PSM4-AR
PSM4-AR
    AUTONICS(奥托尼克斯)
    SMD
    PRESSURE SENSOR INDICATOR NPN
PSM4-AR 数据手册
-|Transparent setting guide|- PSM Series Pressure Sensor Indicator Features ● Displays multi-CH (8CH/4CH) pressure sensor indicator and alarm output ● Input range: 1-5VDC, DC4-20mA (depending on model) ● Auto pressure sensor model identification function (only for PSS Series, pressure sensor) ● Selectable PV display part color by output operation (red/green) ● Easy check output by output indicator of each channel ● Supports RS485 (Modbus RTU) communication ● Freezer pressure control mode ● Easy wiring with sensor connector (CNE Series) ● Power supply: 12-24VDC ±10% Please read “Safety Considerations” in the instruction manual before using. Comprehensive Device Management Program (DAQMaster) ● DAQMaster is comprehensive device management program for convenient management of parameters and multiple device data monitoring. ● Visit our website (www.autonics.com) to download user manual and comprehensive device management program. < Computer specification for using software > < DAQMaster screen > Item System Operations Memory Hard disk VGA Others Minimum requirements IBM PC compatible computer with Intel Pentium Ⅲ or above Microsoft Windows 98/NT/XP/Vista/7/8/10 256MB+ 1GB+ of available hard disk space Resolution: 1024×768 or higher RS-232 serial port (9-pin), USB port Ordering Information PS M 4 V D Option Control output Input Number of channels Type Item D R Digital input RS485 communication No-mark P NPN open collector output PNP open collector output V A Voltage (1-5VDC) input Current (DC4-20mA) input 4 8 4-channel 8-channel M Multi Channel PS Pressure Sensor Rated Pressure Range and Max. Display Pressure Range Pressure type Negative pressure Decimal point Range MPa - kPa 0.1 0.0 to -101.3 (5.0 to -101.3) kgf/cm2 0.001 0.000 to -1.033 (0.051 to -1.033) bar 0.001 0.000 to -1.013 (0.050 to -1.013) psi 0.01 0.00 to -14.70 (0.74 to -14.70) 0 to -760 (38.0 to -760.0) 0.0 to -29.9 inHg 0.1 (1.50 to -29.90) 0.0 to -103.3 0.1 mmH2O (5.1 to -103.3) ※( ) is max. pressure display range. mmHg G-46 1 Standard pressure Decimal point Range 0.000 to 1.000 0.001 (-0.050 to 1.100) 0.0 to 100.0 0.1 (-5.0 to 110.0) 0 to 1000 1 (-101.3 to 1100) 0.000 to 1.020 0.001 (-0.051 to 1.122) 0.00 to 10.20 0.01 (-0.51 to 11.22) 0.000 to 1.000 0.001 (-0.050 to 1.100) 0.00 to 10.00 0.01 (-0.50 to 11.00) 0.00 to 14.50 0.01 (-0.72 to 15.96) 0.0 to 145.0 0.1 (-7.2 to 159.6) - Compound pressure Decimal point Range 0.1 -101.3 to 100.0 (-101.3 to 110.0) 0.001 -1.034 to 1.020 (-1.034 to 1.122) 0.001 -1.013 to 1.000 (-1.013 to 1.100) 0.02 -14.70 to 14.50 (-14.70 to 15.96) -760 to 750 (-760.0 to 824.0) -29.9 to 29.5 0.1 (-29.88 to 32.58) -103.4 to 102.0 0.1 (-103.4 to 112.2) ※For using a unit mmH2O, multiply display value by 100. 1 -|Transparent setting guide|- Multi-CH Pressure Sensor Indicator Pressure Conversion Chart to Pa kPa MPa kgf/cm2 mmHg mmH2O psi bar from 1Pa 1 0.001 0.000001 0.000010197 0.007501 0.101972 0.000145038 0.00001 1kPa 1000.000 1 0.001 0.010197 7.500617 101.971626 0.145038 0.01 1MPa 1000000 1000 1 10.197162 7500.61683 101971.626 145.038243 10 1kgf/cm2 98066.5 98.0665 0.098067 1 735.55924 10000.0005 14.223393 0.980665 1mmHg 133.322368 0.133322 0.000133 0.001359 1 13.595099 0.019337 0.001333 1mmH2O 9.80665 0.009807 0.000099 0.073556 1 0.00142 0.000098 1psi 6894.733 6.89473 0.006895 0.070307 51.714752 703.016716 1 0.068947 1bar 100000.0 100.0000 0.100000 1.019716 750.062 10197.1626 14.503824 1 1inHg 3386.388 3.386388 0.003386 0.034532 25.40022 345.315507 0.491156 0.033864 E.g.) For calculating 760mmHg to kPa : According to above chart, 1mmHg is 0.133322kPa, therefore 760mmHg will be 760×0.133322kPa=101.32472kPa. Specifications Model Display pressure range Power supply Allowable voltage range Power consumption Current consumption※1 Max. inputs Sensor input Power supply for sensor※2 Control output Hysteresis Repeat error Response time Protection circuits Number