MP5M-4N
MP5M-4N
    AUTONICS(奥托尼克斯)
    PULSE METER INDICATOR 100-240V
MP5M-4N 数据手册
-|Transparent setting guide|- MP5S/MP5Y/MP5W Series High Performance, Digital Pulse Meter ▣ Features  otal 16 types of operation mode T Frequency/Revolutions/Speed, Passing speed, Cycle, Passing time, Time interval, Time differential , Absolute ratio, Error ratio, Density, Error, Length measurement 1, Length measurement 2, Interval, Accumulation, Addition/Subtraction-individual input, Addition/ Subtraction-phase difference input Various output models Relay triple/quintuple output, NPN/PNP open collector quintuple output, BCD dynamic output, PV transmission output (current output), RS485 communication output (Modbus RTU) Various functions Selectable NPN solid state/contact input, PNP solid state/contact input, prescale, delay monitoring, hysteresis, auto-zero time setting, lock setting, data bank function (MP5W series) Max. display range: -19999 to 99999 Various display units rpm, rps, Hz, kHz, sec, min, m, mm, mm/s, m/s, m/min, m/h, ℓ/s, ℓ/min, ℓ/h, %, counts, etc. MP5S MP5Y Please read “Safety Considerations” in the instruction manual before using. MP5W ▣ Ordering Information MP 5 Y - 4 N Output S N Main output (comparative value output) Indicator Y N 1 2 3 4 5 6 Indicator NPN open collector quintuple output PNP open collector quintuple output Indicator Indicator Indicator Relay triple output (H, GO, L) BCD dynamic output PV transmission output (current output) RS485 communication output - N - 1 2 Indicator Relay quintuple output (HH, H, GO, L, LL) Relay triple output (H, GO, L) NPN open collector quintuple output BCD dynamic output 4 NPN open collector quintuple output PV transmission output (current output) 5 8 PNP open collector quintuple output NPN open collector quintuple output PV transmission output (current output) RS485 communication output 9 PNP open collector quintuple output RS485 communication output A W Power supply Size Digits Item O-76 2 24VAC 50/60Hz, 24-48VDC 4 100-240VAC 50/60Hz S Y W DIN W48×H48mm DIN W72×H36mm DIN W96×H48mm 5 99999 (5-digit) MP Pulse meter Sub output (display value output) - - -|Transparent setting guide|- Pulse Meter ▣ Specifications Series Display method Character size Display range AC voltage Power supply AC/DC voltage Power consumption AC voltage AC/DC voltage Permissible voltage range External power supply Sub power supply Input frequency Input method Measurement range Measurement accuracy (23℃±5℃) Display cycle Operation mode Output Prescale function Hysteresis Relay triple Main Relay quintuple NPN/PNP open collector quintuple BCD dynamic Sub PV transmission Communication Memory retention Insulation resistance Dielectric strength Noise immunity Mechanical Vibration Malfunction Mechanical Shock Malfunction Mechanical Relay life cycle Electrical Ambient temp. Environment Ambient humi. Approval ※2 Weight MP5S MP5Y MP5W 7-segment LED (zero blanking method) W4×H8mm W7×H14mm -19999 to 99999 100-240VACᜠ 50/60Hz 24VACᜠ 50/60Hz, 24-48VDCᜡ Max. 7.5VA Max. 9VA Max. 15VA (100-240VACᜠ 50/60Hz) (100-240VACᜠ 50/60Hz) (100-240VACᜠ 50/60Hz) Max. 6VA (24VACᜠ 50/60Hz), Max. 7VA (24VACᜠ 50/60Hz), Max. 11VA (24VACᜠ 50/60Hz), max. 4.5W (24-48VDCᜡ) max. 6.2W (24-48VDCᜡ) max. 7W (24-48VDCᜡ) 90 to 110% of rated voltage Max. 12VDCᜡ ±10% 80mA Max. 24VDCᜡ 30mA ·Solid state input 1: max. 50kHz (pulse width: min. 10㎲) ·Solid state input 2: max. 5kHz (pulse width: min. 100㎲) ※For F7, F8, F9, F10 operation mode, max. 1kHz (pulse width: min. 500㎲) ·Contact input: max. 45Hz (pulse width: min. 11ms) [Voltage input] High: 4.5-24VDCᜡ, Low: 0-1VDC, Input impedance: 3.9kΩ [No-voltage input] Short-circuit impedance: max. 80Ω, Residual voltage: max. 1VDC, Open-circuit impedance: min. 100kΩ : 0.0005Hz to 50kHz ·Operation mode F1, F2, F7, F8, F9, F10 : 0.01 to max. of each time range ·Operation mode F3, F4, F5, F6 : 0 to 99999 ·Operation mode F11, F12, F13, F16 : -19999 to 99999 ·Operation mode F14, F15 : F.S.±0.05%rdg±1-digit ·Operation mode F1, F2, F7, F8, F9, F10 : F.S.