T3S-B4RJ2C
T3S-B4RJ2C
    AUTONICS(奥托尼克斯)
    TEMP CONTROL J 200C 100-240VAC
T3S-B4RJ2C 数据手册
T3 / T4 Series Thumbwheel Switch Setting Type Thumbwheel Switch Setting Type Temperature Controller (A) Photoelectric Sensors Features (B) Fiber Optic Sensors Various size as DIN specifications (W48×H48, W48×H96, W72×H72, W96×H96mm) Various control output (Relay/SSR drive/current) Dual setting for simultaneous control for heater and cooler (T4LP) (C) Door/Area Sensors (D) Proximity Sensors Please read “Safety Considerations” in operation manual before using. (E) Pressure Sensors Ordering Information T 3 S B 4 R P 4 C N (F) Rotary Encoders New ※1 Temperature unit Temperature range Input type Control output ※4 ※4 ※3 Power supply Control method Alarm/Sub output ※3 Size Digit Item (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets N New type C ℃ F ℉ 0 -99 to 199℃, -99.9 to 199.9℃ 1 0 to 99.9℃ 2 0 to 200℃, 0 to 200.0℃ 4 0 to 400℃ 8 0 to 800℃/℉ A 0 to 999℃ C 0 to 1200℃ F 600 to 1600℃ P DPt100Ω J J(IC) K K(CA) R R(PR) R Relay output S SSR drive output C Current output 4 100-240VAC 50/60Hz B ON/OFF control, Proportional control No-mark None A Alarm output S Sub output P Dual setting output S DIN W48×H48mm (8-pin plug type) M DIN W72×H72mm H DIN W48×H96mm L DIN W96×H96mm 3 999 (3-digit) 4 9999 (4-digit) T Temperature Controller (H) Temperature Controllers (I) SSRs / Power Controllers (J) Counters (K) Timers (L) Panel Meters (M) Tacho / Speed / Pulse Meters (N) Display Units (O) Sensor Controllers (P) Switching Mode Power Supplies (Q) Stepper Motors & Drivers & Controllers ※2 (R) Graphic/ Logic Panels (S) Field Network Devices (T) Software ※1: Name plate and connections are different from previous T3/T4 Series. ※2: Sockets (PG-08, PS-08(N)) are sold separately. ※3: Output by Series Series Control output Control output+Alarm/Sub output Dual setting output T3S T3H T3HA T3HS T4M T4MA T4L T4LA T4LP H-107 T3 / T4 Series ※4: Input type and temperature range by Series Thermocouples Input type K(CA) J(IC) R(PR) RTD DPt 100Ω Model 0 to 400℃ 0 to 800℃ 0 to 999℃ 0 to 1200℃ 0 to 200℃ 0 to 400℃ 0 to 800℉ 600 to 1600℃ -99.9 to 199.9℃ -99 to 199℃ 0 to 99.9℃ 0 to 200.0℃ 0 to 200℃ 0 to 400℃ Series T3S T3H T3HA T3HS T4M T4MA T4L T4LA T4LP 4 8 A C 2 4 8 F 0 0 1 2 2 4 ※Please contact us for temperature unit ℉ model. Specifications Series Power supply Allowable voltage range Power consumption Display method Character size (W×H) RTD Input type TC RTD Display ※ accuracy 1 TC Relay Control SSR output Current Alarm/Sub/ Dual setting output Sampling period Control method Hysteresis Proportional band Proportional cycle RESET range Mechanical Relay life cycle Electrical Dielectric strength Vibration Insulation resistance Noise immunity Memory retention Ambient temperature Environment Ambient humidity Weight ※3 T3S T3H T3HA T3HS T4M T4MA T4L T4LA T4LP 100-240VACᜠ 50/60Hz 90 to 110% of rated voltage Max. 5VA 7-segment (red) LED method 3.8×7.6mm 6.0×10.0mm 8.0×14.2mm DPt100Ω (Allowable line resistance max.5Ω per a wire) K(CA), J(IC) K(CA), J(IC), R(PR) ●At room temperature (23ºC ± 5ºC): (PV ± 0.5% or ±1ºC, select the higher one) ± 1-digit ●Out of room temperature range: (PV± 0.5% or ±2ºC, select the higher one)± 1-digit ※ OUT1: 250VACᜠ 5A, 30VDCᜡ 5A, 1c, OUT2: 250VACᜠ 2A, 30VDCᜡ 2A, 1c 2 Max. 12VDCᜡ±2V 20mA DC4-20mA (resistive load max. 500Ω) 250VACᜠ 250VACᜠ 2A 1c 250VACᜠ 2A 1c 2A 1a 100ms ON/OFF, Proportional control F.S. 0.5% F.S. 0.2 to 3% variable F.S. 3% F.S. 1 to 10% variable 20 sec F.S. -3 to 3% variable Over 5,000,000 times OUT1: Over 100,000 times, OUT2: Over 200,000 times 2,000VAC 50/60Hz for 1min (between input terminal and power terminal) 0.75mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Over 100MΩ (at 500VDC megger) Square-wave noise by noise simulator (pulse width 1㎲) ±2kV R-phase and S-phase Approx. 