FS4E-1P4
FS4E-1P4
    AUTONICS(奥托尼克斯)
    RELAY TIME DELAY 5SEC 3A 250V
FS4E-1P4 数据手册
FSE Series DIN W48×H48mm 8 Pin Plug Timer Features SENSORS ● Wide range of the time selection (0.01 sec to 9999.9 hour) ● Selectable voltage input (PNP) method or no-voltage input (NPN) method ● Dot for Decimal Point / Hour. Min. Sec. by RESET key ● Wide range of power supply : 100-240VAC 50/60Hz, 24VAC 50/60Hz, 24-48VDC universal ● Memory protection for 10 years (using non-volatile semiconductor) ● Built-in Microprocessor CONTROLLERS MOTION DEVICES SOFTWARE Please read “Safety Considerations” in the instruction manual before using. Ordering Information FS 4 E 1P 4 Power supply Output Timer Display digit Item 2 4 24VAC 50/60Hz, 24-48VDC 100-240VAC 50/60Hz 1P I 1-stage setting Indicator E Timer 4 5 9999 (4-digit) 99999 (5-digit) FS 8-pin plug timer (J) Temperature Controllers (K) SSRs (L) Power Controllers ※8-pin socket (PG-08, PS-08(N)) is sold separately. (M) Counters Specifications FS4E-1P4 1-stage setting FS4E-1P2 FS5E-I4 Indicator Display digit 4-digit 5-digit Character size (W×H) 3.8×7.6mm 4×8mm Power supply 24VACᜠ 50/60Hz, 24-48VDCᜡ 100-240VACᜠ 50/60Hz Permissible voltage range 90 to 110% of rated voltage Max. 3.5VA (24VACᜠ 50/60Hz), Max. 4.6VA Max. 3.8VA Power consumption Max. 2.3W (24-48VDCᜡ) (100-240VACᜠ 50/60Hz) (100-240VACᜠ 50/60Hz) Return time Max. 500ms Time operation Power ON Start Min. signal width RESET, INHIBIT: approx. 20ms Selectable voltage input (PNP) method or no-voltage input (NPN) method [Voltage input (PNP) method] input impedance: max. 10.8kΩ, [H]: 5-30VDCᜡ, [L]: 0-2VDC Input method [No-voltage input (NPN) method] short-circuit impedance: max. 470Ω, short-circuit residual voltage: max. 1VDC, open-circuit impedance: min. 100kΩ One-shot output time 0.05 to 5 sec Type Time-limit SPDT (1c) Control Contact output Capacity 250VACᜠ 3A, 30VDCᜡ 3A resistive load Mechanical Min. 5,000,000 operations Relay life cycle Electrical Min. 100,000 operations (250VAC 3A resistive load) Memory retention Approx. 10 years (non-volatile memory) Repeat error Set error Max. ±0.01% ±0.05 sec Voltage error Temp. error Insulation resistance Over 100MΩ (at 500VDC megger) Dielectric strength 2,000VAC 50/60Hz for 1 min (between all terminals and case) AC voltage ±2kV the square wave noise (pulse width 1㎲) by noise simulator Noise immunity AC/DC voltage ±500V the square wave noise (pulse width 1㎲) by noise simulator Mechanical 0.75mm amplitude at frequency 10 to 55Hz (for 1 min) in each X, Y, Z direction for 1 hour Vibration Malfunction 0.5mm amplitude at frequency 10 to 55Hz (for 1 min) in each X, Y, Z direction for 10 min Mechanical 300m/s2 (approx. 30G) in each X, Y, Z direction for 3 times Shock Malfunction 100m/s2 (approx. 10G) in each X, Y, Z direction for 3 times -10 to 55℃, storage: -25 to 65℃ Environ- Ambient temp. ment Ambient humi. 35 to 85%RH, storage: 35 to 85%RH Protection structure IP20 (front part, IEC standard) Approval ※1 Weight Approx. 130g (approx. 90g) Approx. 120g (approx. 80g) ※1: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. Model N-39 (N) Timers (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices FSE Series Connections FS4E-1P4 PNP FS4E-1P2 5-30VDC (external power) PNP INHIBIT PNP INHIBIT RESET RESET NPN FS5E-I4 5-30VDC (external power) 0VDC CONTACT: 250VAC 3A, 30VDC 3A RESISTIVE LOAD SOURCE: 100-240VAC 50/60Hz 4.6VA NPN 5-30VDC (external power) INHIBIT RESET 0VDC CONTACT: 250VAC 3A, 30VDC 3A RESISTIVE LOAD SOURCE: 24VAC 50/60Hz 3.5VA 24-48VDC 2.3W NPN 0VDC SOURCE: 100-240VAC 50/60Hz 3.8VA Input Connections Voltage input (PNP) ● Solid-state input (standard sensor: PNP output type sensor) Sensor Brown + Black - ※ Blue Timer Sensor Brown + Black - ※ Inner circuit 10.8kΩ 0V Blue ● Contact input Timer Timer ※ Inner circuit 10.8kΩ 0V + Inner circuit 10.8kΩ - 0V (PNP open collector output) (PNP output) ※INHIBIT, RESET input part No-voltage input (NPN) ● Solid-state input (standard sensor: NPN output type sensor) Sensor Timer Brown + Black ※ +12V 5.4kΩ Inner circuit Blue (NPN output) ※INHIBIT, RESET input part N-40 0V Sensor Timer Brown + Black ※ ● Contact input Timer +12V +12V 5.4kΩ Inner circuit Blue (NPN open collector output) 0V ※ 5.4kΩ Inner circuit 0V 8 Pin Plug Timer Dimensions 12.3 63.8 14 (unit: mm) SENSORS 10.5 48 45 CONTROLLERS MOTION DEVICES SOFTWARE Bracket Panel cut-out 45+0.6 0 30.5 Min. 65 36 (K) SSRs Min. 65 44.9 (J) Temperature Controllers 56 55 48.6 45 (L) Power Controllers (M) Counters (N) Timers (O) Digital Panel Meters DIP Switch Setting (P) Indicators Output operation mode Memory backup ON Up/Down mode 1 2 3 4 5 6 1 2 3 ※1 3 2 1 6 ON Factory default SW2 