K706-1PLDT-24VDC
K706-1PLDT-24VDC
    INDUSTRIALEMART
    RELAY GEN PURPOSE SPDT 10A 24V
K706-1PLDT-24VDC 数据手册
Different colored test button for AC or DC Switch type On/Off structure for easy test LED indicator to show operation Socket with safety cover available K706 Series Slim & Compact Relays Specifications Ordering Information K706 - 1PL   Contact Arrangement D T 12VDC k l m Contact Material 1PL 1C 2PL 2C  no mark None Option D Diode (Only DC) l no mark None T Test Button Type (AC : Red, DC : Blue) 12VDC 12VDC 24VDC 24VDC 24VAC 24VAC Contact Ratings Function m Coil Voltage 110VAC 110VAC 230VAC 230VAC Max. Rated Current (Resistance Load) Contact Max. Switching Current 1C Ag alloy (24K Gold Plt.) 10A / 250VAC (1P 1C) 5A / 250VAC (2P 2C) 10A (1P 1C) 5A (2P 2C) Max. Switching Capacity 3,000VA (1P 1C) Min.Switching Current* 2C 2,000VA (2P 2C) 100mA 5VDC Initial Contact Resistance 100mΩ (1A 6VDC) Coil Voltage Coil Consumption Coil Spec. Reference Data Min. Pick-up Voltage Max. Dropout Voltage Life cycle curve Number of operation Operating Time Release Time Insulation Resistance 12VDC, 24VDC, 24VAC, 100/110VAC, 220/240VAC DC(W) : 0.53 / AC(VA) : 1.0 DC : 75% of Nominal Voltage AC : 80% of Nominal Voltage DC : 10% of Nominal Voltage DC AC : 30% of Nominal Voltage AC 20ms 10ms / Standard, 20ms / Diode 1,000MΩ at 500VDC Between Contact Points 1,000Vrms 1min. Dielectric Strength General Info. Life Cycle Vibration Resistant Switching voltage [VDC] DC load breaking capacity Shock Resistant Ambient Temperature Socket Between poles 3,000Vrms 1min. Between Contact Points and Coil 5,000Vrms 1min Mechanical Min. 10,000,000 Electrical Min. 100,000 Malfunction Destruction 10 ~ 55Hz (Durable Amplitude 1.5mm) 10 ~ 55Hz (Durable Amplitude 1.5mm) Malfunction 98 m/s Destruction 980 m/s -40 ~ +55°C (with no Condensing) Ambient Humidity 35% ~ 85% RH Socket part number KPX12/ KPX12-P KPX22/KPX22-P Termial Tightened Torque 0.5N • m (5.10kgf • cm) *The minimum switching current is indicated as a standard value. The actual minimum switching rate is variable factor according to the make and break frequency, environmental condition and anticipated credibility level. Therefore, it is recommended that tests be done to test actual load value before the production process. RFT2CORFT2COLTRFT2COLT LT 13Max 13Max 29Max 29Max 13Max 13Max 13Max 13Max 29Max 29Max 29Max 29Max 1.8 29Max 29Max 13Max 13Max 13Max 1.8 1.8 1.8 29Max 29Max 13Max 13M 1.8 29Max 1.8 1.8 1.8 1.8 1.8 1.8 29Max K706-1PL 7.4 20 20 33.3Max 2 20 21 20 DC voltage (VDC) 20 DC voltage (VDC) 21 DC voltage (VDC) DC voltage (VDC) 20 DC voltage (VDC) 33.3Max DC voltage (VDC) 2 8.9 8.9 8.9 74 . 8.9 5 5 3 4 5 寸 (mm)Without Test Button mm) 5 5 5 5.2 5 5.2 5 5.2 5 5.2 5.2 5.2 5 7.5 7.5 8.9 219.4 2 19.4 19.4 7.5 74 . 0.5 (A)(A)(A)(A)(A)(A) 2 7. 4 2.5 0.5 4 10 10 10 10 10 10 0.1 0.1 0.20.5 0.2 0.5 0.5 2 10 5 2010 5 21 0.20.5 0.20.5 1 2 12 1 5 2 1 25 10 5 5 10 0.1 0.10.1 0.20.1 0.2 1 0.5 12 7.5 5 7.5 3 4 23 7.5 4 2 3 4 17. 