MT4W-AA-49
MT4W-AA-49
    AUTONICS(奥托尼克斯)
    AC AMP 0-5A 3 PNP 100-240VAC
MT4W-AA-49 数据手册
-|Transparent setting guide|- MT4Y/MT4W Series DIN W72×H36mm, W96×H48mm, Digital Multi Panel Meter ▣ Features SENSORS ● Various input/output (default: indicator) - Input: DC voltage, DC current, AC voltage, AC current - Output: RS485 communication output, Low speed serial output, transmission (DC4-20mA) output, BCD dynamic output, NPN/PNP open collector output, relay output ● Maximum allowed input : 500VDC, 500VAC, DC5A, AC5A ● Display range: -1999 to 9999 ● High/low-limit display scale function ● AC frequency measurement (range: 0.1 to 9999Hz) ● Various functions: Monitoring peak display value function, display cycle delay function, zero adjustment function, high display correction function, transmission (DC4-20mA) output scale function etc. ● Power supply: 12-24VDC, 100-240VAC 50/60Hz CONTROLLERS MOTION DEVICES SOFTWARE (J) Temperature Controllers Please read “Safety Considerations” in the instruction manual before using. (K) SSRs ▣ Ordering Information MT 4 W DV 4 (L) Power Controllers N MT4Y Output MT4W Power supply Measurement function (input) Size Digit Item N 0 1 2 100-240VAC ※1 3 ※ 4 1 5 6 Indicator Relay output NPN open collector output PNP open collector output Relay (low out)+transmission (DC4-20mA) output Relay (low out)+RS485 communication output BCD dynamic output Low speed serial output N 12-24VDC, 0 100-240VAC 1 2 3 4 5 100-240VAC 6 7 8 9 Indicator Relay+transmission (DC4-20mA) output Relay output NPN open collector+BCD dynamic output PNP open collector+BCD dynamic output NPN open collector+transmission (DC4-20mA) output PNP open collector+transmission (DC4-20mA) output NPN open collector+low speed serial output PNP open collector+low speed serial output NPN open collector+RS485 communication output PNP open collector+RS485 communication output ※2 1 4 12-24VDC 100-240VAC 50/60Hz DV DA AV AA DC voltage DC current AC voltage AC current Y W DIN W72×H36mm DIN W96×H48mm 4 9999 (4-digit) MT Multi meter (M) Counters (N) Timers (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices ※1: Only lST(preset output mode) setting is available in MT4Y-☐-43 (relay (low out)+transmission (DC4-20mA) output) and MT4Y-☐-43 (relay (low out)+transmission (DC4-20mA) output) models. ※2: Only for MT4W. ※To measure the current over DC5A, please select DV type because the shunt should be used. ※In case of selecting frequency display, no output will be provided even if it is output support models. (main output, sub output and RS485 communication output) O-25 -|Transparent setting guide|- MT4Y/MT4W Series ▣ Specifications MT4Y-AV-4 MT4W-DV-4 MT4W-AV-4 MT4Y-AA-4 MT4W-DA-4 MT4W-AA-4 AC voltage, AC voltage, DC voltage, DC voltage, current, current, current current frequency frequency 100-240VACᜠ 50/60Hz 90 to 110% 5VA 7-segment LED display (red) (character height: 14.2mm) MT4Y-DV-4 MT4Y-DA-4 Series Measurement input Power supply Allowable voltage range Power consumption Display method MT4W-DV-1 MT4W-DA-1 DC voltage, current MT4W-AV-1 MT4W-AA-1 AC voltage, current, frequency 12-24VDCᜡ 90 to 110% 5W • 23℃±5℃ - D  C input: F.S. ±0.1% rdg±2-digit / AC input: F.S. ±0.3% rdg±3-digit (frequency: F.S.±0.1% rdg±2-digit) ※For 5A terminal of current Input, F.S +0.3% rdg ±3-digit • -10℃ to 50℃ - DC/AC input: F.S.±0.5% rdg±3-digit Display accuracy Max. allowable input A/D conversion method Sampling cycle Max. display range 110% F.S. for each measured input range ΣΔ (Sigma Delta) ADC DC input: 50ms, AC input: 16.6ms -1999 to 9999 (4-digit) • Relay output - Contact capacity: 250VACᜠ 3A, 30VDCᜡ 3A / Contact composition: N.O (1a) Preset output • NPN/PNP open collector output - Max. 12-24VDCᜡ ±2V 50mA (resistive load) • RS485 comm output - Baud rate: 1,200/2,400/4,800/9,600, Communication method: 2-wire half duplex, Sub output Synchronous method: Asynchronous method, Protocol: Modbus type (transmission output) • Serial/BCD dynamic output - NPN open collector output: Max. 12-24VDCᜡ 50mA (resistive load) • DC4-20mA output - Resolution: 12,000 division (load resistance max. 600Ω), Response time: max. 450ms AC measurement※1 Selectable RMS or AVG Measurement range: 0.100 to 9999Hz (variable by decimal point position) Frequency measurement※1 Includes (external hold function) Hold function※2 Insulation resistance Over 100MΩ (at 500VDC megger, between external terminal and case) Dielectric strength 2000VAC 50/60Hz for 1 min (between external terminal and case) Noise immunity ±2kV the square wave noise (pulse width: 1㎲) by the noise simulator Mechanical 0.75mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Vibration Malfunction 0.5mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 10 min Mechanical 100m/s² (approx. 