10 years (when using non-volatile semiconductor memory type) -10 to 50℃, Storage: -20 to 60℃ 35 to 85% RH, Storage: 35 to 85% RH Approx. 135g Approx. 239g (approx. 95g) (approx. 176g) Approx. 246g (approx. 180g) Approx. 310g (approx. 222g) ※1: In case of the T3S Series and the decimal point display models At room temperature (23ºC±5ºC): (PV ±0.5% or ±2℃, select the higher one)±1-digit Out of room temperature range: (PV ±0.5% or ±3℃, select the higher one)±1-digit ※2: Dual setting output of the T4LP is fixed as relay output and, it is also available as alarm output. ※3: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. H-108 Thumbwheel Switch Setting Type Unit Description (A) Photoelectric Sensors 1 1. Present temperature (PV) display It displays present temperature. 2. Control output (OUT) indicator It turns ON when control output is ON. ※In case of the T3S, the upper DOT of last digit flashes. 3. Alarm output (AL) indicator It turns ON when alarm output is ON. (only for alarm output model) In case of the sub output model (T3HS), the sub (SUB) indicator turns ON when sub output is ON. 4. Set value (SV) thumbwheel switch Switch for setting temperature. (-) button: Decreases number, (+) button: Increases number If the setting is out of the temperature range of temperature sensor, the present temperature (PV) display part flashes SvER and the present value in turn. ※The models which temperature range is 0 (-99.9 to 199.9℃, -99 to 199℃) of temperature sensor DPt100Ω are only set 1↔0↔ (-). ※The dual setting output model (T4LP) has two thumbwheel switches. 2 3 4 5 6 7 LO SET (low set output) HI SET (high set output) LO SET (low set output) heating control, HI SET (high set output): cooling control 5. Hysteresis/Proportional width volume switch (except T3S) ON/OFF control: Setting for hysteresis. [Setting range] F.S. 0.2 to 3% (For T3S, F.S. 0.5% fixed) Proportional control: Setting for proportional width. [Setting range] F.S. 1 to 10% (For T3S, F.S. 3% fixed) Proportional cycle: 20 sec fixed 6. Alarm output value volume switch (only for alarm output model) It sets alarm output value. [Setting range] F.S. 0 to 10% 7. RESET volume switch In case of proportional control, it sets offset. [Setting range] F.S. -3 to 3% 8. Temperature setting of sub output volume switch (only for T3HS) It sets temperature of the sub output. This output operates as deviation low-limit alarm based on the set sub-output temperature (SV). Setting range: 0 to 50℃ Connections (E) Pressure Sensors (F) Rotary Encoders (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets (I) SSRs / Power Controllers (J) Counters (K) Timers (L) Panel Meters (M) Tacho / Speed / Pulse Meters (O) Sensor Controllers a b a b (D) Proximity Sensors (N) Display Units ※Use teminals of size specified below. Min. 3.5mm Max. 7.2mm (C) Door/Area Sensors (H) Temperature Controllers 8 a b (B) Fiber Optic Sensors (P) Switching Mode Power Supplies Min. 3.5mm Max. 7.2mm (Q) Stepper Motors & Drivers & Controllers T3S SSR OUT: 12VDC±2V 20mA Max. CURRENT OUT: DC4-20mA Load 500Ω Max. (R) Graphic/ Logic Panels RELAY OUT: 250VAC 5A 1c 30VDC 5A 1c RESISTIVE LOAD A (S) Field Network Devices (T) Software B' SENSOR B TC RTD SOURCE 100-240VAC 50/60Hz 5VA H-109 T3 / T4 Series T4M/T4MA SENSOR TC B' B A RTD RELAY OUT: 250VAC 5A 1c 30VDC 5A 1c RESISTIVE LOAD T4MA ALARM OUT: 250VAC 2A 1a SSR OUT: 12VDC±2V 20mA Max. CURRENT OUT: DC4-20mA Load 500Ω Max. SOURCE 100-240VAC 50/60Hz 5VA T3H/T3HA/T3HS SSR OUT: 12VDC±2V 20mA Max. CURRENT OUT: DC4-20mA Load 500Ω Max. RELAY OUT: 250VAC 5A 1c 30VDC 5A 1c RESISTIVE LOAD T3HA ALARM OUT: 250VAC 2A 1c T3HS SUB OUT: 250VAC 2A 1c 30VDC 2A 1c A B SOURCE 100-240VAC 50/60Hz 5VA SENSOR B' RTD TC T4L/T4LA/T4LP SSR OUT: 12VDC±2V 20mA Max. CURRENT OUT: DC4-20mA Load 500Ω