PRFDAWT30-12DO-IV
PRFDAWT30-12DO-IV
    AUTONICS(奥托尼克斯)
    Cylinder,Threaded-M30
    SENSOR PROX INDUCTIVE 12MM CYL
PRFDAWT30-12DO-IV 数据手册
PRFDAW Series Full Metal, Cylindrical, Long Sensing Distance, Spatter-Resistance, Cable Connector Type Features Long sensing distance High impact and wear resistance to friction with the work or metallic brush (sensing face/housing material: stainless steel) Reduced possibility of malfunction by aluminum scraps Prevent malfunction due to spatter with PTFE coating Excellent noise immunity with specialized sensor IC Built-in surge protection circuit and output short over current protection circuit Stability indicator (green LED) and operation indicator (red LED) : excellent visibility with the 360˚ ring type indicator (except for PRFDAWT08 model) Equipped with the oil resistant cable Protection structure: IP67 (IEC standard) Please read “Safety Considerations” in the instruction manual before using. The Characteristic of Spatter-Resistance Type The hot arc from arc welding machine is adhesive even with metals or plastics. Therefore, normal proximity sensor might have malfunction even though there are no sensing object if the arcs are put on the sensing surface. The arcs are not adhered on the sensing part of the spatter-resistance type proximity sensor as the part is coated with PTFE against thermal resistance. Also, the protection cover sold optionally has the same function. Durability Test Highly resistant to the impact of removing welding sludge attached to the sensing face Continuous hitting test Test conditions Hitting object: 1.3kg of weight Hitting speed: 48 times per 1 min The number of hitting times: 300 thousand times Test model: PRFDAW18 Electromagnetic Resistance Test Metallic brush test Test conditions Testing object: stainless cup brush Rotation speed: 80RPM Testing time: 3 hours Test model: PRFDAW18 Large current from welding generates magnetic field which can affect the proximity sensor to malfunction due to noise. This product, however, can be used near strong noise without malfunctioning, thanks to excellent electromagnetic resistance. This test is conducted in the environment of welding. Test conditions Welding current: 13,000A Installation direction: front and side Test model: PRFDAW Series Diameter of Minimum sensing distance between sensing side weld and sensor Installation direction Front Side 8mm 80mm 80mm 12mm No effect from noise 50mm 18mm 30mm 50mm 30mm 120mm 110mm ※Minimum sensing distance can be different by welding environment. F-64 Full Metal, Cylindrical, Long Sensing Distance, Spatter-Resistance, Cable Connector Type Effect of Aluminum Scraps When aluminum scraps are attached or stacked at sensing side, the proximity sensor does not detect and sensing signal is OFF. However, the below cases may occur to sensing signal. In this case, remove the scraps. (1) W  hen the size of aluminum scraps (d) is bigger than 2/3 of the (2) W  hen aluminum scraps are attached on the sensing side by sensing side size (D) external pressure SENSORS CONTROLLERS (d) (D) External pressure Model Size D (mm) PRFDAWT08 6 PRFDAWT12 10 PRFDAWT18 PRFDAWT30 16 28 MOTION DEVICES Aluminum scraps SOFTWARE Specifications ● DC 2-wire type PRFDAWT08-2DO-IV PRFDAWT12-3DO-IV PRFDAWT18-7DO-IV PRFDAWT30-12DO-IV 8mm 12mm 18mm 30mm 2mm 3mm 7mm 12mm Shield (flush) Max. 15% of sensing distance 12×12×1mm (iron) 12×12×1mm (iron) 30×30×1mm (iron) 54×54×1mm (iron) 0 to 1.4mm 0 to 2.1mm 0 to 4.9mm 0 to 8.4mm 12-24VDCᜡ (10-30VDCᜡ) Max. 0.8mA 150Hz 80Hz 80Hz 50Hz Max. 3.5V Max. ±20% for sensing distance at ambient temperature 20℃ Max. 3 to 100mA Over 50MΩ (at 500VDC megger) 1,000VAC 50/60Hz for 1 min 1.5mm amplitude at frequency 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours 500m/s2 (approx. 