G5S-6
G5S-6
    CAIG
    DEOXIT G-SERIES G5 SPRAY WITH P
G5S-6 数据手册
® DATA SHEETInfo DeoxIT® Gold G5 Spray, G-Series Contact Enhancer, Conditioner & Protector 1. Part No.: G5S-6 2. Container Size: 142 g (5.0 oz.), with Low-Med-High Valve 3. Product Description: Unique contact treatment, conditioner, enhancer, lubricant and protectant for PLATED metal surfaces. Improves conductivity, maintains optimum signal quality, reduces fretting & dendrite corrosion, and stabilizes connections between similar and dissimilar metals. Molecularly bonds to both base-metals and plated surfaces and seals out oxygen, protecting both surfaces. The DeoxIT® Gold coating is excellent at reducing wear abrasion, arcing, RFI and intermittent connections and improves connector performance/reliability. Ideal for gold plated surfaces. On oxidized surfaces, pre-treat with DeoxIT® D-Series contact rejuvenator. Temperature* range: -45 to +240OC. 4. Features/Benefits: 5% Spray, with L-M-H valve - Flushing action, Safe on most plastics. DeoxIT® Gold G100L concentrate has approximately 0.5% chemical deoxidizing action. Excellent conductivity enhancing, excellent protection, minimum deoxidizing, no ozone depletion. Prevents dendrite and fretting corrosion. Protects base metals. Reduces intermittent connections, arcing, RFI, wear and abrasion. Ideal for both stationary and moving (vibration) connections. Cleaner Audio - Clearer Video - Reliable Data. 5. Formulation: 5% DeoxIT® Gold G100L 75% Odorless mineral spirits (CAS 64742-88-7) 20% DIFLUOROETHANE (CAS 75-37-6) 6. Which DeoxIT® product do I Use:  Use DeoxIT® D-Series contact treatment on surfaces that have been in service or have visual signs of oxidation. Contains 20% active deoxidizer.  Use DeoxIT® Gold G-Series conditioner on new surfaces, and gold plated surfaces. Ideal for preventing dendrite/fretting corrosion. Protects both surface and base metals. Ideal for critical applications. Contains >1% active deoxidizer.  Use DeoxIT® Shield S-Series to protect surfaces from severe environments (humidity, salts, pollutants, sulfur, etc.). Use on clean surface. Contains 0% active deoxider. * NOTE: Temperature ranges may vary depending on conditions. On critical applications, independent testing is highly recommended. Audio/Video Computers Automotive Communications Marine Electrical Energy Photography Security Medical Avionics 7. Directions for Use: 1. Turn off, unplug the device. 2. On surfaces that have been in service or have visual signs of oxidation or corrosion pre-treat with DeoxIT® D-Series (D5S-6) contact rejuvenator (see Data Sheet DS-D5S-6). 3. Apply one short burst of DeoxIT® Gold G-Series contact enhancer to contact/connector surface. 4. Operate the part/device to help distribute the DeoxIT® Gold and break up minor amounts of oxides and contamination. Wait a few seconds, reapply one short burst. Wait two minutes before turning on equipment. Test for compatibility before use. 5. If you notice a green or black coloration on the surface (may take a few days) after applying DeoxIT®, this indicates dissolved oxidation (surface was severely oxidized). Repeat step “2-4” above. 6. For extended protection: For severe environments (humidity, salts, pollutants, sulfur, outdoor applications, etc.) apply DeoxIT® Shield S-Series after applying DeoxIT® Gold G-Series. 7. NOTE: To prevent overspray or spraying in unwanted areas, you can always spray onto a lint-free swab or cloth first and then using the swab/cloth apply the DeoxIT® to the connector/contact surface(s). 8. Other Applicators: Part No. % DeoxIT® G5S-6 5% GN5S-6N 5% GN5S-2N 5% G100S-2 100% G100P 100% G100L-P6C 100% G50W 100% G1W 100% G100L-2C 100% G100L-16BX 100% G100L-2DB 100% G100L-25C 100% G100L (bulk, many sizes) 100% VOC (%) Applicator 75% spray 0% spray 0% mini-spray 0% spray 0% pen 0% oiler pen 0% wipes 0% wipes 0% tube 0% brush bottle 0% brush bottle 0% needle dispenser 0% bottle/drum Size 142 g 163 g 40 g 57g 6 mL 6 mL 50 count individual 2 mL 1.6 mL 7.4 mL 25 mL assort. Flammable/Nonflammable flammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable nonflammable 9. Product Selection Guides: DeoxIT7 - Spray Selection Guide Product Series FP QD Standard - 5% solution D5S-6, D5MS-15, G5S-6, G5MS-15, S5S-6, S5MS-15, F5S-6, F5MS-15 N Series - 5% solution