RXT-F01
RXT-F01
    INDUSTRIALEMART
    RELAY TERMINAL BLOCK FOR TF-1C
RXT-F01 数据手册
RXT Series Relay Terminal Blocks TF-1c Ordering Information RXT -  Dimensions F01  Description Q01 Relay Specifacations (TF-1c) Contact Form Contact Material Maximum Contact Resistance Contact Rated Current ( Resistance Load ) Ratings Maximum DC Contact Capacity AC Maximum Rated Voltage Minimum Switching Current Coil Voltage Coil Consumption Coil Ratings Minimum Pick Up Voltage Maximum Drop-Out Voltage Operating Pick-up Time Drop-out Insulation Resistance Dielectirc Btwn Contacts and Coil Strength Btwn Contacts Mechanical General Life Cycles Ratings Electrical Vibration Resistance Ambient Temperature Ambient Humidity Weight Approval 1N/O + 1N/C Silver Alloy 30mΩ 6A 250VAC , 6A 30VDC 180W 1500VA 6A 250VAC 1mA 5VDC 5V 12V 24V 170mW 24VDC 70% of Nominal Voltage 5% of Nominal Voltage 8ms 4ms 100MΩ 4000VAC 1 minute 1000VAC 1 minute Min. 10,000,000 Min. 100,000 10Hz to 55HZ 1mm DA -40°C to 85°C 5% to 85% RH Approx. 3g CE , VDE , UL RXT-QS (Jumper) 111 unit: mm
RXT-F01 价格&库存
很抱歉,暂时无法提供与“RXT-F01”相匹配的价格&库存,您可以联系我们找货
