PSS-1V-R1/8
PSS-1V-R1/8
    AUTONICS(奥托尼克斯)
    Module
    PRESSURE SENSOR R1/8 12-24V
PSS-1V-R1/8 数据手册
PSS Series Compact, Non-indicating Pressure Sensors Features ● Rated pressure : negative pressure (-101.3 to 0.0kPa) standard pressure (0 to 100.0kPa, 0 to 1,000kPa) compound pressure (-101.3 to 100.0kPa) ● Compact design: W11.8×H29.3×L24.8mm (including pressure port) ● Analog output: Voltage (1-5VDC), current (DC4-20mA) ● Power supply: 12-24VDC ±10% Please read “Safety Considerations” in the instruction manual before using. Ordering Information PS S V 01 V R1/8 Pressure port Output Pressure range Pressure type Size Item R1/8 Standard V A Voltage (1-5VDC) output Current (DC4-20mA) output 01 1 100kPa 1,000kPa No-mark V C Standard pressure type Negative pressure type Compound pressure type S Small (W11.8×H29.3×L24.8mm) PS Pressure Sensor Specifications Pressure type Gauge pressure Negative pressure Standard pressure Compound pressure PSS-V01V-R1/8 PSS-01V-R1/8 PSS-1V-R1/8 PSS-C01V-R1/8 PSS-V01A-R1/8 PSS-01A-R1/8 PSS-1A-R1/8 PSS-C01A-R1/8 0.0 to -101.3kPa 0.0 to 100.0kPa 0 to 1,000kPa -101.3 to 100.0kPa 5.0 to -101.3kPa -5.0 to 110.0kPa -50 to 1,100kPa -101.3 to 110.0kPa 2 times of rated pressure 2 times of rated pressure 1.5 times of rated pressure 2 times of rated pressure Air, non-corrosive gas 12-24VDCᜡ ±10% (ripple P-P: Max. 10%) Voltage output type: Max. 15mA, Current output type: Max. ±0.3% F.S. Reverse polarity protection circuit •Output voltage: 1-5VDCᜡ ±2% F.S. •Linear: Max. ±1% F.S. •Output impedance: 1kΩ •Output current: DC4-20mA ±2% F.S. •Linear: Max. ±1% F.S. Voltage output Current output Rated pressure range Analog output range Max. pressure range Applied fluid Power supply Current consumption Effect by power supply Protection circuit Analog Voltage output output Current output Temp. characteristics of Max. ±2% F.S. of output voltage/current at 25℃ within temperature range 0 to 50℃ analog output Insulation resistance Over 50MΩ (at 500VDC megger) Dielectric strength 2000VAC 50/60Hz for 1 minute Vibration 1.5mm amplitude at frequency of 10 to 55Hz in each X, Y, Z direction for 2 hours Ambient temp. 0 to 50℃, storage: -10 to 60℃ Environment Ambient humi. 35 to 85%RH, storage: 35 to 85%RH Protection structure IP40 (IEC standard) Material Front, Rear case: Polycarbonate, Pressure port: Nickel plated brass Cable Ø3, 4-wire, 3m (AWG28, Core diameter: 0.08mm, Number of cores: 19, Insulator out diameter: Ø0.88mm) Sold separately Sensor connector wire mount plug (CNE-P04- )※1 Approval Weight※2 Approx. 60g (approx. 26g) ※1: For more information about sensor connector wire mount plug, refer to 'Connectors' and 'Sockets' chapters. ※2: The weight includes packaging. The weight in parenthesis is for unit only. ※F.S.: Rated pressure. ※Environment resistance is rated at no freezing or condensation. Model G-44 Compact, Non-indicating Pressure Sensor Dimensions (unit: mm) SENSORS CONTROLLERS 11.8 19.8 5 12.8 MOTION DEVICES SOFTWARE 16.5 Inside M5 Tap 12 (A) Photoelectric Sensors Connections ● Voltage (1-5VDC) output type ● Current (DC4-20mA) output type (Brown)+V (Black) Voltage (1-5VDC) output (White) Pressure sensor model ※2 recognition (White) Pressure sensor model ※2 recognition 12-24VDC Load (B) Fiber Optic Sensors ※1 (Brown)+V Main circuit Main circuit Ø3, 3m R1/8" (C) LiDAR 12-24VDC (Black)N.C (E) Vision Sensors ※1 (Blue)GND (D) Door/Area Sensors Load (Blue)0V/Current (DC4-20mA) output (F) Proximity Sensors ※1 : Load can be connected any directions. ※2 : Pressure sensor model is automatically recognized only by Autonics PSM Series, Multi-CH Pressure and Sensor indicator. ※Allowable load impedance: Max. 100Ω for 12VDC power, Max. 500Ω for 24VDC power ※The product is not equipped with the output short over current protection circuit. If short-circuit the control output terminal or supply current over the rated specification, it may result in product damage. (G) Pressure Sensors (H) Rotary Encoders Proper Usage Do not insert any sharp or pointed object into pressure port. Failure to follow this instruction may result in malfunction and damage the sensor. Be sure that this unit must avoid direct touch with water, oil, thinner etc. It is ready to operate 3 sec after it is turned ON. Be sure not to use the product within 3 sec. When using switching mode power supply, frame ground (F.G.) terminal of power supply should be grounded. To avoid inductive noise, keep the wiring away from power line, high voltage line. Failure to follow this instruction may result in malfunction. When moving this unit from warm place to cold place, please remove the humidity on the cover then use it. Do not use spanner to mounting this unit. + Tightening torque for one touch fitting should be below 10N·m. Switching Do not apply a tensile strength in excess of 30N to the cables Mode Power or connector. Supply F.G. This product may be used in the following environments. Indoors Altitude max. 2,000m Pollution degree 3 Installation category II (I) Connectors/ Connector Cables/ Sensor Distribution Boxes/ Sockets G-45
PSS-1V-R1/8
物料型号:TI公司的LM358芯片。
器件简介:LM358是一款具有高电压摆幅的双运算放大器,具有8引脚和14引脚封装形式,广泛应用于需要高输入阻抗和低输出阻抗的场合。
引脚分配: - 8引脚封装:引脚1(非反相输入),引脚2(反相输入),引脚3(输出),引脚4(V+),引脚5(GND),引脚6(反相输入),引脚7(非反相输入),引脚8(V+)。 - 14引脚封装:除了8引脚的功能外,还包含引脚9(输出),引脚10(V+),引脚11(GND),引脚12(反相输入),引脚13(非反相输入),引脚14(V+)。
参数特性:包括电源电压范围(±3V~±32V)、输入偏置电流(100nA)、开环增益(100dB)、单位增益带宽(1MHz)等。
功能详解:详细解释了LM358的工作原理、应用电路和设计考虑。
应用信息:适用于音频放大、信号调节、传感器信号放大等多种应用场景。
PSS-1V-R1/8 价格&库存
很抱歉,暂时无法提供与“PSS-1V-R1/8”相匹配的价格&库存,您可以联系我们找货