10G) in each X, Y, Z direction for 3 times Shock Malfunction 300m/s² (approx. 30G) in each X, Y, Z direction for 3 times Malfunction Min. 20,000,000 operations Relay life cycle Mechanical Min. 100,000 operations (250VAC 3A load current) Environ Ambient temperature -10 to 50℃, storage: -20 to 60℃ -ment Ambient humidity 35 to 85%RH, storage: 35 to 85%RH Double insulation or reinforced insulation Insulation type (mark: , dielectric strength between the measurement input part and the power part: 1kV) Approval ᜢᜧ ᜢ Approx. 213.5g (approx. 134g) Approx. 326g (approx. 211g) Weight※3 ※1: AC, frequency measurement functions are only for AC measurement input type. ※2: MT4Y- -4N model has no hold function. ※3: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. ▣ Unit Description MT4Y Series MT4W Series 1 2 3 6 1 2 6 3 4 5 1. HI: High output indication of preset 2. GO: GO output indication of preset 3. LO: Low output indication of preset 4 5 4. MODE key: mode key 5. key: moves digit, enters parameter mode, 6. unit label part ※There is no 1, 2, 3 on a display panel of MT4Y- -4N, 45, 46 and MT4W- -4N. ※In MT4Y- - 3, 4, OUT is used for Go output display and there is no 1, 3 in display panel. O-26 key: changes sv -|Transparent setting guide|- Multi Panel Meter ▣ Connections Measurement input terminal connection of MT4Y Series ● MT4Y-DV-4 1 2 3 4 5 6 250mV /50mV 5V/1V 7 5 6 7 2V/1V SOURCE 100-240VAC 50/60Hz 5VA 50V/10V 500V/100V ● MT4Y-DA-4 1 2 3 4 ● MT4Y-AV-4 1 2 3 4 ※Use terminals of size specified below. ※U se the Copper-conductor wire with the temperature class 60. 5 6 5mA /2mA 500V/250V ● MT4Y-AA-4 1 2 3 4 7 a b CONTROLLERS Min. 3.5mm Max. 7.0mm MOTION DEVICES SOFTWARE 5 100mA /50mA 500mA /250mA SOURCE 100-240VAC 50/60Hz 5VA 50mA/ 4-20mA 500mA/200mA a b SOURCE 100-240VAC 50/60Hz 5VA 20V/10V 110V/50V 6 7 SOURCE 100-240VAC 50/60Hz 5VA 1A 5A/2.5A 5A/2A Output terminal connection of MT4Y Series ●MT4Y- -4N (indicator) ●MT4Y- -40 (triple relay output) 8 (J) Temperature Controllers ●MT4Y- -41 (triple NPN open collector output) 9 10 11 12 13 8 (K) SSRs 9 10 11 12 13 Hold/Zero 1 2 3 4 5 6 7 HI 8 + Hold/Zero GO COM D0 D2 4 6 8 10 12 14 1 3 5 7 9 11 13 D D1 8 Hold/Zero 2 B 8 - D3 (M) Counters 9 10 11 12 13 B (-) Hold/Zero (N) Timers A (+) RS485 OUT1 Hold/Zero (O) Digital Panel Meters CONTACT OUT : 250VAC 3A 1a, 30VDC 3A 1a RESISTIVE LOAD PCB ●MT4Y- -46 (low speed serial output) Dot LO COM (relay+RS485 communication output) CONTACT OUT : 250VAC 3A 1a, 30VDC 3A 1a RESISTIVE LOAD (BCD dynamic output) C GO ●MT4Y- -44 9 10 11 12 13 DC4-20mALoad OUT1 600Ω max. LO COM ●MT4Y- -45 A HI (relay+transmission (DC4-20mA) output) 9 10 11 12 13 (L) Power Controllers Hold/Zero LO COM ●MT4Y- -43 (triple PNP open collector output) HI GO CONTACT OUT : 250VAC 3A 1a, 30VDC 3A 1a RESISTIVE LOAD ●MT4Y- -42 8 (P) Indicators 9 10 11 12 13 (Q) Converters Hold/Zero CLOCK DATA LATCH POL COM ※POL: When a display value is "-", the signal of "-" will be outputted. POL (R) Digital Display Units ※Hirose connector: HIF3BA-14PA-2.54DS ※Connector socket specification: Contact the manufacture for the socket and cable. Manufacture Specifications Connector socket HIF3BA-14D-2.54R Hirose Electric ● MT4W-DV2 ● MT4W-AV- 3 4 5 6 7 250mV /50mV Hold/Zero 5V/1V 50V/10V 500V/100V COM ● MT4W-DA1 2 3 4 5 6 7 5mA /2mA 50mA/ 4-20mA 500mA/200mA 5A/2A COM Hold/Zero 8 + 9 + 2 3 4 9 - SOURCE 12-24VDC 5W 100-240VAC 50/60Hz 5VA 5 6 7 2V/1V - SOURCE 12-24VDC 5W 100-240VAC 50/60Hz 5VA 8 1 Hold/Zero 20V/10V 500V/250V COM ● MT4W-AA2 3 4 5 6 7 100mA /50mA 500mA /250mA 1A 5A/2.5A COM 8 + (U) Recorders 9 - (V) HMIs SOURCE 12-24VDC 5W 100-240VAC 50/60Hz 5VA 110V/50V 