50G) Shock in each X, Y, Z direction 1,000m/s2 (approx. 100G) in each X, Y, Z direction for 10 times for 10 times Indicator Stability indicator: Green LED, Operation indicator: Red LED Environ- Ambient temperature -25 to 70℃, storage: -25 to 70℃ ment Ambient humidity 35 to 95%RH, storage: 35 to 95%RH Protection circuit Surge protection circuit, output short over current protection circuit Protection IP67 (IEC standard) Ø4mm, 2-wire, 300mm, Ø5mm, 2-wire, 300mm, M12 connector ※3 M12 connector Cable AWG22, core diameter: 0.08mm, no. of cores: 60, insulator diameter: Ø1.25mm Case/Nut: Stainless steel 303 (SUS 303, PTFE coated), Washer: Stainless steel 304 (SUS 304), Material Sensing side: Stainless steel 303 (SUS 303, PTFE coated, thickness of PRFDAWT08: 0.2mm, PRFDAWT12/18: 0.4mm, RFDAWT30: 0.5mm), Oil resistant cable (gray): Oil resistant polyvinyl chloride (PVC) Approval ᜢ ※4 Weight Approx. 80g (approx. 55g) Approx. 110g (approx. 83g) Approx. 132g (approx. 97g) Approx. 225g (approx. 170g) ※1: Use accessories (nut, washer) made of SUS. Or, sensing distance cannot be guaranteed. ※2: The response frequency is the average value. The standard sensing target is used and the width is set as 2 times of the standard sensing target, 1/2 of the sensing distance for the distance. ※3: Do not pull the Ø4mm cable with a tensile strength of 30N or over and the Ø5mm cable with a tensile strength of 50N or over. It may result in fire due to the broken wire. When extending wire, use AWG22 cable or over within 200m. ※4: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. Model Diameter of sensing side ※1 Sensing distance Installation Hysteresis Standard sensing target Setting distance Power supply (operating voltage) Leakage current ※2 Response frequency Residual voltage Affection by Temp. Control output Insulation resistance Dielectric strength Vibration F-65 (A) Photoelectric Sensors (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets PRFDAW Series Dimensions (unit: mm) PRFDAWT8-2DO-IV 48 Ø15 13 300 28 4 M8×1 Stability indicator (green) Operation indicator (red) Ø4 M12 PRFDAWT12-3DO-IV Ø21 46 17 300 33 4 M12×1 Stability indicator (green) Operation indicator (red) Ø5 M12 PRFDAWT18-7DO-IV Ø29 50 24 300 36 M18×1 4 Stability indicator (green) Operation indicator (red) Ø5 M12 PRFDAWT30-12DO-IV 54 Ø42 5 F-66 300 40 36 M30×1.5 Stability indicator (green) Operation indicator (red) Ø5 M12 Full Metal, Cylindrical, Long Sensing Distance, Spatter-Resistance, Cable Connector Type Control Output Diagram & Load Operating ● DC 2-wire type SENSORS Load Brown Sensing distance (Sn) +V Main circuit Sensing target Load Blue Load 0V NonUnstable sensing sensing area area   CONTROLLERS Stable sensing area (Sn×Approx. 70%) MOTION DEVICES ON OFF Stability indicator ON (green LED) OFF Operation indicator ON (red LED) OFF SOFTWARE ※When the sensing target is placed over approx. 70% of sensing distance (Sn), the operation indicator (red LED) turns ON. When the target is placed within approx. 70% of sensing distance (Sn), the stability indicator (green LED) turns ON. Use the sensor at the position where the stability indicator turns ON. Connections (A) Photoelectric Sensors ● DC 2-wire type (IEC standard) (B) Fiber Optic Sensors Normally Open (N.O.) 2 3 1 4 Brown Load Blue 2 1 3 4 (C) LiDAR 0V Brown Blue +24VDC (D) Door/Area Sensors +24VDC Load (E) Vision Sensors 0V (F) Proximity Sensors ※②, ③ are N·C (Not Connected) terminals. ※For more information about cable and specification, refer to the (I) Connectors/Cable Connectors/Sensor Distribution Boxes/Sockets (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets F-67 PRFDAWT08-2DO-IV Iron(SS401) 1.50 Stainless steel 364 (SUS364) 1.00 Brass(C3601) Aluminum(ALS052) Copper(C1100) 0.50 Sensing distance X (mm) 4.00 Iron(SS401) 3.00 Stainless steel 364 (SUS364) 2.00 Brass(C3601) 1.00 0.00 4 8 10 12 15 18 20 25 30 35 40 45 50 60 70 75 80 90 100 Aluminum(ALS052) Copper(C1100) 4 10 One side length of sensing target d (mm) PRFDAWT18-7DO-IV 80 100 PRFDAWT30-12DO-IV 15.00 8.00 Iron(SS401) 6.00 Stainless steel 364 (SUS364) 4.00 2.00 Sensing distance X (mm) 10.00 0.00 15 20 30 40 50 70 One side length of sensing target d (mm) Brass(C3601) Aluminum(ALS052) Copper(C1100) 4 10 15 20 30 40 50 70 One side length of sensing target d (mm) Iron(SS401) 12.00 6.00 Brass(C3601) 3.00 0.00 80 100 Stainless steel 364 (SUS364) 9.00 Aluminum(ALS052) Copper(C1100) 4 10 15 20 30 40 50 70 One side length of sensing target d (mm) Sensing Distance Feature Data by Parallel (Left/Right) Movement PRFDAWT08-2DO-IV 2.0 80 100 Sensing area (Y) Sensing target Detecting Method Sensing distance (X) Sensing distance X (mm) 5.00 2.00 Sensing distance X (mm) Sensing distance (X) PRFDAWT12-3DO-IV 2.50 0.00 Detecting Method d One side length Sensing Distance Feature Data by Target Material and Size Sensing target PRFDAW Series PRFDAWT12-3DO-IV PRFDAWT18-7DO-IV PRFDAWT30-12DO-IV 3.0 7.0 12.0 11.0 1.7 6.0 2.5 9.0 2.0 1.5 8.0 Sensing area (mm) Sensing area (mm) 1.0 5.0 Sensing area (mm) Sensing area (mm) 1.5 1.3 10.0 4.0 7.0 6.0 5.0 3.0 4.0 0.7 1.0 0.1 2.0 1.5 1.0 0.5 0.0 0.5 1.0 1.5 2.0 Left ← Center → Right Sensing area Y (mm) F-68 3.0 2.0 0.4 2.0 0.5 3.0 2.0 1.0 0.0 1.0 2.0 Left ← Center → Right Sensing area Y (mm) 3.0 1.0 6.0 1.0 4.0 2.0 0.0 2.0 4.0 Left ← Center → Right Sensing area Y (mm) 6.0 15.0 10.0 5.0 0.0 5.0 10.0 15.0 Left ← Center → Right Sensing area Y (mm) Full Metal, Cylindrical, Long Sensing Distance, Spatter-Resistance, Cable Connector Type Proper Usage Load connections SENSORS Brown Brown Load + - + POWER - Blue Blue CONTROLLERS 24VDC Load MOTION DEVICES When using DC 2-wire type proximity sensor, the load must be connected, otherwise internal components may be damaged. The load can be connected to either wire. SOFTWARE In case of the load current is small ● DC 2-wire type Brown Vs R≤ (kΩ) Io-Ioff Load Bleeder resistor(R) Blue + - Vs Vs: Power supply, (A) Photoelectric Sensors Vs2 P> (W) R Io: Min. action current of proximity sensor, [ Ioff: Return current of load, P : Number of Bleeder resistance watt ] (C) LiDAR Please make the current on proximity sensor smaller than the return current of load by connecting a bleeder resistor in parallel. ※W value of Bleeder resistor should be bigger for proper heat dissipation. (D) Door/Area Sensors Mutual-interference & Influence by surrounding metals (E) Vision Sensors When several proximity sensors are mounted close to one another a malfunction of the may be caused due to mutual interference. Therefore, be sure to keep a minimum distance between the two sensors as below chart indicates. Do NOT connect the sensors more than three in parallel. (F) Proximity Sensors (G) Pressure Sensors Parallel B A (H) Rotary Encoders Face to Face (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets When sensors are mounted on metallic panel, it is required to protect the sensors from being affected by any metallic object except target. Therefore, be sure to provide a minimum distance as below chart indicates. m Ød n ℓ ℓ ℓ (unit: mm) Item A B ℓ Ød m n Model (B) Fiber Optic Sensors PRFDAWT08-2DO-IV PRFDAWT12-3DO-IV PRFDAWT18-7DO-IV PRFDAWT30-12DO-IV 35 35 0 8 8 30 40 35 0 12 12 40 65 60 0 18 28 60 110 100 0 30 48 100 F-69
PRFDAWT30-12DO-IV 价格&库存
很抱歉,暂时无法提供与“PRFDAWT30-12DO-IV”相匹配的价格&库存,您可以联系我们找货