Max. RELAY OUT: 250VAC 5A 1c 30VDC 5A 1c RESISTIVE LOAD T4LA ALARM OUT: 250VAC 2A 1c T4LP HI SET OUT: 250VAC 2A 1c 30VDC 2A ac A SOURCE 100-240VAC 50/60Hz 5VA B RTD H-110 SENSOR B' TC Thumbwheel Switch Setting Type Dimensions T3S (unit: mm) 90.1 12.3 48 (A) Photoelectric Sensors (B) Fiber Optic Sensors 63.8 10.5 45 (C) Door/Area Sensors (D) Proximity Sensors (E) Pressure Sensors T3H 83 13 48 (F) Rotary Encoders 70 (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets 96 91.5 (H) Temperature Controllers (I) SSRs / Power Controllers (J) Counters (K) Timers ※T3HA, alarm output model, has the alarm output value volume switch. ※T3HS, sub output model, has the temperature setting of sub output volume switch. T4M 72 (L) Panel Meters 89.3 75 11.8 (M) Tacho / Speed / Pulse Meters (N) Display Units 67.5 (O) Sensor Controllers (P) Switching Mode Power Supplies (Q) Stepper Motors & Drivers & Controllers ※T4MA, alarm output model, has the alarm output value volume switch. T4L 96 12.5 82.5 70 (R) Graphic/ Logic Panels (S) Field Network Devices 91.5 (T) Software ※T4LA, alarm output model, has the alarm output value volume switch. ※T4LP, dual setting output model, has the two thumbwheel switches. H-111 T3 / T4 Series Bracket ●T3H/T4M/T4L 4 61 45.4 3.3 ●T3S 46 37.5 40.5 3.9 15 4.5 4.2 41 12 7.4 23.9 47.8 61 12.2 48 Terminal cover (sold separately) ●RLA-COVER (96×96mm) 13 13 13 91.5 4 47.2 86 94 64 ●RHA-COVER (48×96mm) 3 91.5 3 68.5 70 86 ●RMA-COVER (72×72mm) Panel cut-out A D B H-112 C Series T3S T3H T4M T4L Size A Min. 65 Min. 65 Min. 90 Min. 115 B C Min. 65 Min. 115 Min. 90 Min. 115 45 45 68 92 D +0.6 0 +0.6 0 +0.7 0 +0.8 0 45 92 68 92 +0.6 0 +0.8 0 +0.7 0 +0.8 0 Thumbwheel Switch Setting Type Function (A) Photoelectric Sensors 1. Control method 1)ON/OFF control Comparing the present measured temperature and the set temperature, the temperature controller turns ON/OFF of the load power. Interval between ON and OFF of control output is set by the set hysteresis. When hysteresis of control output is too narrow, hunting (overshoot, chattering) may occur by external noise. [Setting range of Hysteresis] F.S. 0.2 to 3% (In case of T3S, F.S. 0.5% fixed) Temperature Overshoot Measured temperature (PV) Hunting width Set temperature (SV) (B) Fiber Optic Sensors ※Control method setting switch Front (C) Door/Area Sensors P F (D) Proximity Sensors (E) Pressure Sensors Hysteresis (F) Rotary Encoders Time Output ON OFF 2)Proportional control Proportional control has control output which is proportional to deviation from the present temperature to the set temperature in the proportional band to the set temperature. Temperature Set temperature (SV) (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets Measured temperature (PV) (H) Temperature Controllers ※Control method setting switch Front Offset (I) SSRs / Power Controllers P F (J) Counters Proportional band (K) Timers (L) Panel Meters Time Output ON OFF (M) Tacho / Speed / Pulse Meters ※T: P  roportional band is fixed as 20 sec. (N) Display Units It is available to control without overshoot or hunting comparing ON/OFF control but it may cause offset. Correct the offset with the RESET volume switch. [Setting range of Proportional band] F.S. 1 to 10% (In case of T3S, F.S. 3% fixed) [Setting range of RESET] F.S. -3 to 3% (O) Sensor Controllers 2. Alarm output Alarm temperature is applied to the high/low-limit based on the set temperature. Alarm output operates deviation high/low-limit. Setting range of Alarm temperature: F.S. 0 to 10% E.g.)When F.S. is 400℃ and max. alarm temperature (F.S. 10%) is 40℃. When the set temperature is set as 100℃, alarm output operation range is 140℃ to 60℃. (S) Field Network Devices Hysteresis 2℃ fixed 100℃ 62℃ 60℃ (Q) Stepper Motors & Drivers & Controllers (R) Graphic/ Logic Panels Temperature 140℃ 