I) SSR/ Power controller (J) Counter Output operation mode Model (A) Photo electric sensor t : Setting time, Rt : Reset time (K) Timer Time chart t Rt t (L) Panel meter Power 2-7 ATE (M) Tacho/ Speed/ Pulse meter Instantaneous N.O. 1-3 Time limit N.C. 8-5 (N) Display unit Time limit N.O. 8-6 UP LED t Rt (O) Sensor controller t (P) Switching mode power supply Power 2-7 ATE1 Time limit N.C. 1-4 (8-5) Time limit N.O. 1-3 (8-6) (Q) Stepper motor& Driver&Controller (R) Graphic/ Logic panel UP LED t Rt (S) Field network device t Power 2-7 (T) Software Instantaneous N.C. 1-4 ATE2 Instantaneous N.O. 1-3 (U) Other Time limit N.C. 8-5 Time limit N.O. 8-6 UP LED K-73 ATE Series Connections ● ATE Series ● ATE1 Series 4 5 3 6 2 (Instantaneous 1a) 4 7 1 CONTACT: 250VAC 3A RESISTIVE LOAD CONTACT: 250VAC 3A RESISTIVE LOAD 8 (Time limit 1c) 110VAC 50/60㎐ 5 3 6 2 7 (Time limit 1c) 1 8 - + CONTACT: 250VAC 3A RESISTIVE LOAD (Time limit 1c) ●ATE2 Series 4 220VAC 50/60㎐ SOURCE (Instantaneous 1c) 5 3 6 2 7 1 - 8 CONTACT: 250VAC 3A RESISTIVE LOAD SOURCE (Time limit 1c) + SOURCE Dimensions 14 ● Bracket (sold separately) 80 65 (unit: mm) ● Panel cut-out Min. 55 45 +0.6 0 Min. 65 45 +0.6 0 61 44.8 48 86 41 (Model: PGB48-W) 8-pin socket : PG-08(sold separately) ※Refer to the G-15 page. Panel Proper usage Environment Please avoid the following places: A place where this product may be damaged by strong impact or vibration. A place where corrosive gas or flammable gas and water, oil, dust exist. A place where magnetic and electrical noise occur. A place where high temperature and humidity are beyond rated specification. A place where there are strong alkalis and acids. A place where there are direct rays of sun. K-74 Noise We test 2kV, Pulse width 1㎲ against Impulse voltage between power terminals and 1kV, Pulse width 1㎲ at noise simulator against external noise voltage. Please install MP condenser(0.1 to 1㎌) or oil condenser between power terminals when over impulse noise voltage occurs. When testing dielectric voltage and insulation resistance of the control panel with this unit installed. Please isolate this unit from the circuit of control panel. Please make all terminals of this unit short-circuited. (It prevents the damage of inner circuit.)
ATE-30S 价格&库存
很抱歉,暂时无法提供与“ATE-30S”相匹配的价格&库存,您可以联系我们找货