of display digits Display method Display part Output indicator Display accuracy Control output and display temperature Digital input ※4 Communication※5 Input Output Insulation resistance Connections Dielectric strength Vibration Ambient temp. Ambient humi. Protection structure Accessory Approval Weight※6 Environment inHg 0.0002953 0.2953 295.299875 28.959025 0.039370 0.002896 2.036014 29.529988 1 PSM4-A PSM8-V PSM8-A PSM4-V Depending on pressure type, pressure unit (refer to '▣ Rated Pressure Range and Max. Display Pressure Range') 12-24VDCᜡ (ripple P-P: max. 10%) 90 to 110% of rated voltage Max. 3W Max. 100mA (120mA for RS485 communication) 4 8 1-5VDCᜡ DC4-20mA 1-5VDCᜡ DC4-20mA 12-24VDCᜡ, 40mA for each channel (max. current of 1-4CH: max. 100mA, max. current of 5-8CH: max. 100mA) NPN or PNP open collector output ● Load voltage: max. 30VDCᜡ ● Load current: max. 100mA ● Residual voltage-NPN: max. 1VDCᜡ, PNP: max. 2VDC Min. display interval ±0.1% F.S. ±min. display interval 2.5ms, 100ms, 500ms, 1000ms 5ms, 100ms, 500ms, 1000ms Output short over current protection circuit, reverse polarity protection circuit PV display part, SV display part: 4-digit, channel display part: 1-digit 7-segment LED method ● SV display part: green ● Channel display part: red ● PV display part: red or green※3 8 (OUT1, OUT2: 4 for each) 16 (OUT1, OUT2: 8 for each) ±0.1% ±2-digit (at 23 ±5℃) SENSORS CONTROLLERS MOTION DEVICES SOFTWARE (A) Photoelectric Sensors (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors (G) Pressure Sensors 0 to 50℃: ±0.2% F.S. ±2-digit (based on 25℃), -10 to 0℃: ±0.3% F.S. ±2-digit (H) Rotary Encoders Digital input (1 point) ● Contact input-[L]: max. 0.2V ● Non-contact input: ON- residual voltage max. 1.0V, OFF- leakage current max. 0.1mA RS485 communication (Modbus RTU method) Sensor connector (for CNE-P04- , sold separately) terminal Hirose connector 20-pin (HIF3BA-20D-2.54R, flat cable 20-wire, sold separately) terminal Over 100MΩ (at 500VDC megger) 1,000VAC 50/60Hz for 1 min (between power terminal and case), ※ 500VAC 50/60Hz for 1 min (between power terminal and RS485 terminal) 5 1.5mm amplitude at frequency of 10 to 50Hz (for 1 min) in each X, Y, Z direction for 2 hours -10 to 50ºC, storage: -20 to 60ºC 30 to 85%RH, storage: 30 to 85%RH Front: IP65, the other part: IP30 (IEC standard) Bracket ᜢ Approx. 108g (approx. 65g) (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets ※1: Except current consumption of sensor part. When all output LED are ON, it is max. 120mA. ※2: Do not short +V and 0V of sensor connector. It may cause break inner circuit. ※3: It is able to select at PV display part color [CLOR] in parameter 2 group. ※4: It is only for the digital input option model (PSM D). ※5: It is only for the RS485 communication option model (PSM R). ※6: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. G-47 -|Transparent setting guide|- PSM Series Dimensions (unit: mm) 57.2 48 34.2 3.5 48 Accessory PC loader port (only for SCM-US (USB/Serial converter, sold separately)) ● Bracket 31 48.6 20 45 Panel cut-out 16 36 44.9 44.8 5 15 55 21 Min. 65 45 +0.6 0 Min. 65 45 56 +0.6 0 Sold Separately „ Pressure sensor: PSS Series (8 types) „ Sensor connector plug: CNE-P04-□ „ Communication converter: SCM-US (USB/Serial converter) „ Hirose connector: HIF3BA-20PA-2.54DS [Standard Connector socket] Please contact to the manufacturer of the socket and cable. Standard product Manufacturer Socket HIF3BA-20D-2.54R Hirose Electric I/O Cable (sold separately) CO20-HP□-L, CO20-HP□-R Autonics Control Output Circuit NPN open collector output PNP open collector output +V +V OUT2 Output short over current protection circuit ※2 Load ※1 ※3 DI(input) DI(0V) 0V + 12-24VDC - Main circuit Main circuit Output short over current protection circuit Output short over current protection circuit Load ※1 OUT1 Output short over current protection circuit OUT1 + 12-24VDC - ※1 Load ※1 OUT2 ※2 RS485(A+) DI(input) RS485(B-) DI(0V) ※3 RS485(A+) Load RS485(B-) 