8MQ2M9910RNE046E
8MQ2M9910RNE046E
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, SEALED, WITH FEMA
8MQ2M9910RNE046E 数据手册
04-12 99-01 99-10 * : cotation also avaible for 01-08 / 01L28 / 00-00 modules ** : cotation also avaible for 01-08 / 01L28 modules 09-36 15 16,46 Max 14,4 0,05 * 11,22-11,46 ** 17,16-17,40 * * 0,05 22,4 Max 11,65 Max 11,50,05 * 12 0,05 * 12,7 0,05 * 7 13,5 0,05 * 14 8 * 13,35 Max MALE FEMALE 0,05 13,3 0,05 * 08-16 A 12-20 B C D E F G H 20-22 8 Peripheral seal (optionnal) 6 6 FOR MODULE 18,7 Max Peripheral seal (optionnal) Lightweight version 00-00 11.65 Max 01-08 & 01L28 FOR MODULE 13.35 Max 40 Max 5 MALE 7 12 Max 9.90-10.15 MALE 5 (01-08 for example) 10.8 Max F.2; Validé FOR MODULES 4 sealing sleeve ref. 8990-0570A for 01-08& 01L28 (delivered with contact only) FEMALE 33,2 Max FEMALE 54 Max 4 Peripheral seal (optionnal) 11.65 Max (01-08 for example) DESIGNATION SOURIAU BASIC SERIE 3 2 = Serie 2 8MQ 2 M 20-22 P N E - Layout Dash = No grounding L = No grounding, quadrax contact 2 = = = = Male module delivered with contacts Female module delivered with contacts Male module delivered without contacts Female module delivered without contacts N, A, B, C, D = Polarization None = Without peripheral sealing E = With peripheral sealing A = Serie 2 20-22 1 N M = = = = (For module delivered with antistatic caps, please to consult 1 characteristics: - Insulator : Thermoplastic - Grommet and interfacial seal : Silicon elastomer - Contacts : copper alloy - Contacts plating : Gold over nickel 0.8µ G EN4165- 1 N 1 = Without peripheral sealing us) 2 = With peripheral sealing 12 08-16 16 8 01-08 01L28 L 20 20 Male module delivered with contacts 99-10 Female module delivered with contacts Male module delivered without contacts Female module delivered without contacts 09-36 BASIC SERIE Qty 22D 99-01 N, A, B, C, D = polarization # 20-22 04-12 1 = Without peripheral sealing 2 = With peripheral sealing M F A B Layout 12-20 DESIGNATION EN4165 (blank modules) None = Without protection cap S = With protection cap M = With antistatic protection cap H EN4165 A Layout Dash = No grounding L = No grounding, quadrax contact M = Module P S A B BASIC SERIE Technical requirements CONTACTS DESIGNATION EN4165 (modules) 12 22D 16 20 16 22D 20 8 8Q 4 5 6 8 2 6 3 1 1 00-00 no contact 1- Voltage proof test (Sea level) : - #22 = 1300 V r.m.s. - #20/#16/#12/#8(Q) = 1500 V r.m.s. 2- Insulation resistance = 5000 M ^ 3- Climatic sequence : -55°C/+175°C 4- Fluid resistance : See standard EN 4165-001 (table 40) 5- Contact retention in insert : - #22 = 44 N - #20 = 67 N - #16/#12/#8/#8Q = 110 N 6- The use of sealing plugs or dummy contacts is mandatory for all unused cavities Layout # 5% 6.81 08-16 5.16 6.63 12-20 04-12 09-36 01-08 01L28 00-00 4.36 5.29 4.96 4.46 3.89 E D 10/05/19 ISS DATE 2/1 6.69 6.08 5.69 10.96 1.44 N/C drawing