SRS1-B1203-1
SRS1-B1203-1
    AUTONICS(奥托尼克斯)
    SSR RELAY SPST-NO 3A 90V-240V
SRS1-B1203-1 数据手册
SRS1 Series Single-Phase, Socket Type SSR Features ● Socket type for easier installation and maintenance - SRS1-A: Autonics socket SK-G05 (AC, DC, AC/DC) - SRS1-B: Universal LY2 sockets (AC) - SRS1-C: Universal MY4 sockets (AC, DC, AC/DC) ● Dielectric strength: 2500 VAC ● Zero cross turn-on, random turn-on models available ● Input indicator (red LED) SRS1-A SRS1-B Please read “Safety Considerations” in the instruction manual before using. SRS1-C Ordering Information SRS 1 - B 1 2 02 R - 2 Number of output circuits 1 2 Function SRS1-A SRS1-B SRS1-C Rated input voltage SRS1-A SRS1-B, SRS1-C Socket Control phase Item ※1: In case of SRS1-C1D102-1, SRS1-C1X201-1, rated input voltage is 4-24VDC. K-40 2 No mark Zero cross turn-on Rated load current (resistive load) Rated load voltage 1 R Random turn-on 01 1A 02 2A 03 3A 05 5A 2 24-240VAC D1 5-100VDC D2 5-200VDC X2 5-240VAC/5-200VDC (universal) 2 90-240VAC 2 90-240VAC D1 5-100VDC X2 5-240VAC/5-200VDC (universal) 1 4-24VDC 1 4-30VDC A Autonics socket (Model: SK-G05) B Universal LY2 socket C Universal MY4 socket 1 Single-phase SRS Solid State Relay (socket type) ※1 Single-Phase, Socket Type SSR Model SRS1-A SRS1-B SRS1-C Rated input voltage SRS1-A1202 SRS1-A1202R SRS1-A1203 SRS1-A1203R SRS1-A1205 SRS1-A1205R SRS1-A1D101 SRS1-A1D102 SRS1-A1D201 SRS1-A1X201 SRS1-B1202-2 SRS1-B1202R-2 SRS1-B1203-1 SRS1-B1203R-1 SRS1-B1205-1 SRS1-B1205R-1 SRS1-C1202-2 SRS1-C1202R-2 SRS1-C1203-1 SRS1-C1203R-1 SRS1-C1205-1 SRS1-C1205R-1 SRS1-C1D102-1 SRS1-C1X201-1 Rated load current Rated load voltage Function Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on 2A 3A 4-24VDCᜡ 24-240VACᜠ 5A 1A 2A 5-100VDCᜡ 1A 5-200VDCᜡ 5-240VACᜠ/5-200VDCᜡ 3A 90-240VACᜠ 2A (consists of 2 circuits) 3A 90-240VACᜠ 5A 2A 1A 4-24VDCᜡ SOFTWARE Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on Zero cross turn-on Random turn-on 5A 4-30VDCᜡ CONTROLLERS MOTION DEVICES 2A (consists of 2 circuits) 4-30VDCᜡ SENSORS 5-100VDCᜡ 5-240VACᜠ/5-200VDCᜡ (J) Temperature Controllers (K) SSRs (L) Power Controllers - (M) Counters Specifications (N) Timers Input Series SRS1-A SRS1-B SRS1-C1202(R)-2/ SRS1-C1203(R)-1/ SRS1-C1205(R)-1 SRS1-C1D102-1/ SRS1-C1X201-1 Rated input voltage range 4-24VDCᜡ 4-30VDCᜡ 4-30VDC ᜡ 4-24VDCᜡ Allowable input voltage range 4-26.4VDCᜡ 4-32VDCᜡ 4-32VDCᜡ 4-26.4VDCᜡ Max. input current 15mA (Random turn-on) 13mA (Random turn-on) 13mA (Random turn-on) 15mA Pick-up voltage Min. 4VDCᜡ Drop-out voltage Max. 1VDCᜡ (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units Output (AC) SRS1-A1202(R) Rated load voltage range 24-240VACrmsᜠ (50/60Hz) 90-240VACrmsᜠ (50/60Hz) Allowable load voltage range 24-264VACrmsᜠ (50/60Hz) 90-264VACrmsᜠ (50/60Hz) Rated load current 2Arms 3Arms Min. load current 0.15Arms 0.2Arms 0.15Arms Max. 1cycle surge current (60Hz) 126A 250A 126A 250A Max. non-repetitive surge current (I2t, t=8.3ms) 65A2s 400A2s 