0V ※2: It is only for the digital input option model (PSM ※1: PSM4: 4 of each OUT1/OUT2. D). ※3: It is only for the RS485 communication option model (PSM PSM8: 8 of each OUT1/OUT2. R). ※If short-circuit the control output terminal or supply current over the rated specification, normal control signal is not output due to the output short over current protection circuit. Installation ※Insert this unit into a panel, fasten bracket by pushing with tools as shown. G-48 -|Transparent setting guide|- Multi-CH Pressure Sensor Indicator Unit Descriptions 1. Present value (PV) display part (red or green) RUN mode: Displays the measured value of the current channel. Setting mode: Displays the set parameter name. 2. Setting value (SV) display part (green) RUN mode: Displays the pressure unit of the current channel. Setting mode: Displays SV of the parameter. 3. Channel display part (red) RUN mode: Displays the channel. Setting mode: Displays the channel of the setting parameter. 4. Output indicator (OUT1 (red), OUT2 (green)) Turns ON when the dedicated control output is ON. PSM4: OUT1/OUT2 of 4 channels PSM8: OUT1/OUT2 of 8 channels 1 3 4 2 5 6 7 8 5. SENSORS CONTROLLERS MOTION DEVICES SOFTWARE M Key Sets preset value, enters parameter 1/2 group, moves between parameters or returns to RUN mode. 6. Key RUN mode: Changes the currently displayed channel. Setting mode: Changes the setting channel or moves between digits. 7. Key Setting mode: Changes SV from each parameter. 8. Key RUN mode: Enters peak value/auto shift correction value parameters. Setting mode: Changes SV from each parameter. Connections Sensor connector input It is recommended to use Autoncis sensor connector CNE-P04PIN no. (A) Photoelectric Sensors (B) Fiber Optic Sensors (sold separately). (C) LiDAR Type Voltage (1-5VDC) input INPUT 0V ※2 TYPE +V Current (DC4-20mA) input 4 3 N·C 2 1 ※1: Dot line parts are only for PSM8 Series. ※2: No.2 pin is for auto pressure sensor model identification. Wire it only for using Autonics pressure sensor, PSS Series (sold separately). Refer to the PSS series catalog. ※1 (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors Hirose connector (HIF3FB-20PA-2.54DSA) 20-pin PIN no. 2 Type 0V PIN no. 1 Type 12-24VDC 4 6 8 10 12 14 16 18 20 DI(0V)/ Ch4_OUT2 Ch4_OUT1 Ch3_ OUT2 Ch3_OUT1 Ch2_OUT2 Ch2_OUT1 Ch1_OUT2 Ch1_OUT1 RS485(B-) 19 3 5 7 9 11 13 15 17 DI(input)/ Ch8_OUT2 Ch8_OUT1 Ch7_OUT2 Ch7_OUT1 Ch6_OUT2 Ch6_OUT1 Ch5_OUT2 Ch5_OUT1 RS485(A+) No. 19, 20 pins are sub I/O pins and support digital input function (DI) or RS485 communication by option. Zero-Point Adjustment ※Before using this unit, you must execute zero-point adjustment. 1. 2. for over 4 sec  ith opening pressure ports of pressure sensors, this function is to set zero-point for the W current pressure display value forcibly. + Press the keys for over 4 sec at the same time, the value of PV display part flashes twice as 00)0 and zero-adjustment is complete. You can set the applied channel range for this function at zero-point adjustment channel range [ZeRS] in parameter 2 group. ※Zero-point adjustment allowable range: max. ±5% of rated pressure. ●[ RsCH]: Executes zero-point adjustment only for current channel. ●[ RsAL]: Executes zero-point adjustment for all channels. If there is external pressure and executing zero-point adjustment, [ERR1] flashes during pressing the keys. Remove the external pressure and re-execute zero-point adjustment at atmospheric pressure. G-49 (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets -|Transparent setting guide|- PSM Series Settings Zero-point adjustment ※1 M for less than Preset settings 2 sec M for over 2 sec Parameter 1 group + + for over 4 sec Manual return for freezer control output M + RUN mode M for over 3 sec ※2 + + for over 5 sec M for over 4 sec Parameter 2 group M for over 3 sec M Channel change M for over 2 sec ※3 High peak value check Parameter reset Low peak M value check Auto shift correction ※4 value check ※1: When using forced