1 (S) Sensor Controllers (T) Switching Mode Power Supplies Measurement input terminal connection of MT4W Series 1 SENSORS Hold/Zero 8 + (W) Panel PC (X) Field Network Devices 9 - SOURCE 12-24VDC 5W 100-240VAC 50/60Hz 5VA O-27 -|Transparent setting guide|- MT4Y/MT4W Series Output terminal connection of MT4W Series ● MT4W- - 0 (triple relay+transmission (DC4-20mA) output) ● MT4W- - 1 (triple relay output) MAIN OUT CONTACT OUT : 250VAC 3A 1a, 30VDC 3A 1a RESISTIVE LOAD 10 11 12 13 14 15 + HI 1 2 GO 3 LO 4 COM 5 MAIN OUT CONTACT OUT : 250VAC 3A 1a, 30VDC 3A 1a RESISTIVE LOAD 10 11 12 13 14 15 HI DC4-20mA Load 600Ω Max. 6 7 8 9 1 2 3 GO 4 5 LO 6 7 8 9 PCB 1 2 3 4 5 6 7 8 9 ※Hirose connector: HIF3BA-20D-2.54R ※Connector socket specification: Contact the manufacture for the socket and cable. Specifications Manufacture Connector socket HIF3BA-20D-2.54R Hirose Electric I/O cable (Sold separately) CO20-HP -L, CO20-HP -R Autonics ● MT4W- -42 / MT4W- -43 (triple NPN/PNP open collector+BCD dynamic output) +24VDC 30mA Max. GO MAIN OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA B D D1 D3 16 18 17 2 4 6 8 10 12 14 1 3 5 7 9 11 13 15 A C D0 D2 COM1 HI LO 0V 20 19 MAIN OUT: PNP OPEN COLLECTOR 12-24VDC Max. 50mA POL BCD OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA +24VDC 30mA Max. GO DOT COM2 2 4 1 3 COM1 HI 6 5 +24VDC 30mA Max. MAIN OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA 2 4 1 COM1 6 ※POL: When a display value is "-", the signal of "-" will be outputted. 3 5 HI LO 10 12 14 16 18 20 7 9 11 13 15 17 19 MAIN OUT: PNP OPEN COLLECTOR 12-24VDC Max. 50mA (+) 0V +24VDC 30mA Max. GO (-) 8 7 0V LO ● MT4W- -44 / MT4W- -45 (triple NPN/PNP open collector+transmission (DC4-20mA) output) GO 8 2 4 1 3 COM1 HI Current: DC4-20mA LOAD 600Ω Max. 6 5 LO 8 7 0V ● MT4W- -46 / MT4W- -47 (triple NPN/PNP open collector+low speed serial output) 2 MAIN OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA 4 1 COM1 3 HI ※POL: When a display value is "-", the signal of "-" will be outputted. +24VDC 30mA Max. GO POL CLOCK LATCH 6 8 10 12 14 16 5 7 9 11 13 15 LO 18 20 17 19 MAIN OUT: PNP OPEN COLLECTOR 12-24VDC Max. 50mA COM2 DATA 0V SERIAL OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA +24VDC 30mA Max. GO 2 4 1 3 COM1 HI 6 5 LO 8 7 0V ● MT4W- -48 / MT4W- -49 (triple NPN/PNP open collector+RS485 communication output) +24VDC RS485 30mA Max. B (-) GO MAIN OUT: NPN OPEN COLLECTOR 12-24VDC Max. 50mA 2 4 1 COM1 O-28 3 HI LO SG 6 8 10 12 14 16 18 20 5 7 9 11 13 15 17 19 MAIN OUT: PNP OPEN COLLECTOR 12-24VDC Max. 50mA SG ※SG (Signal Ground) 0V A (+) :S  ignal ground is the terminal which is base of the RS485 signal voltage. It is connected with terminal 7 inside of the product. +24VDC 30mA Max. GO 2 4 6 8 1 3 5 7 COM1 HI LO 0V -|Transparent setting guide|- Multi Panel Meter ▣ Dimensions (unit: mm) MT4Y Series ● MT4Y- -4N/40~44/46 6 6 10.5 66.5 CONTROLLERS 36 30.2 77 MOTION DEVICES 30.2 72 SENSORS ● MT4Y- -45 SOFTWARE ● Bracket ● Panel cut-out 12 14.5 Min. 40 60 MT4W Series 31.5 +0.5 0 9 4 Min. 91 68 6 +0.7 0 (K) SSRs (L) Power Controllers ● MT4W- -42 to 49 ● MT4W- - N/ 0/ 1 96 (J) Temperature Controllers 100 6 14.9 89.5 (M) Counters 45 45 48 (N) Timers (O) Digital Panel Meters ● Bracket (P) Indicators ● Panel cut-out (Q) Converters 10 4.4 Min. 116 12 14.5 45 73 Min. 52 +0.6 0 (R) Digital Display Units (S) Sensor Controllers 92 +0.8 0 (T) Switching Mode Power Supplies ▣ Parameter Setting RUN 3 sec PA 0 3 sec PA1 2 sec PA2 3 sec (U) Recorders ※Press MODE key in RUN mode and it enters PA 0 group. ※Press MODE key for over 3 sec in RUN mode, it displays [PA1]. ※Press MODE key for over 5 sec in RUN mode, it displays [PA2] after [PA1]. When pressing MODE key continually, it stops displaying at [PA2]. ※It is advanced to current display parameter releasing MODE key at [PA1] or [PA2]. ※Press MODE key for over 3 sec in any parameter groups, it returns to RUN mode. ※If any key is not entered for 60 sec in each parameter, it returns to RUN mode. ※After returning to RUN mode, press MODE key within 2 sec, it returns to previous parameter. (Refer to the below descriptions of each parameter group.) ※PA 0 group cannot be entered when preset output mode of [PA2] group is OFF. O-29 (V) HMIs (W) Panel PC (X) Field Network Devices -|Transparent setting guide|- MT4Y/MT4W Series ▣ Parameter 1 Group RUN 3 sec ● Measurement input chart by model PA1 IN-R Display of factory default for measurement input Select measurement input specification by - Refer to " Measurement Input". Item Range of measurement input MT4Y/W-DV 500V MT4Y/W-DA 5A MT4Y/W-AV 500V MT4Y/W-AA 5A . 