65A2s 220A2s Peak voltage (non-repetitive) 600V Leakage current (Ta=25℃) Max. 2mArms (240VACᜠ/60Hz) Output on voltage drop[Vpk] (max. load current) Max. 1.6V Static off-state dv/dt 500V/㎲ Turn-on Zero cross turn-on time Random turn-on Max. 0.5 cycle of load source + 1ms Turn-off time Max. 0.5 cycle of load source + 1ms Resistive load ※1 (AC-51) SRS1-A1203(R) SRS1-A1205(R) SRS1-B1202(R)-2/ SRS1-B1203(R)-1/ SRS1-B1205(R)-1/ SRS1-C1202(R)-2 SRS1-C1203(R)-1 SRS1-C1205(R)-1 Model 5Arms 2Arms 3Arms (S) Sensor Controllers (T) Switching Mode Power Supplies 5Arms (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices Max. 1ms ※1: AC-51 is utilization category at IEC 60947-4-3. K-41 SRS1 Series Specifications Output (DC, AC/DC) SRS1-A1D101 Model SRS1-A1D102 SRS1-A1D201 SRS1-C1D102-1 SRS1-A1X201 SRS1-C1X201-1 Rated load voltage range 5-100VDCᜡ 5-200VDCᜡ 5-100VDCᜡ 5-240VACrmsᜠ (50/60Hz) / 5-200VDCᜡ Allowable load voltage range 3-120VDCᜡ 3-220VDCᜡ 3-120VDCᜡ 3-264VACrmsᜠ (50/60Hz) / 3-220VDCᜡ 2Adc 1Adc 2Adc 1Arms/1Adc 10A 4A 10A Rated load current Resistive load 1Adc ※1 (AC-51) Min. load current 10mA Max. surge current (t=10ms) 5A 10mA Leakage current Max. 100μA Max. 2mArms Output on voltage drop[Vpk] (max. load current) Max. 1.1V Max. 2.2V Static off-state dv/dt 500V/㎲ Turn-on time Max. 1ms Turn-off time Max. 1ms Max. 2ms Max. 1ms 4A Max. 2mArms (240VACᜠ/60Hz) - 500V/㎲ - Max. 1ms Max. 2ms Max. 1ms ※1: AC-51 is utilization category at IEC60947-4-3. General specifications Series SRS1-A Dielectric strength (Vrms) 2,500VAC 50/60Hz 1 min (input-output, input/output-case) SRS1-B SRS1-C Insulation resistance Over 100MΩ (at 500VDC megger) Indicator Input indicator: red LED -20 to 70℃, storage: -30 to 100℃ -20 to 80℃, storage: -30 to 100℃ Environ Ambient temperature (The rated load current capacity is different depending on ambient temperature. Refer to ‘ SSR Derating Curve’.) -ment Ambient humidity 45 to 85%RH, storage: 45 to 85%RH Protection IP10 (Protection structure of socket, According to protection of the universal According to protection of the universal SK-G05) LY2 socket MY4 socket Approval ᜢᜧ Weight ※1 - Max. 3A: approx. 270g (approx. 17g) 5A: approx. 380g (approx. 28g) Approx. 400g (approx. 30g) Approx. 400g (approx. 30g) ※1: The weight is per 10 units with packing and the weight of parenthesis is per 1 unit. ※Environment resistance is rated at no freezing or condensation. Dimensions (unit: mm) 13 29 5.4 4-5 L 4-0.5 SRS1-A Input indicator (red) 4-Ø3 L K-42 Max. 3A 5A 28 38 Single-Phase, Socket Type SSR Dedicated socket for SRS1-A: SK-G05 (sold separately) 82.2 73.5 90.2 82.4 SENSORS 17.6 CONTROLLERS MOTION DEVICES 2-Ø4.5 SOFTWARE Panel cut-out 54.7 82.4 (J) Temperature Controllers (K) SSRs 35mm DIN rail (L) Power Controllers SRS1-B 21 6.5 (M) Counters 8-0.5 34.5 (N) Timers 8-5 27 Input indicator (red) (O) Digital Panel Meters (P) Indicators 8-Ø3 (Q) Converters SRS1-C 6.5 (R) Digital Display Units 21 8-0.5 34.5 (S) Sensor Controllers