output control mode, auto shift/hold input functions are not available. There is no preset setting function. ※2: It executes this function when more than one channel's output operation mode [OUtM] is freezer pressure control [FRZE] and its control output 2 reset is manual [MAN]. ※3: Press the + keys for over 1 sec to reset high/low peak value or auto shift correction value. ※4: You can check it only when digital input function [D-IN] set as Auto shift function [SHFT]. Parameter Setting ※After entering parameter 1/2 group, if there is no additional key input for 30 sec, it maintains previous setting value and it returns to RUN mode. ※Press the , key to set the setting value. ※After entering parameter 1/2 group, press the M key for over 3 sec to at any parameters return to RUN mode. ※Dot line parameters may not be displayed by other parameter settings. Parameter 1 group ※Parameters in parameter 1 group are settable for each channel. (refer to ' Channel Changing and Setting') RUN mode M 2 sec for over 3 sec Parameter 1 group M M Auto pressure sensor model identification When connecting Autonics pressure sensor, PSS Series, it sets pressure model automatically. ※Auto identification method : Set as [ON] → Turn PSM power OFF→ Connect PSS→ Turn PSM power ON M Input display Standard Scale Select display method for measured input. M Pressure type Standard pressure (standard) Standard pressure (lower) Negative pressure Compound pressure M ※Displays when input display [DISP] is set as [STND]. Display unit Pressure Unit Standard (standard) kPa [KPA], kgf/cm2 [KGF], bar [BAR], psi [PSI], MPa [MPA] M Standard (lower) kPa [KPA], kgf/cm2 [KGF], bar [BAR], psi [PSI] Negative kPa [KPA], kgf/cm2 [KGF], bar [BAR], psi [PSI], mmHg [MMHG], inHg [INHG], mmH2O [H2O] Compound Scale decimal point position M ※Displays when input display [DISP] is set as [SCAL]. G-50 -|Transparent setting guide|- Multi-CH Pressure Sensor Indicator Low limit scale value SENSORS Set the display value for analog input 1VDC or DC4mA. ※Displays when input display [DISP] is set as [SCAL]. Setting range: -1999 to 9999 (decimal point of setting range is depending on scale decimal point position [DOT] setting.) M High limit scale value Set the display value for analog input 5VDC or DC20mA. CONTROLLERS MOTION DEVICES M Output operation mode Window comparison output Hysteresis Hysteresis-Window comparison output Freezer pressure control Automatic sensitivity setting SOFTWARE Forced output control M Parameter Output type M Auto shift applied range Parameter ShOT OUT1 output OUT2 output Normally Open Normally Open Normally Closed Normally Closed Normally Open Normally Closed Normally Open Normally Closed (A) Photoelectric Sensors (B) Fiber Optic Sensors Setting range (C) LiDAR Applies OUT1 of the channel. Applies OUT2 of the channel. M Applies OUT1+OUT2 of the channel. (D) Door/Area Sensors Applies OUT1+OUT2 of all channels. ALL ※Displays when digital input terminal [D-IN] is set as [SHFT] in parameter 2 group. (E) Vision Sensors Parameter 2 group ※Parameters in parameter 2 group are applied to all channels. (F) Proximity Sensors RUN mode M for over 3 sec M 4 sec (G) Pressure Sensors Parameter 2 group (H) Rotary Encoders M Channel copy PSM4 PSM8 Origianl CH--Subject CH Original CH 1, 2, 3, 4 1, 2, 3, 4, 5, 6, 7, 8 (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets Subject CH 1, 2, 3, 4, ALL 1, 2, 3, 4, 5, 6, 7, 8, ALL M Response time M PSM4 PSM8 2.5 100 500 1000 5 100 500 1000 Change response time of control output and pressure display value to prevent output chattering. When response time is longer, the number of digital filters is increased for stable display. Digital input terminal function Auto shift Hold The channel All channels Manual return for freezer control output M Digital input applied channel range ※Displays for digital input option model. M G-51 -|Transparent setting guide|- PSM Series Zero-point adjustment applied channel range The channel All channels The