T4YI-N4NP4C-N
T4YI-N4NP4C-N
    AUTONICS(奥托尼克斯)
    TEMP INDICATOR P 400C 100-240VAC
T4YI-N4NP4C-N 数据手册
T3 / T4 Series Temperature Indicator Features Various size as DIN specifications (W48×H24, W72×H36, W96×H48, W48×H48, W48×H96, W72×H72, W96×H96mm) Please read “Safety Considerations” in operation manual before using. Ordering Information T 3 S I N 4 N P 4 C N New ※1 Temperature unit Temperature range Input type ※3 ※3 Control output Power supply Control method Alarm/Sub output Size Digit Item ※1: Name plate and connections are different from previous T3/T4 Series. ※2: Sockets (PG-08, PS-08(N)) are sold separately. H-116 N New type C ℃ 0 -99.9 to 99.9, -99 to 199℃, -99.9 to 199.9℃ 1 0 to 99.9℃ 2 0 to 200℃ 4 0 to 400℃ 5 0 to 500℃ 8 0 to 800℃ A 0 to 999℃ C 0 to 1200℃ F 600 to 1600℃ P DPt100Ω J J(IC) K K(CA) R R(PR) N Indicator X 12-24VDC 4 100-240VAC 50/60Hz N Indicator I Indicator N DIN W48×H24mm Y DIN W72×H36mm W DIN W96×H48mm S DIN W48×H48mm (8-pin plug type) H DIN W48×H96mm M DIN W72×H72mm L DIN W96×H96mm 3 999 (3-digit) 4 9999 (4-digit) T Temperature Controller ※2 Temperature Indicator ※3: Input type and temperature range by Series Thermocouples Input type 0 to 200℃ 0 to 400℃ 0 to 800℃ 0 to 999℃ 0 to 1200℃ 0 to 200℃ 0 to 400℃ 0 to 500℃ 600 to 1600℃ -99.9 to 99.9℃ -99.9 to 199.9℃ -99 to 199℃ 0 to 99.9℃ 0 to 200℃ 0 to 400℃ K(CA) J(IC) R(PR) RTD DPt 100Ω Model 2 4 8 A C 2 4 5 F 0 0 0 1 2 4 Series T3NI T4YI, T4WI T3SI T3HI (A) Photoelectric Sensors T4MI, T4LI (B) Fiber Optic Sensors (C) Door/Area Sensors (D) Proximity Sensors (E) Pressure Sensors (F) Rotary Encoders (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets ※Please contact us for temperature unit ℉ model. (H) Temperature Controllers Specifications Series T3NI T4YI T4WI Power supply 12-24VDCᜡ 100-240VACᜠ 50/60Hz T3SI T3HI T4MI (I) SSRs / Power Controllers T4LI Allowable voltage range 90 to 110% of rated voltage Power consumption Max. 1W Display method 7-segment (red) LED method Character size (W×H) 3.8×7.6mm Input type Display ※ accuracy 1 (J) Counters Max. 3VA 8.0×14.2mm 3.8×7.6mm 6.0×10.0mm 8.0×14.2mm RTD DPt100Ω (allowable line resistance max. 5Ω per a wire) TC K(CA), J(IC) RTD ●At room temperature (23ºC ± 5ºC): (PV ± 0.5% or ±1ºC, select the higher one)±1-digit ●Out of room temperature range: (PV± 0.5% or ±2ºC, select the higher one)±1-digit TC (L) Panel Meters K(CA), J(IC), R(PR) (M) Tacho / Speed / Pulse Meters Sampling period 100ms Dielectric strength 1,000VAC 50/60Hz for 1 min (between input terminal and power terminal) Vibration 0.75mm amplitude at frequency of 10 to 55Hz (for 1 min) in each X, Y, Z direction for 2 hours Insulation resistance Over 100MΩ (at 500VDC megger) Noise immunity Square-wave noise by noise simulator (pulse width 1㎲) Square-wave noise by noise simulator (pulse width 1㎲) ±2kV R-phase and S-phase ±500V R-phase and S-phase Environment Weight ※2 -10 to 50℃, storage: -20 to 60℃ Ambient humi. 35 to 85% RH, storage: 35 to 85% RH Approx. 48g (approx. 25g) (N) Display Units 2,000VAC 50/60Hz for 1 min (between input terminal and power terminal) Ambient temp. (K) Timers (O) Sensor Controllers (P) Switching Mode Power Supplies (Q) Stepper Motors & Drivers & Controllers (R) Graphic/ Logic Panels Approx. 181g Approx. 231g Approx. 120g Approx. 203g Approx. 202g Approx. 274g (approx. 123g) (approx. 140g) (approx. 80g) (approx. 137g) (approx. 137g) (approx. 