7 1 5.2 5.2 5.2 5.2 5.2 5.2 1 9 10 9 10 10 98 10 98 10 987 10 2 5 876 987 5 5 4. 4 4. 7 1 765 876 1 3 4 2 3 543 543 654 654 765 4 23 74 . 0. 5 2 2 3 31 4 4 2 3 4 1 5 2 5 1 1 0 0 0 0 0 0 0 10 4.104 210 21017.2 317 20 20 20 20 202 20 4.4 17.7 2 19.4 17.719.4 2 4.4 17.7 219.4 4.4 74 . 4. 7 74 . 20. 5 17.7 0. 5 4 DC DCDC DCDC DC 50 50 50 50 50 50 40 40 40 40 40 40 DC DCDC 2.5 2.5 0.5 DC DCDC 30 30 30 30 30 30 4 2.5 4.7 0.5 2.5 0.5 0.5 0.5 0.5 4.7 2.5 4.70.5 8.9 4.4 17.74.4 17.7 4 4 4 100100100100100100 2 33.3 28 2 20. 0 4 4 4 4 12. 6 21 29 200200200200200200 250VAC/30VDC 250VAC/30VDC 250VAC/30VDC 250VAC/30VDC 250VAC/30VDC 250VAC/30VDC 250VAC(COSØ=0.4) 10 250VAC(COSØ=0.4) 10 250VAC(COSØ=0.4) 10 250VAC(COSØ=0.4) 10 250VAC(COSØ=0.4) 0 4.7 10 250VAC(COSØ=0.4) 0.5 4.70.5 4.7 0.5 30VDC(L/R=7ms) 30VDC(L/R=7ms) 30VDC(L/R=7ms) 30VDC(L/R=7ms) 30VDC(L/R=7ms) 30VDC(L/R=7ms) 0 2 33.3Max 2 21 4 1. 8 2 33.3Max 33.3Max 2 4 12. 6 Socket Dimensions (unit: mm) 2.75 21 4 21 29 2 33.3Max 2 33.3Max 2 0100100100 1. 8 100100 33.3Max (x105) (x105) 33.3Max 5 (x10 ) 2 33.3Max Relays Dimensions (unit: mm) 33.3Max 2 300300300300300300 1000 1000 1000 1000 0 1000 (A)(A 5 5 5 5. 2 5. 2 5. 2 5. 2 Test Button KPX 12 KPX 12-P 4 20 20 4 20 44 LED + Diode (DC) 33.3Max 2 33.3Max 2 33.3Max 2 44 20 21 RFT2COLT RFT2COLT RFT2COLT DC DC DC 4 20 21 LED (DC) 21 2 33.3Max 33.3Max 2 2 33.3Max 33.3Max 2 2 33.3Max 2 4 4 RFT2COLTD RFT2COLT RFT2COLTD RFT2COLTD DC DC DC RFT2COLTD1 RFT2COLTD1 DC D K706-2PL 20. 5 8.9 8.9 8.9 8.9 74 . 8.9 74 . 74 . 2 28 74 . 2 5 5 5 0. 5 19. 4 8.9 7 .5 RFT1COLT RFT1COLT RFT1COLT AC AC AC 19. 4 2 RFT1COLT RFT1COLT RFT1COLT DC DC DC 2 3 4 7 6 5 8. 9 18 5 5 RFT1COLTD RFT1COLTD RFT1COLTD DC DC DC RFT1COLTD RFT1COLTD1 RFT1COLTD1 DC D 7. 5 20. 0 7.5 5 5 7.5 7.5 7.5 3 7.5 7.5 4 4 3 2 3 2 5 5 4 5 2 3 4 4 3 2 5 4 5 3 2 2 5 5 0. 5 2. 5 2 0.5 4 5 5 5 5.25 5.2 55.25 5.2 5.2 5.2 5.2 5.25.2 5.25.2 5.2 2. 5 2.50.52.50.5 2 19.4 19.4 2 19.4 2 1 1 1 1 1 1 4 2.5 12. 6 2 19.4 17.719.4 4.4 17.7 24.419.4 17.7 2 4.4 2.75 4.4 17.7 17.7 4.4 17.7 29 1. 8 12. 6 29 1. 8 Socket 2.50.50.5 0.5 Dimensions (unit: mm) 2.5 4.7 4.7 0.5 0.50.5 4.7 2.5 8.9 (unit: mm) Relays Dimensions 4.7 0.5 0.5 4.7 0.5 33.3 4.7 74 . 4 21 21 21 RFT2COLT FT2COLT RFT2COLT AC AC AC 4 33.3Max 2 2 33.3Max 33.3Max 4 LED (AC) 20 (with safety cover) RFT2CORFT2COLT LT RFT2COLT 13Max 13Max 13Max 13Max 29Max 13Max 29Max 29Max 29Max 29Max 29Max 1.8 1.8 1.8RFT1COLTD1 1.8RFT1COLT 1.8 13Max13Max 13Max 13Max 13Max 29Max 29Max 29Max RFT1COLT RFT1COLT DC RFT1COLTD RFT1COLT 1.8 1.8 1.8 FT1COLT AC AC AC RFT1COLT RFT1COLT DC1.81.8 DC RFT1COLTD RFT1COLTD DC DC1.8DC29Max RFT1COLTD1 DC 13M D Wiring 29Max diagram 29Max Without Test Button 5 5 Test Button KPX 22 Wiring diagram RFT2COLT RFT2COLT RFT2COLT AC AC AC LED (AC) RFT2COLT RFT2COLT RFT2COLT DC DC DC LED (DC) RFT2COLTD RFT2COLTD RFT2COLTD DC DC DC LED + Diode (DC) KPX 22-P (with safety cover) RFT2COLTD RFT2COLTD1 RFT2COLTD1 DC D
K706-1PLDT-24VDC 价格&库存
很抱歉,暂时无法提供与“K706-1PLDT-24VDC”相匹配的价格&库存,您可以联系我们找货