channel All channels M Peak value reset applied channel range M Channel auto change cycle ※unit: sec M Energy save ※Saves energy to turn OFF the front except output indicators when there is no operation for over 1 min in RUN mode. M PV display color Parameter M Status Parameter Status Normal Output Normal Output Red Green Green Red Red Red Green Green Communication address ※Setting range: 1 to 127 M Communication speed ※Setting range: 24, 48, 96, 192, 384 ※Multiply the display value by 100. (unit: bps) M Communication parity bit M Communication stop bit M Communication response wait time ※Setting range: 5 to 99 (unit: ms) M Communication write M Parameter reset ※Be sure that all SVs are reset. M Lock M G-52 Parameter Function OFF LOC1 LOC2 Unlock All lock Locks parameter setting, Preset value change, zero-point adjustment and peak values, auto shift correction value reset are available. -|Transparent setting guide|- Multi-CH Pressure Sensor Indicator High/Low Peak Value, Auto Shift Value Check ※1 SENSORS CONTROLLERS M M for over 2 sec MOTION DEVICES High peak value SOFTWARE Low peak value Auto shift correction value M ※1: It displays only when digital input terminal function [D-IN] is [SHFT] in parameter 2 group. ※Press the + keys for over 1 sec, "----" of the SV display part flashes twice and saved value is reset. ※This function is to diagnose malfunction of the system caused by parasitic pressure through memorizing the High/Low peak value occurred from the system. ※When digital input terminal function [D-IN] is [SHFT] in parameter 2 group, you can check and correct auto shift correction value at [ShIN]. ※Press the key for over 2 sec to check high/low peak value, auto shift correction value of current channel in RUN mode. Press the key to change the channel. Auto Pressure Sensor Model Identification[ AtSC] When connecting Autonics pressure sensor, PSS Series, this unit recognizes pressure model [IN-T] in parameter 1 group and pressure range automatically. ※Auto identification method : Set auto pressure sensor model identification [AtSC] as [ON] → Turn PSM power OFF → Connect PSS → PSM power ON ※This function is only for Autonics pressure sensor, PSS Series. ※Turn OFF the PSM power and connect PSS. Otherwise, it may cause malfunction. Channel Changing and Setting Channel change ● Manual channel changing: Press the key in RUN mode. The SV display part changes channel and the PV display part displays the value of this channel. ● Auto channel changing: It displays only connected channels. It displays one of the connected channels and the next channel for the set time (2 or 5 sec) automatically. ※In auto channel changing, when pressing the key to change channel, it displays the value of this channel for 30 sec and it displays the next channel automatically. Channel setting Parameter 1 group is available to set for each channel. Press the key once, channel is changed for the parameter. E.g.)To set auto pressure sensor model identification [AtSC], and input display [DISP] at CH1, 2, 3 in parameter 1 group. CH2.auto pressure sensor model identification changes channel M M CH2. input display changes channel CH3.auto pressure sensor model identification changes channel M CH1. input display (B) Fiber Optic Sensors (C) LiDAR (D) Door/Area Sensors (E) Vision Sensors (F) Proximity Sensors ※Manual channel changing: Set channel auto change cycle [AtCH] as [OFF] in parameter 2 group. ※Auto channel changing: Set channel auto change cycle [AtCH] as [2] or [5] in parameter 2 group. CH1.auto pressure sensor model identification (A) Photoelectric Sensors CH3. input display changes channel G-53 (G) Pressure Sensors (H) Rotary Encoders (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets -|Transparent setting guide|- PSM Series Preset Setting ※The example is based on standard pressure, kPa. Hysteresis mode [HYsM] M M Pressure detection level 1 ST1 0500 M [Setting range] Min. display pressure
PSM4-AR 价格&库存
很抱歉,暂时无法提供与“PSM4-AR”相匹配的价格&库存,您可以联系我们找货