100V 2A 50V )5A 250V 2.5A 10V )2A 110P(※) 1A 5V 50MA )5A 1V 4-20MA )25V 5MA 50V 20V 10V )25A )1A 50mA 50ㅡMV 2MA 2V 500V 5A 1V 500V 5A ※Standard specification. (110P is 440VAC/110VAC P.T) DISP STND - Refer to " Measurement Input". (FREQ mode is only for AC measurement type.) IN-T AVG Select measurement method for AC. Setting range: AVG, RMS (average: AVG, root mean square: RMS) (This parameter will be displayed only for AC measurement models. In case of selecting frequency display, it will not be displayed.) STND Max. display value It shows Max. display value of standard specification. Display value is fixed. W hen DISP is FREQ (It is only displayed for AC measurement type.) W hen DISP is SCAL Whe n DISP i s STND DOT H-SC Decimal point Select decimal point position. position Setting range : 0, )0, )00, )000 ※When selecting the decimal point position, "H-SC ", L-SC " have decimal point position. Max. display value Min. display value !000 INbL 00 0 )0 )00 )000 : shift the digit : change setting value) 1 to 9999Hz 0.1 to 999.9Hz 0.10 to 99.99Hz 0.100 to 9.999Hz ※In case of selecting frequency display, no output will be provided even if it is output support models (main output, Sub output and RS485 communication output). Set display value against min. measurement input. ( INbH Decimal point Set frequency measurement range, it is decided as position the decimal point position. ( change the decimal point position) Set display value against max. measurement input. ( L-SC DOT : shift the digit : change setting value) It corrects a gradient of High-limit display value against max. input. Setting range: )100 to %000 (%) : change setting value, : shift the digit) ( INbH !000 It corrects deviation of Low-limit display value against Min. input. Setting range: -99 to 99 (Refer to " Zero adjustment ".) ( : set a deviation value, : shift the digit) INbE 10-0 It corrects a gradient of display value against max.input. Setting range: 0.001 to 9.999 ( : shift the digit, : change setting value) Set Setting range: 10-2 to 101 ( : shift the digit, : change setting value) ※After setting each mode, press MODE key for 2 sec to return to RUN. ※If any key is untouched for 60 sec after advance to parameter, it will return to RUN. Factory defaults Parameter O-30 MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA Parameter MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA IN-R 500V SA 500V SA INbH !000 !000 !000 !000 DISP STND STND STND STND INbL 00 00 00 00 IN-T - - AVG AVG DOT )0 )000 )0 )000 STND 50)0 %000 50)0 %000 INbE - - 10-0 10-0 -|Transparent setting guide|- Multi Panel Meter ▣ Parameter 2 Group RUN SENSORS 5 sec PA2 CONTROLLERS Move after 1 sec OUtT OFF Select preset output mode. (only for available models) Setting range: OFF, lST, hST, LhST, HhST, LlST, LdST ※Only lST setting is available in MT4Y-☐-43 and MT4Y-☐-44 models. MOTION DEVICES HYS 001 Set preset hysteresis. The range is within 10% of max. display range (unit: digit). ※ OUtT mode is OFF, it is not displayed. STaT 0)0 Set startup compensation time. ( : shift the digit, : change setting value) Setting range: 0.0 to 99.9 sec PEkT 00 5 D1sT )2 5 ZERO NO EV1N HOLD FS-H 50)0 SOFTWARE When initially supplying power, delays monitoring of high-limit/low-limit value of display value for the set time. : change setting value) ( :shift the digit, Setting range: 00 to 30 sec ※If it is set to 00 sec [00 S], parameters of high-peak monitoring value [hPEK]/low-limit monitoring value [lPEK] in the parameter 0 group will be not displayed. Set display cycle and also variable sets by 0.1 sec. ( Setting range: 0.1 to 5.0 sec : shift the digit, : change setting value) (K) SSRs key) Select zero function with operation at front. (set with When + Key are pressed for 3 sec to set ㅛㄷㄴYES, it will be zero