Data sheet | Item number: 2734-1104/327-000
1-conductor female connector; lever; Push-in CAGE CLAMP®; 1.5 mm²; Pin spacing
3.5 mm; 4-pole; 100% protected against mismating; 1,50 mm²; light gray
https://www.wago.com/2734-1104/327-000
Color:
light gray
Dimensions in mm
L = (pole no. x pin spacing) + 2.4 mm
Intuitive and tool-free lever actuation
Universal connection for all conductor types
Push-in termination of solid and ferruled conductors
Test slot 90° to conductor entry
Coding option available
Page 1/5
Version 25.11.2022
Continued on next page
Notes
Safety information 1
The MCS – MULTI CONNECTION SYSTEM includes connectors without breaking capaci
ty in accordance with DIN EN 61984. When used as intended, these connectors must
not be connected/disconnected when live or under load.When used as intended, these
connectors must not be connected/disconnected when live or under load. The circuit
design should ensure header pins, which can be touched, are not live when unmated.
Variants:
Other pole numbers
Other versions (or variants) can be requested from WAGO Sales or configured at https://
configurator.wago.com/.
Electrical data
Ratings per IEC/EN
Ratings per UL
Ratings per
IEC/EN 60664-1
Approvals per
UL 1059
Nominal voltage (III/3)
160 V
Rated voltage UL (Use Group B)
300 V
Rated impulse voltage (III/3)
2.5 kV
Rated current UL (Use Group B)
10 A
Rated voltage (III/2)
160 V
Rated voltage UL (Use Group D)
300 V
Rated impulse voltage (III/2)
2.5 kV
Rated current UL (Use Group D)
10 A
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
10 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Polluti
on degree 2
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
300 V
Rated current CSA (Use Group B)
10 A
Rated voltage CSA (Use Group D)
300 V
Rated current CSA (Use Group D)
10 A
Connection data
Number of connection types
1
Connection 1
Number of levels
1
Connection technology
Push-in CAGE CLAMP®
Actuation type
Lever
Solid conductor
0.14 … 1.5 mm² / 26 … 14 AWG
Solid conductor; push-in termination
0.34 … 1.5 mm² / 22 … 14 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated
ferrule
0.14 … 0.75 mm²
Fine-stranded conductor; with uninsula
ted ferrule
0.14 … 1 mm²
Strip length
9 … 10 mm / 0.35 … 0.39 inches
Pole number
4
Conductor entry direction to mating di
rection
0°
Page 2/5
Version 25.11.2022
Physical data
Pin spacing
3.5 mm / 0.138 inches
Height
9.95 mm / 0.392 inches
Depth
24.6 mm / 0.969 inches
Mechanical Data
Variable coding
Yes
Anti-rotation protection
Yes
Plug-in connection
Contact type (pluggable connector)
Female connector/socket
Connector (connection type)
for conductor
Mismating protection
Yes
Material Data
Note (material data)
Information on material specifications can be found here
Color
light gray
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome-nickel spring steel (CrNi)
Contact material
Copper alloy
Contact plating
Tin
Fire load
0.057 MJ
Weight
3.4 g
Environmental requirements
Limit temperature range
-60 … +100 °C
Processing temperature
-35 … +60 °C
Commercial data
ETIM 8.0
EC002638
Country of origin
PT
GTIN
4066966216196
Customs tariff number
85366990990
Approvals and certificates
General approvals
Approval
Standard
Certificate name
CSA
DEKRA Certification B.V.
C22.2 No. 158
2314554
UL
Underwriters Laboratories
Inc.
UL 1059
E45172
Page 3/5
Version 25.11.2022
Downloads
Environmental Product Compliance
Compliance Search
Compliance
2734-1104/327-000
Documentation
Additional Information
Technical Section
03.04.2019
pdf
1949.09 KB
CAD/CAE-Data
CAD data
2D/3D Models
2734-1104/327-000
1 Compatible products
1.1 System counterpart
1.1.1 Male connector/plug
Item no.: 734-304
1-conductor male connector; CAGE
CLAMP®; 1.5 mm²; Pin spacing 3.5 mm; 4pole; 100% protected against mismating;
Item no.: 734-164
THT male header; 1.0 x 1.0 mm solder pin;
angled; 100% protected against misma
ting; Pin spacing 3.5 mm; 4-pole; light
gray
Item no.: 734-134
straight; 100% protected against misma
ting; Pin spacing 3.5 mm; 4-pole; light gray
1.2 Optional accessories
1.2.1 Coding
1.2.1.1 Coding
Item no.: 2734-505
Coding pin carrier; 5 coding keys; for fe
male connectors; orange
1.2.2 Ferrule
Page 4/5
Version 25.11.2022
1.2.2.1 Ferrule
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; in
sulated; electro-tin plated; yellow
Item no.: 216-321
Item no.: 216-151
uninsulated; electro-tin plated
Item no.: 216-131
uninsulated; electro-tin plated; silver-co
lored
Item no.: 216-302
Ferrule; Sleeve for 0.34 mm² / 22 AWG; in
sulated; electro-tin plated; light turquoise
Item no.: 216-322
Item no.: 216-132
Ferrule; Sleeve for 0.34 mm² / AWG 24;
Item no.: 216-152
Item no.: 216-241
Ferrule; Sleeve for 0.5 mm² / 20 AWG; in
sulated; electro-tin plated; electrolytic
copper; gastight crimped; acc. to DIN
46228, Part 4/09.90; white
Item no.: 216-201
sulated; electro-tin plated; white
Item no.: 216-221
Item no.: 216-141
Ferrule; Sleeve for 0.5 mm² / 20 AWG; un
insulated; electro-tin plated; electrolytic
46228, Part 1/08.92
Item no.: 216-101
Ferrule; Sleeve for 0.5 mm² / AWG 22; un
insulated; electro-tin plated; silver-colo
red
Item no.: 216-121
red
Item no.: 216-242
Ferrule; Sleeve for 0.75 mm² / 18 AWG; in
46228, Part 4/09.90; gray
Item no.: 216-262
Item no.: 216-202
sulated; electro-tin plated; gray
Item no.: 216-222
Item no.: 216-142
uninsulated; electro-tin plated; electroly
tic copper; gastight crimped; acc. to DIN
46228, Part 1/08.92
Item no.: 216-102
Ferrule; Sleeve for 0.75 mm² / AWG 20;
lored
Item no.: 216-122
Ferrule; Sleeve for 0.75 mm² / AWG 20; un
insulated; electro-tin plated; silver-colored
1.2.3 Jumper
1.2.3.1 Jumper
Item no.: 2734-402
Jumper; for conductor entry; 2-way; insu
lated; light gray
Subject to changes. Please also observe the further product documentation!
Current addresses can be found at: w w w.wago.com
Page 5/5
Version 25.11.2022
很抱歉,暂时无法提供与“2734-1104/327-000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3+40.355813+4.82850
- 15+39.4280915+4.71750
- 40+38.8714640+4.65090
- 100+38.40760100+4.59540
- 250+37.29434250+4.46220