138℃ (P) Switching Mode Power Supplies (T) Software Hysteresis 2℃ fixed Time Alarm ON output OFF H-113 T3 / T4 Series 3. Sub output (Only for T3HS) Only the T3HS model has sub output. This output operates as deviation low-limit alarm. [Setting range of Sub output]: 0 to 50℃ E.g.)Set temperature is set as 100℃ and sub-output is set as 20℃ Temperature 100℃ 82℃ Hysteresis 2℃ fixed 80℃ Time Sub output ON OFF 4. Dual setting output (Only for T4LP) Only the T4LP model has dual setting output. -LO SET (low set output: ON/OFF control (Hysteresis: F.S. 0.2 to 3%), Proportional control (Proportional band: F.S. 1 to 10%) -HI SET (high set output): Absolute value high-limit alarm output (Hysteresis: 2℃ fixed) E.g.)T4LP, temperature sensor: DPt100, temperature range: 0 to 400℃ Type LO SET (low set output) HI SET (High set output) Set temperature Output 80℃ ON/OFF control 120℃ Absolute value high-limit alarm output Hysteresis 0.5% (400×0.5%=2℃) 2℃ (fixed) Temperature 120℃ Hysteresis 2℃ fixed 118℃ 100℃ 80℃ 78℃ Hysteresis 0.5% (2℃) Time ON LO SET (low set output) OFF ON HI SET (high set output) OFF Display When Power Is ON When power is supplied, whole display parts turn ON for 1 sec. It displays model type (digits, size, alarm/sub output and control output, sensor, temp. range, unit). Afterward, it returns to RUN mode. Displays digits, size, alarm/sub output Whole parts turn ON → Displays control output, sensor, temp. range, unit → RUN mode → When input sensor Normal operation break/sensor is not connected When input sensor break/sensor is not connected, it displays [OPEN]. In case of normal operation, it displays the present input temperature and controls temperature. ※During displaying model type, control output does not operate. H-114 Thumbwheel Switch Setting Type Control Method (ON/OFF, Proportional Control) Setting (A) Photoelectric Sensors Before supplying power, remove the case and set the control method by the control method setting switch. T3S Control method setting switch Other Series ② ① ② ① (B) Fiber Optic Sensors Front P (C) Door/Area Sensors F (D) Proximity Sensors P: Proportional control (default) Press the 8-pin plug with your thumb. Insert F: ON/OFF control a flat head driver to the ① groove and uplift Press the ① with your thumb. Pull the case to the the case (same as the other side). Push it to ② direction and it is removed. the ② direction and the case is removed. Error Display and Output Operation Display Description OPEN Flashes when a temperature sensor is broken or not connected. HHHH LLLL SvER※2 Flashes when the measured input value is higher than the temperature range of the sensor. Flashes when the measured input value is lower than the temperature range of the sensor. Flashes with the present value when the set value is out of the temperature range of the sensor. (E) Pressure Sensors (F) Rotary Encoders ●: ON ○: OFF Control Alarm Sub Dual Troubleshooting ※ output 1 output output output Check the status of the temperature sensor. When the sensor is connected correctly, it is clear. When the measured temperature is within the temperature range of the sensor, it is clear. The set value should be within the temperature range of the sensor. ※1: T4LP (Dual setting output) is the single output. ※2: When SvER and OPEN/ HHHH/LLLL occur at the same time, SvER and OPEN/ HHHH/LLLLflash in turn and all output turns OFF. (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets (H) Temperature Controllers (I) SSRs / Power Controllers (J) Counters (K) Timers (L) Panel Meters (M) Tacho / Speed / Pulse Meters (N) Display Units (O) Sensor Controllers (P) Switching Mode Power Supplies (Q) Stepper Motors & Drivers & Controllers (R) Graphic/ Logic Panels (S) Field Network Devices (T) Software H-115
T3S-B4RJ2C 价格&库存
很抱歉,暂时无法提供与“T3S-B4RJ2C”相匹配的价格&库存,您可以联系我们找货