SW1 1 Function ON OFF ON OFF 5 (S) Sensor Controllers SW1 (T) Switching Mode Power Supplies ※1: Indicator model (FS5E-I4) does not have no. 1, 2, 3 of SW2 for output operation mode setting. NPN (no-voltage input) (U) Recorders PNP (voltage input) (V) HMIs Up/Down mode SW1 (R) Digital Display Units 5 4 3 2 1 OFF Input logic (INHIBIT, RESET input) (Q) Converters Time range Input logic (NPN/PNP) Memory backup SW1 Function ON OFF Down mode ON OFF Up mode ON 6 ※How to change settings Power OFF → change settings → power ON → press RESET (W) Panel PC Function OFF ON OFF No memory backup (X) Field Network Devices Memory backup key or input signal (min. 20ms) N-41 FSE Series Time Range SW1 ON OFF ON 4 3 2 4 3 2 OFF ON OFF ON 4 3 2 4 3 2 OFF SW1 4-digit 5-digit 99.99 sec 9999.9 sec ON OFF 999.9 sec 99999 sec ON OFF 9999 sec 9 min 59.99 sec ON OFF 99 min 59 sec 99 min 59.9 sec ON 4 3 2 4 3 2 4 3 2 4 3 2 OFF 4-digit 5-digit 999.9 min 9999.9 min 99 hour 59 min 9 hour 59 min 59 sec 999.9 hour 999 hour 59 min 9999 hour 9999.9 hour Dot for Hour, Min, Second RESET 3 sec Setting mode ※In run mode, hold the RESET key for over 3 sec, and it enters setting mode[DP]. ※In setting mode, hold the RESET key for over 3 sec, and it saves the setting and returns to RUN mode. ※If there is no RESET key input for 60 sec when entering setting mode, it returns to RUN mode. RUN mode RESET 3 sec DP RESET CLR RESET Hour, Min, Sec are not divided with dot. E.g.) 5959: 59 min 59 sec SET Hour, Min, Sec are divided with dot. E.g.) )5(59: 59 min 59 sec Time Operation for Indicator (FS5E-I4) ● Up mode ● Down mode RESET RESET INHIBIT INHIBIT +Max. time range +Max. time range 0 0 -Max. time range ※- display is only for F, K, Q, S output operation mode and it cannot be set. Error Display and Output Operation Error Display ERR0 Error description Setting value is 0. Troubleshooting Change the setting value anything but 0. ※When error occurs, the output turns OFF. ※Indicator model does not have error display function. N-42 8 Pin Plug Timer Output Operation Mode One-shot output (0.05 to 5 sec) Output mode (SW2) F ON 3 2 1 OFF N ON OFF 3 2 1 C ON OFF 3 2 1 R ON OFF 3 2 1 K ON 3 2 1 OFF P ON OFF 3 2 1 Q ON OFF 3 2 1 S ON OFF 3 2 1 ON OFF 5 SENSORS Self-holding output Up mode ON OFF RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output RESET RESET Setting Setting 0 0 Output Output 5 Down mode Operation CONTROLLERS After time-up, the display value increases or decreases until reset signal input is applied and self-holding output is maintained. MOTION DEVICES SOFTWARE After time-up, the display value and self-holding output are maintained until reset signal input is applied. When time-up, the display value is reset and it operates simultaneously. After time-up, the display value is reset after one-shot output time and it operates simultaneously. (J) Temperature Controllers (K) SSRs (L) Power Controllers (M) Counters (N) Timers After time-up, the display value increases or decreases until reset signal input is applied. (O) Digital Panel Meters (P) Indicators After time-up, the display value is maintained while output is ON. The value is internally reset and it operates simultaneously. (Q) Converters (R) Digital Display Units After time-up, the display value increases or decreases during oneshot output time. (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders Output turns OFF→ON→OFF operates repeatedly (flicker). (V) HMIs ※Set one-shot output time by front TIME volume switch. (W) Panel PC (X) Field Network Devices N-43 FSE Series Proper Usage ● Follow instructions in ‘Proper Usage’. Otherwise, it may cause unexpected accidents. ● 24-48VDC, 24VAC power supply should be insulated and limited voltage/current or Class 2, SELV power supply device. ● Use the product, 0.1 sec after supplying power. ● When supplying or turning off the power, use a switch or etc. to avoid chattering. ● Install a power switch or circuit breaker in the easily accessible place for supplying or disconnecting the power. ● Keep away from high voltage lines or power lines to prevent inductive noise. In case installing power line and input signal line closely, use line filter or varistor at power line and shielded wire at input signal line. Do not use near the equipment which generates strong magnetic force or high frequency noise. ● Change setting time(T1), time range or etc. after turning off the power of the timer. ● This product may be used in the following environments. ①Indoors (in the environment condition rated in ‘Specifications’) ②Altitude max. 2,000m ③Pollution degree 2 ④Installation category II N-44
FS4E-1P4 价格&库存
很抱歉,暂时无法提供与“FS4E-1P4”相匹配的价格&库存,您可以联系我们找货