function and the deviation value is saved automatically at ㅛ INbL mode. (L) Power Controllers Select input with 6, 7 (MT4W)[12, 13 (MT4Y)] terminal or zero function for external signal. (set with , Key) HOLD: Holding display value, ZERO: Zero function using Hold/Zero terminal (M) Counters Set the high limit value, output point of current output 20mA. : change setting value) ( : shift the digit, (When changing measurement input and prescale mode, it is changed automatically as maximum value of input range.) Set the low limit value, output point of current output 4mA. : change setting value) ( : shift the digit, (When changing measurement input and prescale mode, it is changed automatically as minimum value of input range.) Set the address of RS485 communication output. ( : shift the digit, : change setting value) Setting range: 01 to 99 FS-L 00)0 ADRS 01 BPS 9600 Select Baud rate of RS485 communication output. Setting range: 9600, 4800, 2400, 1200 PRTY NONE Set parity bit of RS485 communication. Setting range: NONE, EVEN, ODD STP 2 Set stop bit of RS485 communication. Setting range: 1, 2 RSwT 5 Set response wait time of RS485 communication. Setting range: 5 to 99 LOC OFF (N) Timers (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies OFF Disable to lock keys Set key lock function and select from 4 types. Setting range: OFF, LOC1, LOC2, LOC3 LOC1 Lock Parameter 1 (U) Recorders LOC2 Lock Parameter 1, 2 LOC3 Lock Parameter 0, 1 and 2 (V) HMIs ※The dotted mode is only displayed for output type. ※After setting each mode, press MODE key for 2 sec to return to RUN mode. ※If any key is untouched for 60 sec after advance to parameter, it will return to RUN mode. (W) Panel PC Factory defaults Parameter OUtT HYS STAT PEkT DIsT ZERO MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA Parameter OFF OFF OFF OFF EV1N 001 001 001 001 FS-H 0)0 0)0 0)0 0)0 FS-L 00 5 00 5 00 5 00 5 ARDS )2 5 )2 5 )2 5 )2 5 BPS NO NO NO NO LOC (J) Temperature Controllers MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA HOLD HOLD HOLD HOLD 50)0 %000 50)0 %000 00)0 )000 00)0 )000 01 01 01 01 9600 9600 9600 9600 OFF OFF OFF OFF O-31 (X) Field Network Devices -|Transparent setting guide|- MT4Y/MT4W Series ▣ Parameter 0 Group RUN hSET 50)0 Set preset High-limit value. (set with , , key) ※It is displayed when set the preset only. When set OFF in OUtT mode of the parameter 2 group, the parameter is not displayed. lSET 00)0 , , key) Set preset Low-limit value. (set with ※It is displayed when set the preset only. When set OFF in OUtT mode of the parameter 2 group, the parameter is not displayed. hPEK )0 lPEK )0 It shows High-limit monitoring value while it is in RUN mode. It will be reset by pressing , , key. ※hPEK parameter is not displayed when PEkT parameter is set as 00 sec [00 5] at the parameter 2 group. It shows Low-limit monitoring value while it is in RUN mode. It will be reset by pressing , , key. ※lPEK parameter is not displayed when PEkT parameter is set as 00 sec [00 5] at the parameter 2 group. ※If any key is untouched for 60 sec after advance to parameter, it will return to RUN mode. Factory defaults Parameter MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA Parameter MT4Y/W-DV MT4Y/W-DA MT4Y/W-AV MT4Y/W-AA hSET 50)0 %000 50)0 %000 hPEK )0 )000 )0 )000 lSET 00)0 )000 00)0 )000 lPEK )0 )000 )0 )000 ▣ Measurement Input Type DC voltage DC current AC voltage AC current Measurement input and range Input impedance Display range [STND] 0-500V 0-100V 0-50V 0-10V 0-5V 0-1V 0-250mV 0-50mV 0-5A 0-2A 0-500mA 0-200mA 0-50mA 4-20mA 0-5mA 0-2mA 0-500V 0-250V 0-110V 0-50V 0-20V 0-10V 0-2V 0-1V 0-5A 0-2.5A 0-1A 0-500mA 0-250mA 0-100mA 0-50mA 0.0 to 500.0 (fixed) 0.0 to 100.0 (fixed) 0.00 to 50.00 (fixed) 0.00 to 10.00 (fixed) 0.000 to 5.000 (fixed) 0.000 to 1.000 (fixed) 0.0 to 250.0 (fixed) 0.00 to 50.00 (fixed) 0.000 to 5.000 (fixed) 0.000 to 2.000 (fixed) 0.0 to 500.0 (fixed) 0.0 to 200.0 (fixed) 0.00 to 50.00 (fixed) 4.00 to 20.00 (fixed) 0.000 to 5.000 (fixed) 0.000 to 2.000 (fixed) 0.0 to 500.0 (fixed) 0.0 to 250.0 (fixed) 0.0 to 440.0 (fixed) 0.00 to 50.00 (fixed) 0.00 to 20.00 (fixed) 0.00 to 10.00 (fixed) 0.000 to 2.000 (fixed) 0.000 to 1.000 (fixed) 0.000 to 5.000 (fixed) 0.000 to 2.500 (fixed) 0.000 to 1.000 (fixed) 0.0 to 500.0 (fixed) 0.0 to 250.0 (fixed) 0.0 to 100.0 (fixed) 0.00 to 50.00 (fixed) [500V] [100V] [50V] [10V] [5V] [1V] [)25V] [50MV] [5A] [2A] [)5A] [)2A] [50MA] [4-20] [5MA] [2MA] [500V] [250V] [110P] [50V] [20V] [10V] [2V] [1V] [5A] [2.5A] [1A] [)5A] [)25A] [)1A] [50MA] 4.33MΩ 4.33MΩ 433.48kΩ 433.48kΩ 43.48kΩ 43.48kΩ 2.28kΩ 2.28kΩ 0.02Ω 0.02Ω 0.22Ω 0.22Ω 2.22Ω 2.22Ω 22.22Ω 22.22Ω 5.01MΩ 5.01MΩ 1.11MΩ 1.11MΩ 200.92kΩ 200.92kΩ 20.92kΩ 20.92kΩ 0.02Ω 0.02Ω 0.10Ω 0.20Ω 0.20Ω 1.02Ω 1.02Ω Prescale display range [SCAL] DOT 0 )0 )00 )000 Display range -1999 to 9999 -199.9 to 999.9 -19.99 to 99.99 -1.999 to 9.999 (Display range is variable according to decimal point position.) ※Connect to the input terminals whose 30% to 100% of the input range includes the max. value of the input range to measure. When the max. input value is under the 30% of the input terminal range, display accuracy is degraded. When the max. input value is over the 100%, it may result in input terminal damage. ※In case of 0 to 110V [110P] of AC voltage range and using P.T (potential transformer) for 440V/110VAC, if 110V is input, and the unit displays 440V automatically by preset scale value for P.T user's convenient. ※When "HHHH" or "LLLL" is flashes with a certain measurement input, disconnect power supply and then check the cables. O-32 -|Transparent setting guide|- Multi Panel Meter ▣ Sold Separately Communication converter SCM-WF48 (Wi-Fi to RS485·USB wireless communication converter) SENSORS SCM-38I SCM-US48I (RS232C to RS485 converter) (USB to RS485 converter) CONTROLLERS MOTION DEVICES SOFTWARE Display Units (DS/DA-T Series) DS/DA-T Series (RS485 communication input type display unit) (J) Temperature Controllers (K) SSRs DS22/DA22- T DS16- T DS40/DA40- T DS60/DA60- T (L) Power Controllers ※Connect RS485 communication input type display unit (DS/DA-T Series) and RS485 communication output model of MT4Y/MT4W Series, the display unit displays present value of the device without PC/PLC. ▣ Functions (N) Timers AC frequency measurement [PA 1 group: DISP] It measures input signal frequency when it is AC input. It uses fixed decimal point [PA1: DOT], measured range can be changed by setting and measured range of decimal point position is as below chart. It is available to adjust the upper gradient at [PA 1: INbH]and [PA 1: INbE]. In order to measure frequency normally, input signal, over 10% F.S. of the measured range, should be supplied. Please select the proper point of ① Measurement range Decimal point position Measurement range (M) Counters 0.000 0.00 0.0 0 0.100 to 9.999Hz 0.10 to 99.99Hz 0.1 to 999.9Hz 1 to 9999Hz ※Accuracy of frequency measurement: Below 1kHz, F.S. ±0.1rdg ±2-digit. From 1kHz to 10kHz, F.S. ±0.3rdg ±2-digit. ② INbH: 0.100 to 9.999 [Gradient adjustment of high value] -2 -1 0 1 ③ INbE: 10 , 10 , 10 , 10 [Index adjustment of INbH] Zero adjustment [Deviation correction function of low limit display value] It adjusts the display value of the optional configured input value as zero by force, zero point error can be adjusted with 3 ways as below. When zero point adjustment with front key and Hold terminal is finished normally, zero point of measurement terminal is displayed and the adjusted value at saved in INbL automatically. Operation Input correction value Front panel key Input external signal Description PA 1: Direct input correction value method at INbL. Press , key for 3 sec at the RUN mode. Short-circuit external Hold terminal 11,12 [6, 7 (MT4W)] over min. 50m. ※Refer to " Error correction", " Error display" and " Parameter 2 Group" for function and error. (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units Transmission (DC4-20mA) output scale [PA2 group: ] / It sets transmission output for the display value at the output current DC4-20mA. It sets display value for 4mA at FS-L and 20mA at FS-H and the range between FS-H and FS-L should be 10% ※When min. set interval between FS-H and FS-L is set as under 10% F.S., it changed as over 10% F.S. automatically. ※Preset display value is fixed to output as 4mA at under FS-L and 20mA at over FS-H. Output 20mA (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC Min. setting range F.S. 10% 4mA FS-L FS-H (X) Field Network Devices Display value O-33 -|Transparent setting guide|- MT4Y/MT4W Series InitializationIt initializes as the factory default status. If press , , keys together for 2 sec in RUN mode, keys, (NO) will flash INIT is displayed and press , , every 0.5 sec. It will be initialized as the factory default when press MODE key after change NO→ YES. Startup compensation time [PA 2 group: STAT]This time function limits Display value for measuring input the operation of an output until the measured input (overvoltage or inrush current) is stable at moment of power on. All outputs are off during startup compensation time setting after power is applied. Setting range: 00.0 to 99.9 (unit: sec) Factory default: 00.0 HHHH LLLL D-HH D-LL F-HH OVER Flashes when measured input is exceeded the max. allowable input (110%) Flashes when measured input is exceeded the min. allowable input (-10%) Turns ON when display input is exceeded the max. display range (9999) or H-SC setting value Turns ON when display input is exceeded the min. display range (-1999) or L-SC setting value Turns ON when input frequency is exceeded the max. display value of measurement range Flashes when it exceeds zero range (±99) ※Error display is released automatically when it is in the measured and display range. ※"LLLL" is displayed when the input specification is DC. ※ After flashing " OVER" 2 times when it exceeds the zero adjustment range, it returns to RUN mode. Display scale [PA 1 group: H-SC/L-SC] This function is to display setting (-1999 to 9999) of particular High/Low-limit value in order to display High/Lowlimit value of measured input. If measured inputs are 'a' and 'b' and particular values are 'A' and 'B', it will display a=A, b=B as below graphs. Display B value A B Display value A a b Input value Display A value B Display value b a Input value Display A value b a Input value Y βY 0 Description B a A b A Display value Input value B B a b Input value a b Input value 15.000 α time 12.000 β time 9.000 6.000 Display value Display value αY Error display Display Gradient correction [PA 1 group: INbH] This function is to correct a gradient of prescale value and display value. (Fig.1) Display value Y can be used as α, β times against X input value by correction function [INbH]. And also can be used as correction function of max. display value (H-SC). Adjustment range is 0.100 to 5.000 and multiply current gradient. E.g.) Input: DC200mV, Display: 3.000 for MT4W-DV X Input value (Fig. 1) 3.000 1.000 0.2 0.4 0.60.8 1V Input value (example of gradient correction) ① Select 0-1VDC[1V] for measurement input in Parameter1. ② Standard specification in input: 0-1VDCᜡ and 1.000 therefore it has to be 15.000 (H-SC) for 1VDCᜡ (input) in order to display 3.000 for 200mVDCᜡ (input). But it is disable due to setting range is 9.999 ③ In this case, please check below chart. Please set as INbH× H-SC=15.000 Setting ① ② ③ ④ ⑤ H-SC L-SC INbH Disable 7.500 5.000 3.750 3.000 0.000 0.000 0.000 0.000 0.000 1.000 2.000 3.000 4.000 5.000 Other In this case, any setting methods display the same display value. Error correction [PA 1 group: INbH / INbL] It corrects display value error of measured input. INbL: ±99 [Adjust deviation of low value] INbH: 5.000 to 0.100 [Correct gradient (%) of high value] Display value= (measured value × INbH ) + INbL E.g.) When the measured range is 0 to 500V, and the display range is 0 to 500.0. If the low display value is "1.2" to 0V input, set -12 as INbL value to display ")0" by adjusting offset of the low value. The display value to 500V measured input varies by adjusting the offset of low value. If this display value is "501.0", calculate 500.0/501.0 (desired display value/the display value), and set the 0.998 correction value as the INbH to display 50)0 by adjusting gradient of high value. ※The offset correction range of INbL is within -99 to 99 for D-0, D-1 digit regardless of decimal point. Display cycle delay [PA 2 group: D1sT] In some applications the measured input may fluctuate which in turn causes the display to fluctuate. By adjusting the display