±0.01%rdg±1-digit ·Operation mode F3, F4, F5, F6 OFF (for F2, F16 operation mode), 0.05, 0.5, 1, 2, 4, 8 sec (same as update output cycle) Frequency/Revolutions/Speed (F1), Passing speed (F2), Cycle (F3), Passing time (F4), Time interval (F5), Time differential (F6), Absolute ratio (F7), Error ratio (F8), Density (F9), Error (F10), Length measurement 1 (F11), Interval (F12), Accumulation (F13), Addition/Subtraction-individual input (F14), Addition/Subtraction-phase difference input (F15), Length measurement 2 (F16) Direct input method (0.0001×10-9 to 9.9999×109) ※1 0 to 9999 250VACᜠ 3A, 30VDCᜡ 3A resistive load 250VACᜠ 3A, 30VDCᜡ 3A resistive load - Max. 30VDCᜡ 30mA Max. 30VDCᜡ 30mA DC4-20mA/DC0-20mA max. load 500Ω RS485 communication output (Modbus RTU method) Non-volatile memory (number of inputs: 100,000 operations) Over 100MΩ (at 500VDC megger) 2,000VAC 60Hz for 1 min ±2kV the square wave noise (pulse width: 1㎲) by the noise simulator 0.75mm amplitude at frequency of 10 to 55Hz in each X, Y, Z direction for 1 hour 0.5mm amplitude at frequency of 10 to 55Hz in each X, Y, Z direction for 10 min 300m/s² (approx. 30G) in each X, Y, Z direction for 3 times 100m/s² (approx. 30G) in each X, Y, Z direction for 3 times Min. 10,000,000 operations Min. 100,000 operations (250VAC 3A resistive load) -10 to 50℃, storage: -20 to 60℃ 35 to 85%RH, storage: 35 to 85%RH Approx. 191g (approx. 132g) Approx. 230g (approx. 140g) SENSORS CONTROLLERS MOTION DEVICES SOFTWARE (J) Temperature Controllers (K) SSRs (L) Power Controllers (M) Counters (N) Timers (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs Approx. 334g (approx. 210g) (W) Panel PC ※1: Setting range will vary depending on the decimal point. ※2: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. (X) Field Network Devices O-77 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ▣ Connections ※Terminal connections differ by power supply and output type of each series and model. Brown Blue Black Black MP5S Series 8 9 INA INB +12V 0V HOLD/RESET 6 ※1: Operation mode F1 to F12 : display value HOLD Operation mode F13 to F16 : display value RESET ※2: Model Source MP5S-4N 10 11 12 1 24-48VDC 24VAC 50/60Hz 100-240VAC 50/60Hz MP5S-2N 7 ※1 2 3 4 5 - + ※2 SOURCE MP5Y Series Power/Input Terminal (Common) ※MP5Y- N (indicator) only has 'Power/Input terminals'. Black Black 1 2 INA INB ※1: O  peration mode F1 to F12 : display value HOLD Operation mode F13 to F16 : display value RESET ※2: Model Source 24-48VDC MP5Y-2 24VAC 50/60Hz 100-240VAC MP5Y-4 50/60Hz Blue Brown 3 4 5 0V 6 7 +12V ※1 HOLD/RESET - + SOURCE ※2 Output Connector (MP5Y- 1 to 5) ※Hirose connector: HIF3BA-10PA-2.54DS ※Connector socket specification: Contact the manufacture for the socket and cable. Specifications Connector socket HIF3BA-10D-2.54R Manufacture Hirose Electric ● MP5Y- 1 (NPN open collector output) ● MP5Y- 2 (PNP open collector output) MAIN OUT (NPN OPEN COLLECTOR) 30VDC 30mA MAIN OUT (PNP OPEN COLLECTOR) 30VDC 30mA GO HH GO HH LL 2 4 6 8 10 2 4 6 8 10 1 3 5 7 9 1 3 5 7 9 COM O-78 LL H L COM H L -|Transparent setting guide|- Pulse Meter ● MP5Y- 3 (BCD dynamic output) ● MP5Y- 4 (PV transmission output) BCD OUT (NPN OPEN COLLECTOR) 30VDC 30mA A C 2 D0 4 D2 6 D4 2 10 8 SENSORS DC4-20mA/DC0-20mA (+) Load 500Ω Max. 4 6 8 CONTROLLERS 10 MOTION DEVICES 1 COM 3 B 5 D D1 1 9 7 3 5 7 D3 9 SOFTWARE (-) ※Autonics display unit (DS/DA Series) is recommended for stable minus (-) sign display. ●Output Terminal (MP5Y- 6) ● MP5Y- 5 (RS485 communication otuput) ● MP5Y- 6 (Relay triple output) RS485 B(-) 2 4 1 3 6 5 8 10 8 9 7 9 10 11 H 12 13 14 15 GO (K) SSRs L CONTACT OUT: 250VAC 3A, 30VDC 3A RESISTIVE LOAD RS485 A(+) (J) Temperature Controllers (L) Power Controllers (M) Counters MP5W Series ●Power/Input Terminal (Common) (N) Timers ※MP5W- N (indicator) only has 'Power/Input terminals'. (O) Digital Panel Meters (P) Indicators Black Black ※1: Operation mode F1 to F12 : display value HOLD Operation mode F13 to F16 : display value RESET ※2: Model Source 24-48VDC MP5W-2 24VAC 50/60Hz 100-240VAC MP5W-4 50/60Hz 1 INA 2 INB Blue 3 4 5 6 7 0V 0V 8 9 (R) Digital Display Units +12V ※1 HOLD/RESET (S) Sensor Controllers - + ※2 SOURCE BANK ●Output Terminal (MP5W- A/1) (Q) Converters Brown (T) Switching Mode Power Supplies (U) Recorders ● MP5W- A (Relay quintuple output) ● MP5W- 1 (Relay triple output) CONTACT OUT: 250VAC 3A, 30VDC 3A RESISTIVE LOAD (V) HMIs CONTACT OUT: 250VAC 3A, 30VDC 3A RESISTIVE LOAD H 10 11 12 13 14 15 HH H GO L LL COM 10 GO 11 12 L 13 14 (W) Panel PC (X) Field Network Devices 15 O-79 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series Output Connector (MP5W- 2/4/5/8/9) ※Hirose connector: HIF3BA-20PA-2.54DS ※Connector socket specification: Contact the manufacture for the socket and cable. Specifications Connector socket HIF3BA-20D-2.54R I/O cable (sold separately) CO20-HP -L, CO20-HP -R Manufacture Hirose Electric Autonics ● MP5W- 2 (NPN open collector+BCD dynamic output) MAIN OUT (NPN OPEN COLLECTOR) 30VDC 30mA +24VDC ※ 30mA Max. 1 LL HH GO D B 2 4 1 COM 3 H D1 D3 DOT COM2 6 8 10 12 14 16 18 20 5 7 9 11 13 15 17 19 L A 0V ※ C D0 D4 POL 2 D2 BCD OUT (NPN OPEN COLLECTOR) 30VDC 30mA ※1: Sub power supply ※2: POL signal turns ON when the display value is a minus (-) value. ※Autonics display unit (DS/DA Series) is recommended for stable minus (-) sign display. ● MP5W- 5 (PNP open collector+PV transmission output) ● MP5W- 4 (NPN open collector+PV transmission output) MAIN OUT (PNP OPEN COLLECTOR) 30VDC 30mA MAIN OUT (NPN OPEN COLLECTOR) 30VDC 30mA +24VDC ※ 30mA Max. 1 HH GO LL (+) HH LL 2 4 6 8 10 12 14 16 18 20 2 4 6 1 3 5 7 9 11 13 15 17 19 1 3 5 COM H L 0V COM H (-) DC4-20mA/DC0-20mA (Load 500Ω Max.) ● MP5W- 8 (NPN open collector+RS485 comm. output) RS485 B(-) 2 4 6 8 10 12 14 16 18 20 1 3 5 7 9 11 13 15 17 19 COM H L 0V L ● MP5W- 9 (PNP open collector+RS485 comm. output) MAIN OUT (NPN OPEN COLLECTOR) 30VDC 30mA +24VDC ※ 30mA Max. 1 HH GO LL O-80 GO MAIN OUT (PNP OPEN COLLECTOR) 30VDC 30mA HH GO 2 4 1 3 COM H A(+) RS485 LL 6 5 L -|Transparent setting guide|- Pulse Meter ▣ Dimensions (unit: mm) ※Side dimensions of MP5Y/W differ by output type. SENSORS MP5S Series 48 10 90 CONTROLLERS 45 MOTION DEVICES SOFTWARE MP5Y Series MP5Y- N 72 6 MP5Y - 1/2/3/4/5 89.5 MP5Y- 6 14.5 10.5 15.3 36 30 (J) Temperature Controllers (K) SSRs MP5W Series MP5W- N 6 96 MP5W- A/1 89.5 10.5 10.5 MP5W - 2/4/5/8/9 14.5 (L) Power Controllers (M) Counters 48 45 (N) Timers (O) Digital Panel Meters (P) Indicators Panel cut-out A (Q) Converters (unit: mm) D B C Series MP5S MP5Y MP5W Size A B Min. 55 Min. 62 Min. 91 Min. 40 Min. 116 Min. 52 C D 45.5 68 92 +0.7 0 +0.8 0 +0.5 0 45.5 31.5 45 (R) Digital Display Units +0.5 0 +0.5 0 (S) Sensor Controllers +0.6 0 (T) Switching Mode Power Supplies Bracket For MP5S For MP5Y/W 15 (W) Panel PC 14.5 (X) Field Network Devices 60.2 □45.8 (V) HMIs 73 12 48.3 10 4.4 26.3 (U) Recorders O-81 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ▣ Unit Description MP5S Series MP5S Series MP5S Series 4 4 1 2 1 2 3 1 3 1: Display component Displays current value in RUN mode. Alternately displays setting parameters and corresponding value in SETTING mode. 2:  key In RUN mode, press the key once to check max./min. value. In RUN mode, hold the key for over 2 sec to enter parameter groups. 3:  , , key Select parameter groups, and select or setting values in the corresponding parameters. 4: Output status indicator 2 3 ▣ Sold Separately Communication converter SCM-WF48 (Wi-Fi to RS485·USB wireless communication converter) SCM-38I SCM-US48I (RS232C to RS485 converter) (USB to RS485 converter) Display Units (DS/DA-T Series) DS/DA-T Series (RS485 communication input type display unit) DS16- T DS22/DA22- T DS40/DA40- T DS60/DA60- T ※Connect RS485 communication input type display unit (DS/DA-T Series) and RS485 communication output model of MP5Y/MP5W Series, the display unit displays present value of the device without PC/PLC. ▣ Input Specifications 1. Input signal Standard duty ratio of input signal is 1:1. ON (1) Solid state input 1 Input frequency: Max. 50kHz (ON/OFF pulse width: min. 10㎲ of each) OFF (2) S  olid state input 2 Pulse width Input frequency: Max. 5kHz (ON/OFF pulse width: min. 100㎲ of each) OFF ON ※For F7, F8, F9, F10 operation mode, max. 1kHz (ON/OFF pulse width: min. 500㎲ of each) T (3) Contact input ① Input frequency: Max. 45Hz (when each ON/OFF pulse width is over 11ms) ※T: s ingle cycle of input signal ② Contact specifications: 12VDC, stable switching of load current as small as 5mA 2. Input type [IN-A, IN-B] MP5 allows selection between NPN input (solid state/contact) or PNP input (solid state/contact). (1) NPN input type (2) PNP input type O-82 IN 0V (COM) MP5 3.9kΩ Sensor circuit Sensor circuit 0V (COM) 3.9kΩ ③PNP open collector ①Contact ②PNP voltage output type sensor output type sensor +12V Sensor circuit IN MP5 Sensor circuit Sensor circuit Sensor circuit ③NPN open collector ①Contact ②NPN voltage output type sensor output type sensor +12V -|Transparent setting guide|- Pulse Meter ▣ Output Specifications 1. Relay output ① Output: Comparative or alarm output (refer to " Output Modes") ② Output type: Relay ③ Contact capacity: 250VAC 3A resistive load ④ Life cycle: [Mechanical] min. 10,000,000 operations (switching frequency 180 operations/min) [Electrical] min. 100,000 operations (3A 250VAC, 30VDC resistive load) (switching frequency 20 operations/min) SENSORS ① Output: Comparative output or alarm output (refer to " ② Output type: NPN/PNP open collector ③ Rated load voltage: 30VDC ④ Max. load current: 30mA MOTION DEVICES 2. Transistor output CONTROLLERS Output Modes") SOFTWARE 3. BCD dynamic output (negative logic) ① Output: present value ② Output signal: BCD data (A, B, C, D, DOT) ← A: lowest bit, DOT: highest bit Digit data (D0, D1, D2, D3, D4) ← D0: lowest digit, D4: highest digit ③ Output type: NPN open collector ④ Rated load voltage: 30VDC ⑤ Max. load current: 30mA ⑥ Dynamic COM cycle (T) = 40ms E.g.) To display value = 125.89 by BCD dynamic output 100-digit 104-digit PV display value 1 2 5. 8 9 A B BCD Data C (J) Temperature Controllers D DOT (K) SSRs D0 0.1ms D1 Digit (L) Power Controllers D2 D3 (M) Counters D4 5ms 8ms 40ms (N) Timers 4. PV transmission output (O) Digital Panel Meters ① Application: transmit measured value ② Function: transmit measured value within setting range of high-limit output [FS-H] to low-limit output [FS-L] after conversion into DC4-20mA or DC0-20mA current. ③ Output range of high/low-limit ·High-limit [FS-H] range: From min. value to max. value within measurement range ·Low-limit [FS-L] range: From min. value to max. value within measurement range ([FS-H]≥[FS-L]+1) (1) DC4-20mA transmission output (2) DC0-20mA transmission output ① Transmit measured value within setting range of high-limit ① Transmit measured value within setting range of high-limit output [FS-H] to low-limit output [FS-L] after conversion output [FS-H] to low-limit output [FS-L] after conversion into into DC4-20mA current. DC0-20mA current. ② Resistive load: Max. 500Ω ② Resistive load: Max. 500Ω ③ Resolution: 8000 divisions ③ Resolution: 10,000 divisions Diplay value FS-H If the setting width between [FS-L] and [FS-H] is lower than 8000 divisions, the resolution is also reduced. (Q) Converters (R) Digital Display Units Display value FS-H FS-L Set [FS-L] and [FS-H] and the output is DC4-20mA. (P) Indicators (T) Switching Mode Power Supplies FS-L 20mA 4mA Set [FS-L] and [FS-H] and the output is DC0-20mA. If the setting width between [FS-L] and [FS-H] is lower than 10,000 divisions, the resolution is also reduced. 20mA (U) Recorders 0mA (V) HMIs 5. RS485 communication output Comm. protocol Connection type Application standard Max. connection Synchronous method Comm. method Comm. distance Modbus RTU RS485 Compliance with EIA RS485 31 units (address: 01 to 99) Asynchronous Two-wire half duplex Max. 800m (S) Sensor Controllers Communication Speed 2400, 4800, 9600 (default), 19200, 38400 bps Communication response time Start Bit Data Bit Parity Bit Stop Bit 5 to 99ms (default: 20ms) 1-bit fixed 8-bit fixed None (default), Even, Odd 1, 2-bit (default) (W) Panel PC (X) Field Network Devices ※For more information about RS485 communication output specifications, refer to ' RS485 Communication Output'. O-83 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ▣ Parameter Groups Parameter 0 group (max./min. monitoring value) RUN mode 2 sec HOLD/RESET 3 sec ※ ※Operation mode F1 to F12 : display value HOLD Operation mode F13 to F16 : display value RESET Parameter 1/2/3 group ※Press the , , keys to select or set the desired value. ※Press the key once after changing the setting value, to save the setting value and move to the next parameter. ※Hold the key for 1.5 sec at any parameters to return to the select parameter group mode. ※Hold the key for 3 sec to save the setting value and return to RUN mode after changing the setting value. ※If there is no key input for 60 sec while setting the parameters, the new settings are ignored, and the unit will return to RUN mode with previous settings. ※The dotted line parameters may not appear depending on output specifications or other parameter settings. Please refer to ' Operation Mode by Parameter Group'. ※1: Each parameter and corresponding setting value will flash alternately every 0.5 sec. ● Parameter 0 group RUN mode PStHH Flashes ※1 alternately 