DN5S-6N, DN5S-2N, GN5S-6N, GN5S-2N, SN5S-6N, SN5S-2N X Series - 5% solution GX5S-6N 100% Spray solution D100S-2, G100S-2, F100S-L2  NF PC VOC  75% (588g/L)    0.0%    0.0%   0.0% FP = Flushing properties QD = Quick dry / non drip NF = Nonflammable PC = Plastics compatibility VOC = VOC (%) Page 2 Audio/Video Computers Communications Automotive Marine Electrical Energy Photography Security Medical Avionics 10. Materials Compatibility (Plastics, Rubber, Elastomeric and Metals): (Rating: Not compatible, Poor, Fair, Good, Excellent), (N/A = Not applicable (no solvents and propellants) (* If the product is not 100% DeoxIT® then the package is rated before and after the solvents/propellants are applied to materials. Compatibility testing is always recommended) Material Name Rating (*100% DeoxIT®) Rating (*with solvents) ABS Nylon Lexan HDPE LDPE C.E.Phenolic Epoxy Polycarbonate PMMA POM PP PS PTFE PVC TPE/Rubber/Varnish Excellent Excellent Excellent Good Good Excellent Excellent Excellent Fair Excellent Excellent Fair Excellent Excellent Poor Fair-Good Excellent Excellent Good Good Good Excellent Fair-Good Fair Excellent Good Fair Excellent Excellent Poor IMPORTANT: Rating, 100% DeoxIT®: Any of the above that fall into the “Fair” and “Poor” categories should be thoroughly tested for compatibility. They may be compatible, however, it will depend on the manufacturing process of the materials. Acrylics, ABS, and polycarbonate, if under stress, may show slight cracking or crazing damage. Test for compatibility before use. On porous materials; i.e. wood, rubber, cloth, some phenolics, semi-cured materials, no liquid or solvents should be used. Occasionally, DeoxIT® will get onto unwanted surfaces, quickly wipe off surface and usually no damage will occur. Rating, with solvents: Similar to rating above (100% DeoxIT®). However, any rating worse than the 100% DeoxIT® may require additional care. If DeoxIT is applied to unwanted areas or materials, wipe off surface quickly and usually no damage will occur. Alternatively, apply DeoxIT® onto a lint-free swab or cloth first and then wipe onto desired metal surface. 11. DeoxIT® Essential Reference: DeoxIT® D-Series - Brings old systems back to life! DeoxIT® Gold G-Series - Maintains new system performance! DeoxIT® Shield S-Series - Maintains new system performance for severe environments! DeoxIT® Fader F-Series - Clean, lubricate & protect conductive plastic and carbon compound faders! 12. Shipping and Additional Information: Hazardous: VOC (%): ORMD Part No. G5S-6, 75% (588 g/L) Page 3 Audio/Video Computers Automotive Communications Marine Electrical Energy Photography Security Medical Avionics 13. Other Information: RoHS Compliant: VOC Compliant: MSDS Link, G5S-6 DeoxIT® Product Sheet: CAIG Essential Guide: WHY DeoxIT® is Different: YES YES http://caig.com/material-safety-data-sheets/ http://caig.com/technical-data/ http://caig.com/product-literature/#toggle-id-1 http://caig.com/product-literature/#toggle-id-5 14. MANUFACTURER DISCLAIMER: To the best of our knowledge, the information contained herein is accurate. However, neither CAIG Laboratories, Inc., or any of its subsidiaries assumes any liability whatsoever for the accuracy or completeness of the information contained herein. All materials may present unknown hazards and should be used with caution. In particular, improper use of our products and their inappropriate combination with other products and substances may produce harmful results which cannot be anticipated. Final determination of the suitability of any material is the sole responsibility of the user. Although certain hazards are described herein, we cannot guarantee that these are the only hazards that may exist. All service performed on internal parts and equipment should be provided by qualified technicians. 15. Contact Information: ® Website: www.caig.com www.deoxit.com General email: info@caig.com Technical email: tech@caig.com North America (Headquarters): CAIG Laboratories, Inc. 12200 Thatcher Court Poway, CA 92064 USA Tel: (858) 486-8388 Fax: (858) 486-8398 Distributors (Domestic & International): http://store.caig.com/s.nl/sc.15/.f CAIG Laboratories, Inc. 12200 Thatcher Court, Poway, CA 92064 U.S.A. P: 858/486-8388 | E: info@caig.com WEB: www.caig.com | www.deoxit.com Page 4
G5S-6 价格&库存
很抱歉,暂时无法提供与“G5S-6”相匹配的价格&库存,您可以联系我们找货