update for EN4165 creation modules 10.13 FORMAT C A2 23536BM Add marking and codification EN4165 version Latest modification - by: N.AUFFRET E.FOREST Date:24/07/15 CUSTOMER DRAWING MOD N $ 2 MODULES - BASIC SERIE 8MQ COMPLIANT WITH EN4165/BACI10BC/ARINC 809 General linear Tolerances: WWW.SOURIAU.COM Values for information purposes F F Scale 6.19 6.70 7.60 P/N : SEE TABLE TITLE 6.06 3 CountryJurisdiction & Control List FR NOT LISTED Designed by: Male module Female module 4.32 99-10 L = Lightweight version With contacts 20-22 99-01 N = Polarization (N only) Weight (g) Colors no contractuals SOURIAU DRG N° C001-8MQ-A B NPRDS / PROJECT BE133701A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 2 A 1 3,89 5 cts #22D + 6 cts #16 3,38 1,69 3,79 3,81 2,975 3,77 5 4 cts #12 8 7 5,07 5,24 2,62 99-01 04-12 8 cts #16 5,24 5,07 6 NO MARKING 2,62 3,5 3,77 08-16 99-10 00-00 3,5 2,31 3,38 3,81 8 cts #20 + 2 cts #16 3,475 2,975 2,31 VIEW OF FRONT FACE OF MALE MODULE & REAR FACE OF FEMALE MODULE 3,79 6 cts #22D + 3 cts #20 3,475 LAYOUT 3,81 3,89 1,27 6 4,62 POSITIONNING 1,69 09-36 12 cts #20 4,62 3,81 1,69 12-20 1,27 3,81 3,81 1,69 2,54 VIEW OF FRONT FACE OF MALE MODULE & REAR FACE OF FEMALE MODULE 5,07 A 5,07 POSITIONNING LAYOUT VIEW OF FRONT FACE OF MALE MODULE & REAR FACE OF FEMALE MODULE B 7 20 cts #22D LAYOUT 5,08 2,54 20-22 POSITIONNING C 5,08 D VIEW OF FRONT FACE OF MALE MODULE & REAR FACE OF FEMALE MODULE E F G H 8 F.2; Validé LAYOUT POSITIONNING No contacts 4,4 5 4,4 NO MARKING 4 01-08 01L28 1 ct #8 1 ct #8 Quadrax 4 3 3 MARKING Peripheral seal (optionnal) Marking exemple : 2 15-01 * SOURIAU FR 1 8MQ2M20-22 PNE or EN4165A 20-222NM or EN4165-1NL H Colors no contractuals P/N : SEE TABLE Date code (Year-Week) * = Manufacturing location - France : None - Maroc : T F 10/05/19 ISS DATE Designed by: TITLE Part number module SOURIAU Scale 4/1 or Part number module EN4165 or drawing update for EN4165 creation modules Male module F Female module E D FORMAT C A2 23536BM Add marking and codification EN4165 version Latest modification - by: N.AUFFRET E.FOREST Date:24/07/15 CUSTOMER DRAWING MOD N $ 2 MODULES - BASIC SERIE 8MQ COMPLIANT WITH EN4165/BACI10BC/ARINC 809 General linear Tolerances: WWW.SOURIAU.COM Part number blank module EN4165 G CountryJurisdiction & Control List FR NOT LISTED SOURIAU DRG N° C001-8MQ-A B NPRDS / PROJECT BE133701A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 2 / 2 A 1
8MQ2M9910RNE046E
1. 物料型号:8MQ系列,包括不同的模块配置,如20-22、12-20、08-16、04-12、99-01、99-10、09-36、01-08、01L28、00-00。
2. 器件简介:8MQ系列连接器符合EN4165标准,适用于多种电气和气候条件,包括电压测试、气候序列、流体阻力等。
3. 引脚分配:文档列出了不同模块的引脚数量,例如20-22模块有20个引脚,12-20模块有12个引脚等。
4. 参数特性:包括绝缘体材料、垫圈和界面密封材料、接触材料和镀层等。
5. 功能详解:文档提供了连接器的电压测试要求、气候序列、流体阻力等技术要求。
6. 应用信息:适用于需要符合EN4165标准的电气连接应用。
7. 封装信息:提供了不同模块的重量信息,以及有无周边密封的选择。
8MQ2M9910RNE046E 价格&库存
很抱歉,暂时无法提供与“8MQ2M9910RNE046E”相匹配的价格&库存,您可以联系我们找货