99999 HH comparative value ※Does not appear in F output mode PSt H 99999 H comparative value PSt L 00000 L comparative value PStLL 00000 LL comparative value ※Does not appear in F output mode, hPEK 99999 Max. monitoring value ※The parameters are identical to [PStHH], [PSt H], [PSt L], [PStLL] of parameter 2 group and the setting values will be linked. ●Setting range by operation mode Operation mode Setting range F1, F2, F7, F9, F11, 0 to 99999 F12, F13, F16 F3, F4, F5, F6 0 to setting time range `9999 to 99999 F8, F10, F14, F15 (the setting range varies depending on the decimal point setting.) ※Only appears in comparative value setting models. ※Resetting monitoring value :H  old the key for over 2 sec (reset current value) lPEK O-84 `9999 Min. monitoring value -|Transparent setting guide|- Pulse Meter ● Parameter 1 group 2 sec RUN mode PARa1 PARa2 SENSORS PARa3 CONTROLLERS 3 sec MODE Flashes ※ alternately 1 F ㄹ 1 Operation mode ●Setting range: F1 to F16 NPnhF Sensor type of input A IN-B NPnhF Sensor type of input B STARD ●Setting range Parameter Output mode STARD S (Standard) Output mode OUT-H H (High) OUT-L L (Low) HYS GUARD 0001 fDEFY STArT SOFTWARE ●Setting range Parameter Input sensor type NPnhF NPN solid state input 1 NPnmF NPN solid state input 2 NPnlF NPN contact input PNphF PNP solid state input 1 PNpmF PNP solid state input 2 PNplF PNP contact input IN-A OUT-T MOTION DEVICES Parameter OUT-B OUT-I OUT-F (J) Temperature Controllers (K) SSRs Output mode B (Block) I (One-shot) F (Deflection) Output hysteresis ●Setting range: 0000 to 9999 (the setting range varies depending on the decimal point setting.) (L) Power Controllers ※Does not appear in indicator models. 999(9 (P) Indicators 9(9 (Q) Converters (R) Digital Display Units Auto-zero time for input A (S) Sensor Controllers ●Setting range: )1 to 999(9 (sec) AUToB 999(9 (N) Timers (O) Digital Panel Meters LL, L comparative output limit function Start compensation timer function & compensation time ●Setting range: )0 to 9(9 (sec) AUToA (M) Counters (T) Switching Mode Power Supplies Auto-zero time for input B (U) Recorders MEMO OFF Memory retention ●Setting range: ㅒㅜON, OFF (V) HMIs (W) Panel PC (X) Field Network Devices O-85 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ● Parameter 2 group RUN mode 2 sec PARa1 PARa2 PARa3 3 sec pBANK DOT tUNT O-86 Flashes ※ alternately 1 1 00000 Data bank ●Setting range: 1, 2 ※Only appears in MP5W. Decimal point location of display value ●Setting range: 00000, 000)0, 00)00, 0)000, )0000 tSEC 99(99 tMIN 99(99 Time unit and range ●Setting range tSEC (sec) 99(99 999.99s 999(9 9999.9s 9(5(9 99m 59.9s (5(59 9h 59m 59s 99999 99999s PStHH 99999 HH comparative value ※Does not appear in F output mode PSt H 99999 H comparative value PSt L 00000 L comparative value PStLL 00000 LL comparative value ※Does not appear in F output mode PScaH ^0000 Prescale mantissa (X) of input A ●Setting range: )0001 to (9999 PScaY 10 01 PScbH ^0000 PScbY 10 01 DISpT )05 COUnB 99999 ※The parameters are identical to [PStHH], [PSt H], [PSt L], [PStLL] of parameter 0 group and the setting values will be linked. ●Setting range by operation mode Operation mode Setting range F1, F2, F7, F9, F11, 0 to 99999 F12, F13, F16 F3, F4, F5, F6 0 to set time range `9999 to 99999 F8, F10, F14, F15 (the setting range varies depending on the decimal point setting.) ※Only appears in comparative value setting models. Prescale exponent (y) of input A ●Setting range: 10 - 9 (10-9) to 10 09 (109) Prescale mantissa (X) of input B ●Setting range: )0001 to (9999 Prescale exponent (y) of input B ●Setting range: 10 - 9 (10-9) to 10 09 (109) Display cycle of measured value ●Setting range: )05, )5, 1, 2, 4, 8 (sec) ※Setting range in operation mode F2, F16 : OFF, )05, )5, 1, 2, 4, 8 (sec) Setting value of input B ●Setting range: 1 to 99999 tMIN (min) 99(99 999.99m 999(9 9999.9m 9(5(9 99h 59.9m 99(59 999h 59m 99999 99999m -|Transparent setting guide|- Pulse Meter ● Parameter 3 group RUN mode 2 sec PARa1 PARa2 PARa3 SENSORS 3 sec CONTROLLERS FS-H Flashes ※ alternately 1 99999 FS-L 00000 MA 4-20 ADDR B ㅜㅠ PS 01 9600 High-limit value of PV transmission output Low-limit value of PV transmission output ●Setting range by operation mode Operation mode Setting range F1, F2, F7, F9, F11, F12, 0 to 99999 F13, F16 F3, F4, F5, F6 0 to set time range `9999 to 99999 