cycle delay function time in the D1sT of parameter 2, the operator can adjust the display time within a range of 0.1 sec to 5 sec. For example, if the operator sets the display cycle time to 4.0 sec, the display value displayed will be the average input value over 4 sec and also will show any changes if any every 4 sec. O-34 -|Transparent setting guide|- Multi Panel Meter Monitoring peak display value [PA 0 group: hPEK/lPEK, PA 2 group: PEkT ] It monitors max./min. value of display value based on the current displays value and then displays the data at hPEK, lPEK of parameter 0. Set the delay time (0 to 30 sec) at PEkT of parameter 2 in order to prevent malfunction caused by initial overcurrent or overvoltage, when monitoring the peak value. Delay time is 0 to 30 sec and it starts to monitor the peak value after the set time. When pressing any one of keys at hPEK, lPEK of parameter 0, the monitored data is initialized. ※hPEK, lPEK parameters is not displayed when monitoring delay time [PEkT] of parameter 2 group is set as 00 sec [00 S]. Preset output operation mode [PA 2 group: OUtT] Mode Output operation Sub output ● RS485 communication output It is able to set address (01 to 99) It is able to transmit by selecting modulation speed (transmitted number of signal per 1 sec) of serial trans -mission. (selectable 1200, 2400, 4800, 9600bps) ● Low-speed serial output It outputs current display value as Low-frequency (50Hz) type. ● Transmission (DC4-20mA) output It outputs DC4-20mA against High/Low-limit scale. (resolution: 12000 division) ● BCD dynamic output It outputs display value as BCD Code. ※Only one sub-output is selectable. (More than one sub-output is not allowed.) lST GO LO hST HI GO H HI H H LhST GO LO H HI HhST GO H LO H HI H LlST GO LO LdST H GO LO H ※"H" means hysteresis and able to set 1 to 99 at "HYS" mode in PA 2 among above comparison output chart. ※ hSETis displayed according to the setting of output operation mode, when user sets "OFF", hSET/ lSET are not displayed. ※Only lST setting is available in MT4Y-☐-43 and MT4Y-☐-44 models. MOTION DEVICES SOFTWARE (J) Temperature Controllers ● BCD dynamic output (negative logic) t ta H H: Hysteresis No output If it is equal or smaller than low setting value, LO output will be ON. If it is bigger than low setting value, GO output will be ON. If it is equal or bigger than high setting value, HI output will be ON. If it is equal or smaller than high setting value, GO output will be ON. If it is equal or smaller than low setting value and equal or bigger than high setting value, the output will be ON. If it is bigger than Low setting value and smaller than high setting value, GO output will be ON. If it is equal or bigger than low set and equal or bigger than high set value, output will be ON. If it is smaller than low setting value and high setting value, GO output will be ON. If it is equal or smaller than low setting value, LO output will be ON. If it is equal or smaller than high setting value, HI output will be ON. If it is bigger than low setting value and High setting value, GO output will be ON. This operation is the same as lST But it doesn't operate at initial low set value, it will operate at next low set value. If this is higher than low set value, Go output will be ON. CONTROLLERS Time chart of BCD dynamic output and Serial output Operation OFF SENSORS t: 7.8ms ta: 0.5ms tw: 5ms tb: 2.3ms tb tw Digit signal Input Data (K) SSRs (L) Power Controllers Data (M) Counters 31.2ms D3 Digit (N) Timers D2 D1 (O) Digital Panel Meters D0 Data A H L H L H B H L L H H C L H H H H D H H H H H dot H H L H H (P) Indicators (Q) Converters (R) Digital Display Units Display (S) Sensor Controllers ● Serial output (negative logic)-Clock frequency:50Hz Latch Clock Data Input ordering Clock Data t ta Cn-1 tb Cn Dn-1 (U) Recorders C1 Dn (V) HMIs D1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 DP D C B A DP D C B A DP D C B A DP D C B A H H L H H H H H L L (T) Switching Mode Power Supplies t: 20ms ta: 0.05ms tw: 5ms tb: 4.95ms tw L H H L H H H H H L ta 1 2 (W) Panel PC DP D (X) Field Network Devices tw tb Latch Display O-35
MT4W-AA-49 价格&库存
很抱歉,暂时无法提供与“MT4W-AA-49”相匹配的价格&库存,您可以联系我们找货
