LE3SA-24-240
LE3SA-24-240
    AUTONICS(奥托尼克斯)
    RELAY TIME DELAY 9990HR 3A 250V
LE3SA-24-240 数据手册
LE3S Series Digital LCD Timer DIN W48×H48mm Features SENSORS ● Power supply : 24-240VAC 50/60Hz, 24-240VDC universal ● Easy to switch Up/Down mode ● 10 programmable output modes and timing ranges (LE3S) ● Selectable function by front digital switches ● Graphic output contact status display (N.O./N.C.) ● BAR graph display of time progressing in 5% increments ● Compact size (length: 74mm) CONTROLLERS MOTION DEVICES SOFTWARE Please read “Safety Considerations” in the instruction manual before using. (J) Temperature Controllers Ordering Information LE 3 S (K) SSRs Output Size Digit Item Specifications No mark Time-limit SPDT (1c) A Time-limit DPDT (2c) B Time-limit SPDT (1c), Instantaneous SPDT (1c) S DIN W48×H48mm 3 999 (3-digit) LE LCD timer (digital switch type) (L) Power Controllers (M) Counters (N) Timers ※8-pin socket (PG-08, PS-08(N)) is sold separately. Model LE3S LE3SA Function Multi time and operation Multi time range, Power ON Delay operation Display method LCD display (character size: W4×H8mm) Power supply 24-240VACᜠ 50/60Hz, 24-240VDCᜡ universal Allowable voltage range 90 to 110% of rated voltage Power consumption Max. 2.5VA (24-240VACᜠ 50/60Hz), Max. 3.3VA (24-240VACᜠ 50/60Hz), Max. 1W (24-240VDCᜡ) Max. 1.5W (24-240VDCᜡ) Return time Max. 200ms Max. 100ms Approx. 20ms - Min. input signal width INHIBIT (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers RESET INHIBIT RESET Timing operation Control output LE3SB START START Input (O) Digital Panel Meters (T) Switching Mode Power Supplies • No-voltage input Impedance at short-circuit: max. 1kΩ Residual voltage: max. 0.5VDC Impedance at open-circuit: min. 100kΩ (U) Recorders Signal ON Start Power ON Start Contact type Time limit SPDT (1c) Time limit DPDT (2c) Contact capacity 250VACᜠ 5A, 30VDCᜡ 5A resistive load 250VACᜠ 3A, 30VDCᜡ 3A resistive load Mechanical Min. 10,000,000 operations Relay life cycle Electrical Output mode Min. 100,000 operations (250VAC 5A resistive load) Min. 100,000 operations (250VAC 3A resistive load) 10 operation modes Power ON Delay mode fixed Time limit SPDT (1c), Instantaneous SPDT (1c) (V) HMIs (W) Panel PC (X) Field Network Devices -10 to 55℃, storage: -25 to 65℃ Environ- Ambient temp. ment Ambient humidity 35 to 85%RH Accessory Bracket ※Environment resistance is rated at no freezing or condensation. N-15 LE3S Series Specifications Model Repeat error SET error Voltage error Temperature error LE3S LE3SA LE3SB Max. ±0.01% ±0.05 sec (for Power ON Start) Max. ±0.005% ±0.03 sec (for Signal ON Start) Max. ±0.01% ±0.05 sec Insulation resistance Over 100MΩ (at 500VDC megger) Dielectric strength 2,000VAC 50/60Hz for 1 min Noise immunity ±2kV the square wave noise (pulse width: 1㎲) by the noise simulator Vibration Mechanical Mechanical Shock 0.75mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 1 hour Malfunction 0.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 10 min 300m/s² (approx. 30G) in each X, Y, Z direction for 3 times Malfunction 100m/s² (approx. 10G) in each X, Y, Z direction for 3 times Approval Unit weight Approx. 100g Approx. 