F8, F10, F14, F15 (the setting range varies depending on the decimal point setting.) ※Only appears in PV transmission output models. MOTION DEVICES SOFTWARE Current output specifications ●Setting range: 4-20, 0-20 (J) Temperature Controllers (K) SSRs Communication address ●Setting range: 01 to 99 (L) Power Controllers Communication speed ●Setting range: 9600, 19200, 38400, 2400, 4800 (bps) (M) Counters (N) Timers P ㅜ RTY STP RSwT COmW NONE 2 20 D ㅇ ISA Communication parity bit ●Setting range: NONE (none), EVEN (even), ODD (odd) (O) Digital Panel Meters ※Only appears in RS485 comm. output models. Communication stop bit ●Setting range: 1, 2 (Q) Converters Communication response wait time ●Setting range by communication speed Communication speed (unit: bps) 2400 4800 9600, 19200, 38400 (P) Indicators (R) Digital Display Units Setting range (unit: ms) 16 to 99 8 to 99 5 to 99 (S) Sensor Controllers (T) Switching Mode Power Supplies Communication write ●Setting range: ENA (enable), DISA (disable) (U) Recorders LOC OFF Lock ●Setting range Parameter OFF LOc0 LOc1 LOc2 LOc3 (V) HMIs Function Unlock Lock all Parameter 1/2/3 lock Parameter 2/3 lock Parameter 3 lock (W) Panel PC (X) Field Network Devices O-87 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ▣ Operation Mode by Parameter Groups Parameter Operation mode PStHH 0 group PSt H PSt L F1 F2 F3 F4 F5 F6 F7 ( : parameter display, X: no parameter display) F8 F9 F10 F11 F12 F13 F14 F15 F16 ※1 ※2 Appears in all operation modes (F1 to F16). ※2 ※1 PSt LL hPEK lPEK MODE Appears in all operation mode (F1 to F16). IN-A 1 group IN-B OUT-T HYS GVARD ※3 ※2 ※4 ※2 ※2 AVToA AVToB MEMO ※Only appears in MP5W. Appears in all operation modes (F1 to F16). pBANK DOT tUNT PStHH 2 group PSt H PStLL PSt L ※1 ※2 Appears in all operation modes (F1 to F16). ※2 ※1 PScaH PScaY PScbH PScbY DISpT ※5 COUnB FS-H ※Only appears in PV transmission output models. Appears in operation modes (F1 to F16). FS-L ㅡMA 3 group ADDR BPS PRTY ※Only appears in RS485 comm. output models. Appears in all operation modes (F1 to F16). STP REwT COmW LOC ※1: Only appears in only for quintuple output models. ※2: Only appears in triple, quintuple output models. ※3: The settings for IN-B and IN-A are applied. ※4: ( ) F output mode [OUT-F] cannot be set. ※5: ( ) setting range: OFF, )05, )5, 1, 2, 4, 8 Monitoring delay function by output mode Output mode Parameter Comparative output limit Start compensation timer O-88 S mode H mode L mode B mode I mode F mode STARD OVT-; OVT-L OVT-B OVT-I OVT-F -|Transparent setting guide|- Pulse Meter ▣ Operation Modes [MODE] Select operation mode from operation mode[MODE]of parameter 1 group.. MP5 has 16 operation modes. SENSORS F1 Mode: Frequency/Revolutions/Speed CONTROLLERS Measures the frequency of input A and displays the calculated frequency, revolutions, and speed. 1) Frequency (Hz) =f×α (α= 1 [sec]) 2) Revolutions (rpm) =f×α (α= 60 [sec]) 3) Speed (m/min) =f×α (α= 60L [sec]) MOTION DEVICES SOFTWARE ※L: travel distance of conveyor belt of 1 pulse cycle[m] α: prescale value 60L For multiple objects, α = N MP5 Encoder Display value and display unit Display value Frequency Revolutions Speed Display unit α (prescale value) Hz 1 kHz 0.001 rps 1 rpm (default) 60 mm/sec 1,000L cm/sec 100L m/sec 1L m/min 60L km/hour 3.6L Timing chart (J) Temperature Controllers Input A t1 Hold input t2 t3 t4 1 α 1 α t1 t2 Display Passing speed Display unit α (prescale value) 1,000L cm/sec 100L m/sec (default) 1L m/min 60L km/hour 3.6L 1 α t5 (L) Power Controllers 1 α t6 (N) Timers MP5 (O) Digital Panel Meters (P) Indicators Sensor B Sensor A Timing chart mm/sec (K) SSRs t6 (M) Counters Displays the passing speed between input A ON and input B ON. Passing speed (V) = f × α (α = L[m]) ※f : reciprocal of time [sec] between input A (sensor) ON and input B (sensor) ON. L: distance between input A (sensor) and input B (sensor) [m] α: prescale value Display value t5 1 α t3 F2 Mode: Passing Speed Display value and display unit MP5 (Q) Converters Input A Input B Hold input (R) Digital Display Units ta t1 t2 1 t1 α Display t3 t4 1 t2 α 1 t3 α (S) Sensor Controllers t5 t6 t7 1 1 1 α α t6 t4 t7 α (T) Switching Mode Power Supplies ※ta: Return time (over 20ms) F3 Mode: Cycle (U) Recorders Displays the measured time from Input A ON to the next ON. Cycle (T) = t ※t: measurement time [sec] Display