185g) (S) Field Network Devices (T) Software ※1: In case of the T3NI, T3SI Series and the decimal point display models At room temperature (23ºC±5ºC): (PV ±0.5% or ±2℃, select the higher one)±1-digit Out of room temperature range: (PV ±0.5% or ±3℃, select the higher one)±1-digit ※2: The weight includes packaging. The weight in parenthesis is for unit only. ※Environment resistance is rated at no freezing or condensation. H-117 T3 / T4 Series Connections ※Use teminals of size specified below. a b a b a b Min. 3.5mm Max. 7.2mm Min. 3.5mm Max. 7.2mm T3NI T4YI 4 3 2 B' SOURCE 12-24VDC 1W 1 B A A B B' RTD SOURCE 100-240VAC 50/60Hz 3VA TC RTD SENSOR TC SENSOR T4WI A B B' RTD SOURCE 100-240VAC 50/60Hz 3VA TC SENSOR T3SI T4MI SENSOR TC A B' B A RTD B' SENSOR B TC RTD SOURCE 100-240VAC 50/60Hz 3VA SOURCE 100-240VAC 50/60Hz 3VA T3HI, T4LI A SOURCE 100-240VAC 50/60Hz 3VA H-118 B SENSOR B' RTD TC Temperature Indicator Dimensions (unit: mm) T3NI 52 40 4 (B) Fiber Optic Sensors 8 (C) Door/Area Sensors 21 24 48 (A) Photoelectric Sensors (D) Proximity Sensors T4YI 100 80 (E) Pressure Sensors (F) Rotary Encoders 36 30 7 72 (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets T4WI 112 90 12 (I) SSRs / Power Controllers (J) Counters 48 45 96 (H) Temperature Controllers (K) Timers T3SI 12.3 10.5 (M) Tacho / Speed / Pulse Meters (N) Display Units 45 48 (L) Panel Meters 90.1 63.8 (O) Sensor Controllers T3HI 48 13 (P) Switching Mode Power Supplies 83 70 (Q) Stepper Motors & Drivers & Controllers 91.5 96 (R) Graphic/ Logic Panels (S) Field Network Devices (T) Software H-119 T3 / T4 Series T4MI 89.3 75 11.8 67.5 72 T4LI 12.5 82.5 70 91.5 96 Bracket (unit: mm) ●T4YI Series ●T4WI Series 73 12 20 45.2 48.6 7.9 3.5 11.6 3.5 32.4 26.4 1 10 4.4 22 36.28 28.8 30 10 42 10 ●T3HI/T4MI/T4LI Series 4 61 45.4 3.3 ●T3SI Series 37.5 40.5 3.9 12 7.4 15 4.5 46 4.2 41 H-120 23.9 12.2 48 47.8 61 3.5 ●T3NI Series 53.5 Temperature Indicator (unit: mm) Terminal cover (sold separately) ●RMA-COVER (72×72mm) ●RLA-COVER (96×96mm) 3 ●RHA-COVER (48×96mm) 3 94 (B) Fiber Optic Sensors 4 47.2 86 86 91.5 91.5 (C) Door/Area Sensors 64 68.5 70 (D) Proximity Sensors 13 13 13 (E) Pressure Sensors (F) Rotary Encoders Panel cut-out (unit: mm) Series T3NI T4YI T4WI T3SI T3HI T4MI T4LI D B C Size A Min. 55 Min. 91 Min. 116 Min. 65 Min. 65 Min. 90 Min. 115 B C D Min. 37 Min. 40 Min. 52 Min. 65 Min. 115 Min. 90 Min. 115 45+00.5 68+00.7 92+00.8 45+00.6 45+00.6 68+00.7 92+00.8 22.2+00.3 31.5+00.6 45+00.6 45+00.6 92+00.8 68+00.7 92+00.8 When power is supplied, whole display parts turn ON for 1 sec. It displays model type (digits, size, alarm/sub output and control output, sensor, temp. range, unit). Afterward, it returns to RUN mode. Displays control output, sensor, temp. range, unit Displays digits, size, alarm/sub output → (J) Counters (K) Timers → (M) Tacho / Speed / Pulse Meters (N) Display Units RUN mode (O) Sensor Controllers → When input sensor break/sensor is not connected (P) Switching Mode Power Supplies Normal operation (Q) Stepper Motors & Drivers & Controllers When input sensor break/sensor is not connected, it displays [OPEN]. In case of normal operation, it displays the present input temperature. (R) Graphic/ Logic Panels Error Display Display Description OPEN the status of the temperature sensor. When the sensor Flashes when a temperature sensor is broken or not connected. Check is connected correctly, it is clear. Flashes when the measured input value is higher than the temperature range of the sensor. When the measured temperature is within the temperature range of the sensor, it is clear. Flashes when the measured input value is lower than the temperature range of the sensor. LLLL (I) SSRs / Power Controllers (L) Panel Meters Display When Power Is ON Whole parts turn ON (G) Connectors/ Connector Cables/ Sensor Distribution Boxes/Sockets (H) Temperature Controllers A HHHH (A) Photoelectric Sensors Troubleshooting H-121 (S) Field Network Devices (T) Software
T4YI-N4NP4C-N 价格&库存
很抱歉,暂时无法提供与“T4YI-N4NP4C-N”相匹配的价格&库存,您可以联系我们找货