Input indicator (red) 27 (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices 8-2.6 8-R0.6 K-43 SRS1 Series Connections SRS1-A SRS1-A1202(R)/SRS1-A1203(R)/ SRS1-A1205(R) ※SRS1-A1202(R) : 240VAC 2A RESISTIVE LOAD SRS1-A1203(R) : 240VAC 3A RESISTIVE LOAD SRS1-A1205(R) : 240VAC 5A RESISTIVE LOAD 3 4 5 1 INPUT : 4-24VDC SRS1-A1X201 ※SRS1-A1D101 : 100VDC 1A RESISTIVE LOAD SRS1-A1D102 : 100VDC 2A RESISTIVE LOAD SRS1-A1D201 : 200VDC 1A RESISTIVE LOAD 3 4 5 1 INPUT : 4-24VDC ※SRS1-A1X201 : 200VDC 1A RESISTIVE LOAD : 240VAC 1A RESISTIVE LOAD 3 4 5 SRS1-A1D101/SRS1-A1D102/ SRS1-A1D201 1 INPUT : 4-24VDC SRS1-B SRS1-B1202(R)-2 2 4 1 3 6 8 5 7 ※SRS1-B1202(R)-2 : 240VAC 2A RESISTIVE LOAD SRS1-B1203(R)-1/SRS1-B1205(R)-1 2 4 1 3 6 8 5 7 ※SRS1-B1203(R)-1 : 240VAC 3A RESISTIVE LOAD SRS1-B1205(R)-1 : 240VAC 5A RESISTIVE LOAD INPUT : 4-30VDC INPUT : 4-30VDC SRS1-C SRS1-C1202(R)-2 SRS1-C1203(R)-1/SRS1-C1205(R)-1 ※SRS1-C1202(R)-2 : 240VAC 2A RESISTIVE LOAD INPUT : 4-30VDC INPUT : 4-30VDC SRS1-C1D102-1/SRS1-C1X201-1 ※SRS1-C1D102-1 : 100VDC 2A RESISTIVE LOAD SRS1-C1X201-1 : 200VDC 1A RESISTIVE LOAD : 240VAC 1A RESISTIVE LOAD INPUT : 4-24VDC K-44 ※SRS1-C1203(R)-1 : 240VAC 3A RESISTIVE LOAD SRS1-C1205(R)-1 : 240VAC 5A RESISTIVE LOAD Single-Phase, Socket Type SSR Example of Connection SRS1-A SENSORS AC Load (SRS1-A1202(R)/SRS1-A1203(R)/SRS1-A1205(R)) 5/+ 4-24VDC + SRS1 Input Output 1/- Load 3 Varistor ※1 Rapid fuse CAP ※2 ※1: Must use a Varistor (470V, 0.6W) Load ※2: When connecting capacitor as source above, it is appropriate for EMC. (AC) CAP: 1μF/250VAC ~ 4 DC Load (SRS1-A1D101/SRS1-A1D102/SRS1-A1D201) 5/+ 4-24VDC + - SRS1 Input 1/- SOFTWARE Varistor ※1 Load ※1: Must use a Varistor (SRS1-A1D101/SRS1-A1D102: source 270V, 0.6W) - (DC) (SRS1-A1D201: 470V, 0.6W) + Rapid fuse 4/- AC/DC Load (SRS1-A1X201) 5/+ 4-24VDC + - SRS1 Input (J) Temperature Controllers Load 3 Output Varistor ※1 Load source (AC) ~ Rapid fuse 1/- 4 + - (K) SSRs Load source + (DC) - (L) Power Controllers ※1: Must use a Varistor (470V, 0.6W) (M) Counters SRS1-B 8/+ 4-30VDC + - SRS1 Input Load 6 Output Varistor ※1 Rapid fuse CAP ※2 ※1: Must use a Varistor (470V, 0.6W) Load ※2: When connecting capacitor as source above, it is appropriate for EMC. (AC) CAP: 1uF/250VAC ~ 4 7/- AC Load (SRS1-C1202(R)-2/SRS1-C1203(R)-1/SRS1-C1205(R)-1 14/+ 4-30VDC SRS1 Input Output (Q) Converters Varistor ※1 Rapid fuse CAP ※2 Load source (AC) ~ 12 ※1: Must use a Varistor (470V, 0.6W) ※2: When connecting capacitor as above, it is appropriate for EMC. CAP: 1μF/250VAC DC Load (SRS1-C1D102-1) 14/+ + - SRS1 Input Varistor ※1 Load source - (DC) Rapid fuse ※1: Must use a Varistor (270V, 0.6W) AC/DC Load (SRS1-C1X201-1) 14/+ 4-24VDC - Input Output Varistor ※1 ~ Rapid fuse 13/- 12 (V) HMIs (W) Panel PC Load 8 (S) Sensor Controllers (U) Recorders + 12/- SRS1 (R) Digital Display Units (T) Switching Mode Power Supplies Load 8/+ Output 13/- + (O) Digital Panel Meters Load 8 13/- 4-24VDC (N) Timers (P) Indicators