value Display unit Sec Min 999.99s (default) 999.99m Cycle 9999.9s 9999.9m 99m 59.9s 99h 59.9m 9h 59m 59s 999h 59m 99999s 99999m (V) HMIs Photoelectric sensor Display value and display unit ([tUNT] of parameter 2) MP5 Timing chart (W) Panel PC Input A Hold input Display t1 t2 t3 t1 t2 t4 t5 t3 (X) Field Network Devices t6 t5 t6 O-89 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series F4 Mode: Passing Time Measures the time from Input A ON to the next ON, and displays the passing time of the arbitrary distance. Passing time[sec]= t × α (α= L[m] ) Distance advanced in 1 pulse cycle [m] ※t : measured time[sec], L : arbitrary distance[m] α: prescale value Display value Passing time ] th[m eng Display value and display unit ([tUNT] of parameter 2) L:L MP5 Display unit SEC MIN 999.99s (default) 999.99m 9999.9s 9999.9m 99m 59.9s 99h 59.9m 9h 59m 59s 999h 59m 99999s 99999m Timing chart Input A t1 Hold input Display t2 t3 t4 t1 α t2 α t5 t6 t5 α t3 α t6 α F5 Mode: Time Interval Displays measured time of Input A ON Time interval (T) = t ※t: measured time of input A ON [sec] MP5 Motor Display value and display unit ([tUNT] of parameter 2) Display value Time interval Stamp Display unit SEC MIN 999.99s (default) 999.99m 9999.9s 9999.9m 99m 59.9s 99h 59.9m Hold input 9h 59m 59s 999h 59m Display 99999s 99999m Timing chart Input A t1 ta t2 ta t3 t1 t3 t2 ※ta: Return time (over 20ms) F6 Mode: Time Differential Displays measured time from Input A ON to Input B ON. Time differential (T) = t (ta to tb) ※t (ta to tb): measured time from input A ON to input B ON [sec] MP5 Display value and display unit ([tUNT] of parameter 2) Display value Time difference O-90 Display unit SEC MIN 999.99s (default) 999.99m 9999.9s 9999.9m 99m 59.9s 99h 59.9m 9h 59m 59s 999h 59m 99999s 99999m Sensor B Sensor A Timing chart Input A Input B Hold input Display ta t1 t2 t1 t3 t2 ※ta: Return time (over 20ms) t4 t3 t5 t6 t4 t7 t6 t7 -|Transparent setting guide|- Pulse Meter F7 Mode: Absolute Ratio Measures and displays relative speed, amount, speed, etc. of input B against input A in percentage (%). Absolute ratio = (Input B / Input A) × 100% Frequency of input B[Hz] × Bα Absolute ratio = × 100[%] Frequency of input A[Hz] × Aα Flow meter A MP5 Display value Display unit Absolute ratio % ※Hold: When the hold signal turns ON, the display value is maintained until the display cycle turns to hold OFF. CONTROLLERS Liquid ※Aα: Prescale value of input A, Bα: Prescale value of input B Display value and display unit SENSORS Flow meter B Timing chart MOTION DEVICES Input A fA Input B SOFTWARE fB Display = Frequency of input B[Hz] × Bα × 100[%] Frequency of input A[Hz] × Aα F8 Mode: Error Ratio Measures and displays the relative rate of input B against the reference value of input A in percentage (%). Input B-Input A Error ratio = × 100[%] Input A (Frequency of input B [Hz] × Bα) - (Frequency of input A[Hz] × Aα) Error ratio = × 100[%] Frequency of input A[Hz] × Aα ※Aα: prescale value of input A, Bα: prescale value of input B Display value and display unit Display value Display unit Error ratio % Timing chart Conveyor A (J) Temperature Controllers Conveyor B (K) SSRs MP5 (L) Power Controllers Input A (M) Counters fA Input B ※Hold: When the hold signal turns ON, the display value is maintained until the display cycle turns to hold OFF. (N) Timers fB (O) Digital Panel Meters F9 Mode: Density Measures and displays the density ratio (%) of input B against the total sum of input A and input B. Input B Density = × 100[%] Input A + Input B Frequency of Input B[Hz] × Bα Density = × 100[%] (Frequency of input A[Hz] × Aα) + (Frequency of input B[Hz] × Bα) ※Aα: Prescale value of input A, Bα: Prescale value of input B Display value and display unit Display value Display unit Density % (P) Indicators Flow meter A Flow meter B (Q) Converters MP5 Liquid (R) Digital Display Units Timing chart (S) Sensor Controllers Input A fA (T) Switching Mode Power Supplies Input B ※Hold: When the hold signal turns ON, the display value is maintained until the display cycle turns to hold OFF. fB F10 Mode: Error Conveyor A Measures and displays the error of input B against reference value of input A. (U) Recorders Conveyor B (V) HMIs Error = Input B - Input A Error = (Frequency of input B[Hz] × Bα) - (Frequency of input A[Hz] × Aα) (W) Panel PC ※Aα: prescale value