105g Connections ● LE3S ● LE3SA 4 RESET START INHIBIT 4 5 3 6 2 7 1 8 - + SOURCE CONTACT OUT : 250VAC 5A, 30VDC 5A RESISTIVE LOAD (Time limit 1c) 5 3 6 2 7 1 (Time limit 1c) 8 (Time limit 1c) - + SOURCE 24-240VAC 50/60Hz 24-240VDC CONTACT OUT : 250VAC 3A, 30VDC 3A RESISTIVE LOAD 24-240VAC 50/60Hz 24-240VDC ● LE3SB 4 (Instantaneous contact 1c) 5 3 6 2 7 1 8 - + SOURCE N-16 CONTACT OUT : 250VAC 3A, 30VDC 3A RESISTIVE LOAD (Time limit 1c) 24-240VAC 50/60Hz 24-240VDC Thumbwheel Switch Setting Type LCD Display Timer Input Connections (LE3S Only) Solid-state input Contact input Sensor LE3S 12-24VDC +V LE3S INHIBIT + RESET Q1 MOTION DEVICES S1 GND Sensor +V SOFTWARE 0V 0V ● Q1 is ON: Operating ● Sensor: NPN open collector output RL CONTROLLERS INHIBIT START RESET START OUT - SENSORS ● S1 is ON: Operating ● S1: Micro switch, push button switch, relay ● Input level LE3S 12-24VDC INHIBIT + START OUT - No voltage input RESET ● Short-level (transistor is ON) • Residual voltage: Max. 0.5V • Impedance: Max. 1kΩ (K) SSRs ●Open-level (transistor is OFF) • Impedance: Min. 100kΩ Q2 GND (J) Temperature Controllers 0V Contact input (L) Power Controllers Please use reliable contacts enough to flow 5VDC 1mA of current. (M) Counters ● Q2 is ON: Operating ● Sensor: NPN universal output (N) Timers Dimensions 9.2 48 6 52.4 (O) Digital Panel Meters 14.2 (unit: mm) (P) Indicators 44.8 (Q) Converters (R) Digital Display Units (S) Sensor Controllers Bracket Panel cut-out (T) Switching Mode Power Supplies (U) Recorders 45 +00.6 26.3 Min. 55 15 (V) HMIs Min. 65 48.3 (X) Field Network Devices 60.2 45.8 (W) Panel PC N-17 LE3S Series Unit Description Output OFF Time value ON Time unit : hour : min : sec Output operation mode Bar graph indicator for time processing Setting of preset value Time range selectort 001 to 999 Up/Down Mode Up ※Output operate as Up or Down mode by Up/Down switch location. DN Down UP DN UP Power must be cut off. ● Default specifications LE3S LE3SA, LE3SB Up/Down mode: Up • Up/Down mode: Up • Output mode: A mode (fixed) ※Down mode is option. Output Operation Mode Selection Please select operation mode by press the left of , keys in front panel. Output operation mode A ON Delay Ⓐ B Interval Delay Ⓐ C ON Delay Ⓑ D Flicker Ⓐ E Flicker Ⓑ F One-shot Out Flicker H OFF Delay K ON/OFF Delay L Interval Delay Ⓑ N Integration Time ※Refer to LE3SA, LE3SB Output Operation Mode ● ON Delay Ⓐ of A mode and ON Delay Ⓑ of C mode are different. ● Interval delay Ⓐ of B mode and Interval Delay Ⓑ of L mode are different. ● Flicker Ⓐ of D mode and Flicker Ⓑ of E mode are different. ※Output mode Ⓐ is operated as time progresses only when the START signal applied continuously. ※Output mode Ⓑ is operated as time progresses even the START signal is applied as One-shot signal. (one-shot input signal should be over 20ms.) N-18 Thumbwheel Switch Setting Type LCD Display Timer Time Specifications and Time Range Please select time unit and range by press the right of , keys in front panel. SENSORS BAR graph: Display % for the time progressing against setting time CONTROLLERS Time Range mode 0.01s 0.01 sec to 9.99 sec 0.1s 0.1 sec to 99.9 sec s 1 sec to 999 sec 0.1m 0.1 min to 99.9 min m 1 min to 999 min 0.1h 0.1 hour to 99.9 hour h 1 hour to 999 hour 10h 10 hour to 9990 hour S 0 min 01 sec to 9min 59 sec M 0 hour 01 min to 9 hour 59 min MOTION DEVICES SOFTWARE (J) Temperature Controllers Time setting digital switch ● Setting of operation time: Please select operation time by press the center of 3 ※When using this unit with 20.0 sec of operation time. After selecting as time range, then set digital switches as 20.0 sec In this case, it is convenient to put a decimal point as below figure. , (K) SSRs keys in front panel. (L) Power Controllers (M) Counters (N) Timers Mark a decimal point. (O) Digital Panel Meters ● Bar graph display: Display the progress rate of time for setting time with bar, it is calculated as below for 1bar. Setting value (operation time) ÷ 20 (total number of bars) = The time for 1 bar is lighted. (Q) Converters LE3SA, LE3SB Output Operation Mode t Power LE3SA (P) Indicators t=Setting time, Rt=Reset time (min. 100ms) Rt t (S) Sensor Controllers 2-7 Time-limit contact 1-4 N.C. (8-5) (T) Switching Mode Power Supplies Time-limit contact 1-3 N.O. (8-6) (U) Recorders t Rt t (V) HMIs Power 2-7 Time-limit contact N.C. 8-5 LE3SB (R) Digital Display Units (W) Panel PC Time-limit contact N.O. 8-6 (X) Field Network Devices Instantaneous contact N.C. 1-4 Instantaneous contact N.O. 1-3 N-19 LE3S Series LE3S Output Operation Mode Mode A ON Delay T=Setting time, T >Ta Time chart T T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 Ta T ② ③ ④ ① 1. Time progresses when START signal is ON. 2. The output will be ON when the setting value is equal to the display value. (Position ①) 3. When the RESET signal is ON, the display value is returned to the initial state. (Position ③) ※If START signal is OFF when the output is OFF the display value is returned to initial state (Position ④). T B Interval Delay POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 T Ta ② ① T ③ 1. The output turns ON and time progresses when START signal is ON. 2. The output will be ON when the setting value is equal to the display value. (Position ①) 3. When the RESET signal is ON, the display value is returned to the initial state. (Position ②) ※If START signal is OFF when the output is OFF the display value is returned to initial state. (Position ③) C ON Delay T T Ta T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 T ① Ta ② 1. Time proceeds when START signal is ON. 2. The output will be ON when the setting value is equal to the display value. (Position ①) 3. When the RESET signal is ON, the display value is returned to the initial state. ※When start signal is applied repeatedly (Position ①), only the initial signal is recognized. ※Even if the START signal is not applied, time progresses. (Position ②) D Flicker T T Ta T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 Ta T Ta ① ② 1. Time progresses repeatedly when the START signal is ON. 2. The output operates from N.C. to N.O., and from N.O. to N.C. repeatedly. 3. If RESET signal is ON, it is returned to initial state. (Position ①) ※If the START signal is OFF, the display value and output is returned to initial state. (Position ②) T E Flicker POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 ① T Ta T T T Ta T Ta T Ta ② ③ 1. Time progresses repeatedly when the START signal is ON. 2. The output operates from N.C. to N.O., and from N.O. to N.C. repeatedly. 3. If RESET signal is ON, it is returned to initial state. (Position ③) ※When START signal is applied repeatedly, only the initial signal is recognized. (Position ①) ※Even if the START signal is not applied, time progresses. (Position ②) ※Initial state: Output is OFF, the display value is "0". (UP mode). The output is OFF and the display value is the setting value (DOWN mode) ※When set the time setting as 000, control output does not come out. ※When using D, E output operation modes, if the time is set too short, the output may not work properly. Please set the time at least over 100ms. N-20 Thumbwheel Switch Setting Type LCD Display Timer LE3S Output Operation Mode Mode F One-shot Out Flicker T=Setting time, T=T1+T2+T3, T >Ta, T >Ta+Tb SENSORS Time chart T T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 Ta T T T Ta T Ta T Ta ② CONTROLLERS ① 0.3s ③ 0.3s One-shot output 1. Time progresses from initial value to the preset value repeatedly and the output operates as one-shot (0.3 sec), when the START signal is ON. (Position ①) 2. If the RESET signal is ON, it is returned to initial state. (Position ③) ※When START signal is applied repeatedly, only the initial signal is recognized. (Position ②) H OFF Delay Ta POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 T Ta Ta ON-OFF Delay T (J) Temperature Controllers Ta Ta (K) SSRs Ta T Ta Ta Ta Ta Ta T (L) Power Controllers T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 (M) Counters (N) Timers 1. When the START signal is ON the output is ON the output will be reset and display value is held when setting value is equal to display value. 