SRS1-C + MOTION DEVICES Load 3/+ Output CONTROLLERS Load source (AC) + - (X) Field Network Devices Load source + (DC) - ※1: Must use a Varistor (470V, 0.6W) K-45 SRS1 Series SSR Derating Curve SRS1-A SRS1-A1205(R) 5 4 SRS1-A1203(R) 3 SRS1-A1202(R) 2 SRS1-A1D102/SRS1-A1D101/ SRS1-A1D201/SRS1-A1X201 Load current[A] Load current[A] SRS1-A1202(R)/SRS1-A1203(R)/ SRS1-A1205(R) SRS1-A1D102 2 SRS1-A1D101 1 SRS1-A1D201/A1X201 0.6 1 0.7 0.5 0.3 0.2 0 10 20 30 40 50 60 70 80 Ambient temperature [℃] 0 10 20 30 40 50 60 70 80 Ambient temperature [℃] Load current[A] SRS1-B SRS1-B1205(R)-1 5 4 SRS1-B1203(R)-1 3 SRS1-B1202(R)-2 2 1.6 1 0.7 0 10 20 25 30 40 50 60 70 80 90 Ambient temperature [℃] SRS1-C SRS1-C1205(R)-1 5 4 3 2 1.6 1 0.7 SRS1-C1203(R)-1 SRS1-C1202(R)-2 SRS1-C1D102-1/SRS1-C1X201-1 Load current[A] Load current[A] SRS1-C1202(R)-2/SRS1-C1203(R)-1/ SRS1-C1205(R)-1 2 SRS1-CD102-1 1 0.6 SRS1-C1X201-1 0.3 0.2 0 10 20 25 30 40 50 60 70 80 90 Ambient temperature [℃] 0 10 20 30 40 50 60 70 80 Ambient temperature [℃] Since effectiveness of the heat radiation is decreased when multiple SSRs are installed closely, please supply less than 50% of the rated load current. ※Above SSR derating curves obtained approval from the UL certification authority. K-46 Single-Phase, Socket Type SSR Proper Usage Cautions during use SENSORS 1. Follow instructions in ‘Cautions during Use’. Otherwise, it may cause unexpected accidents. 2. 4-24VDC, 4-30VDC signal input should be insulated and limited voltage/current or Class 2, SELV power supply device. 3. Install the unit in the well ventilated place. 4. While supplying power to the load or right after turning off the power of the load, do not touch the body. Failure to follow this instruction may result in a burn due to the high temperature. 5. In order to protect the product from the short-circuit current of the load, use rapid fuse of which I2t is under the 1/2 of SSR I2t. When short-circuited, replace the fuse to those of same specification with the used rapid fuse. 6. Install dummy resistance in parallel with the load, to keep the sum of current flowing in the load and dummy resistance being over SSR minimum load current. 7. When using random turn-on model for phase control, install noise filter between the load and the power of the load. 8. Do not use near the equipment which generates strong magnetic force or high frequency noise. 9. This unit may be used in the following environments. ① Indoors (in the environment condition rated in ‘Specifications’) ② Altitude max. 2,000m ③ Pollution degree 2 ④ Installation category II CONTROLLERS MOTION DEVICES SOFTWARE (J) Temperature Controllers (K) SSRs (L) Power Controllers (M) Counters (N) Timers (O) Digital Panel Meters (P) Indicators (Q) Converters (R) Digital Display Units (S) Sensor Controllers (T) Switching Mode Power Supplies (U) Recorders (V) HMIs (W) Panel PC (X) Field Network Devices K-47
SRS1-B1203-1 价格&库存
很抱歉,暂时无法提供与“SRS1-B1203-1”相匹配的价格&库存,您可以联系我们找货