of input A, Bα: prescale value of input B Display value and display unit Display value Display unit Error END User setting ※Hold: When the hold signal turns ON, the display value is maintained until the display cycle turns to hold OFF. MP5 Timing chart (X) Field Network Devices Input A fA Input B fB O-91 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series F11 Mode: Length Measurement 1 Measure and display the number of input A pulses during input B ON. Input A Length measurement = P × α ※P: Number of input A pulses, α: Prescale value Display value and display unit Display value Display unit Quantity (default) mm Length measurement cm m Photoelectric sensor MP5 Timing chart Input A Input B 1 2 3 4 5 6 1 2 1 2 3 4 Input B tb ta Hold input 6 α Display 2 α 4 α ※ta, tb: return time (over 20ms) F12 Mode: Interval MP5 Measures and displays the number of input A pulses from Input B ON to the next ON. Interval = P × α ※P: Number of input A pulses, α: Prescale value Display value and display unit Display value Interval Display unit Quantity (default) Input A mm Input B cm m Photoelectric sensor Timing chart 1 2 3 4 5 1 2 3 4 1 2 3 ta Hold input 5×α Display 4×α ※ta: return time (over 20ms) F13 Mode: Accumulation Measures and displays the counted value of input A pulses. Accumulation = P × α ※P: Number of input A pulses, α: Prescale value MP5 Display value and display unit Display value Display unit Accumulation Quantity[EA] Operation ①Counts the number of input A pulses. ②Input B is an enable input signal. During ON, the quantity and display value of input A will be held, and during OFF input A will be re-counted. ③When RESET input is ON, the integrated counted value will be reset to "0". O-92 Timing chart Input A Input B RESET Display 0 1 1 2 3 2 3 ※α=1 display value 4 5 6 4 5 6 1 0 1 2 3 4 2 3 4 -|Transparent setting guide|- Pulse Meter F14 Mode: Addition/Subtraction-Individual Input MP5 Displays the counted value from added input A pulses and subtracted input B pulses. When there are two inputs simultaneously, it will not count. Addition/Subtraction = Input A × α - Input B × α ※α: Prescale value of input A Display value and display unit Display value Display unit Addition/ Subtraction (individual input) Quantity Operation and timing chart Pulse of input A is added, and pulse of input B is subtracted. SENSORS Photoelectric Input A sensor (addition) Timing chart Display value and display unit Display value Display unit Up/Down counting (phase difference input) Quantity H L H Input B L RESET H L MOTION DEVICES SOFTWARE Display 0 1 2 32 Display value Display unit Length measurement 2 Quantity[EA] ※If input A and input B are ON during initial power supply, it will not count and only count the number of rising edge. ※Display value is renewed depending on the display cycle [DISpT] setting. 1 2 3 2 1 (J) Temperature Controllers Input A Input B (K) SSRs MP5 Timing chart (L) Power Controllers H Input A L H Input B L RESET H L (M) Counters 0 1 2 3 2 1 0 (N) Timers 1 2 0 (O) Digital Panel Meters Timing chart (e.g.) setting value of Input B=4 Measures and displays the number of pulses from input A until the value of input B reaches the set value. H Input A L Length measurement 2 = P × α (until the setting value of Input B) H Input B L ※P: Number of input A pulses, α: Prescale value Display value and display unit 0 ※α=1 display value Display F16 Mode: Length Measurement 2 CONTROLLERS Input A F15 Mode: Addition/Subtraction- Phase difference input When input A is low, counting is added to the low of input B. When input A is low, counting is subtracted from the high of input B. Addition/Subtraction (phase difference) = Detects position and speed using A and B phases of encoder outputs as input. Input B (subtraction) 1 2 1 2 3 4 (P) Indicators 1 2 3 H RESET L 1 2 3 4 0 1 2 3 4 5 6 7 0 1 2 3 4 5 Display Display ※1 0 7 ※1: W  hen the display cycle [DISpT] setting is OFF, it will maintain the quantity of input A until the value of input B reaches the setting value B [COUnB]. (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices O-93 -|Transparent setting guide|- MP5S/MP5Y/MP5W Series ▣ Output Modes [OUT-T] MP5 Series supports 6 output modes. (There is no output mode in indicator models). Requirement for setting comparative value: (B output mode) LL
MP5M-4N 价格&库存
很抱歉,暂时无法提供与“MP5M-4N”相匹配的价格&库存,您可以联系我们找货