2. The START signal turns OFF, the output turns ON, the output will be reset and display value is held when setting value is equal to display value. 3. If RESET signal is ON, it is returned to initial state. ※If START signal is applied repeatedly, output keeps ON but be sure that the time will be initialized. L Interval Delay T Ta T POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 T Integration Time (P) Indicators (Q) Converters (R) Digital Display Units T1 POWER START RESET RY OUT SET UP MODE 0 DISPLAY SET DOWN MODE 0 (O) Digital Panel Meters T ① (S) Sensor Controllers 1. When START signal is ON, the output turns ON and the time progresses at the same time. 2. When the time reaches at the preset value the output will be reset, and the display value is held. 3. If RESET signal is applied, the display value is returned to initial state. ※When START signal is applied repeatedly, only the initial signal is recognized. (Position ①) N SOFTWARE ① 1. The START signal & the output are ON at the same time. The output will return and the display value is held after the setting time. 2. If the RESET signal is ON, the display value is returned to initial state. ※If the START signal is applied continuously, the output will be ON but time is not progressed. K MOTION DEVICES T2 T3 Ta Tb Ta (T) Switching Mode Power Supplies Tb (U) Recorders ① (V) HMIs (W) Panel PC 1. When START signal is ON, time progresses. 2. If START signal turns off before the display value reaches the setting value, the time (display value) will be held. 3. If RESET signal is ON, it is returned to initial state. ※Initial state: Output is OFF, the display value is "0". (UP mode). The output is OFF and the display value is the setting value (DOWN mode) ※When set the time setting as 000, control output does not come out. ※When using D, E output operation modes, if the time is set too short, the output may not work properly. Please set the time at least over 100ms. N-21 (X) Field Network Devices LE3S Series Proper Usage ● Follow instructions in 'Proper Usage'. Otherwise, it may cause unexpected accidents. ● When supplying or turning off the power, use a switch or etc. to avoid chattering. ● Install a power switch or circuit breaker in the easily accessible place for supplying or disconnecting the power. ● In order to block peripheral current, use isolation transformer which of secondary part is not grounded as (Figure 1) to supply power to the external input device. (Figure 1) Main circuit < Sensor > START RESET INHIBIT Rectification circuit Isolation transformer Power ● Do not connect two or more timers with only one input contact or transistor simultaneously. ●K  eep away from high voltage lines or power lines to prevent inductive noise. In case installing power line and input signal line closely, use line filter or varistor at power line and shielded wire at input signal line. Do not use near the equipment which generates strong magnetic force or high frequency noise. ● Change setting time, time range, operation mode or etc. after turning off the power of the timer. ●T  his unit may be used in the following environments. ①Indoors (in the environment condition rated in 'Specifications') ②Altitude max. 2,000m ③Pollution degree 2 ④Installation category II N-22
LE3SA-24-240 价格&库存
很抱歉,暂时无法提供与“LE3SA-24-240”相匹配的价格&库存,您可以联系我们找货
