8MQ2S1M0B1U0
8MQ2S1M0B1U0
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK SHORT RECEPTACLE, COMPOSI
8MQ2S1M0B1U0 数据手册
A B C D E F G H Technical Characteristics 28,85 # 0,11 8 8 Material & finishes External keying for panel cut out (see sheet 2) 23,30 # 0,05 • Shell : Composite nickel plated • Keying colour coding plate : Composite • Sealing gasket : Silicone elastomer • Nut plate : Stainless steel 18,70 max Electrical 10,060-0,07 • Housing (shell) electrical continuity : < 3m ^ • Shielding effectiveness : > 50dB attenuation from 100 to 1 000 MHz Climatic 7 • Operating temperature range : -55°C to +175°C • Salt spray (corrosion) : 500 hrs 18,70 max 10,060-0,07 20,30 # 0,05 18,05 # 0,06 7 25,85 # 0,11 Mechanical • Compliant EN4165 - BACC65 - ARINC 809 • Mating/Unmating: 500 operations • Delivered with protective cap Environmental 6 • RoHS and REACH compliant • Fluid resistance : See standard EN 4165-001 (table 40) 5,8 max 15,45 min Part 20,15 # 0,06 4x n 3,1 Internal keying for plug Polarization color band (see table) Marking on receptacle EN4165 M Only for ordering 0 1 A M - Composite nickel plated Shell Type : 0 - Short receptacle Module Quantity : 1 - Mono module Serie : 2 - Serie 2 Polarization : N, A, B, C, D, E, F, G Option for coding color plate 0 : Delivered without keying colour coding plate 1 : Delivered with keying colour coding plate Option for sealing gasket U : Delivered without sealing gasket G : Delivered with sealing gasket Option for nut plate 0 : Delivered without nut plate 1 : Delivered with nut plate N 0 U 0 0 N 0 U 0 1.0 maxi 5 4 2 RZ M - Composite nickel plated Shell Type : 0 - Short receptacle Polarization : N, A, B, C, D, E, F, G Option for coding color plate 0 : Delivered without keying colour coding plate 1 : Delivered with keying colour coding plate Polarization colour table 1 Option for sealing gasket U : Delivered without sealing gasket G : Delivered with sealing gasket Option for nut plate 0 : Delivered without nut plate 1 : Delivered with nut plate P/N : SEE PART NUMBER TABLE N M AT 1 1 - Mono module C N 21/05/19 ISS A DATE Designed by: B TITLE C D Scale E F 3/1 G drawing update for EN4165 creation receptacle F E SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) D C FORMAT A2 24230AB Add marking and codification EN4165 version Latest modification - by: N.AUFFRET E.FOREST Date:07/09/16 CUSTOMER DRAWING MOD N $ 2 RECEPTACLE 8MQ TYPE 0 BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 Dimensions in mm General linear Tolerances: www.souriau.com CountryJurisdiction & Control List FR NOT LISTED G Nut plate SEALING GASKET Only for ordering Plating : H 0.8 maxi 3 Type of component : S - Shell Module Quantity : Sealing gasket RECEPTACLE LA 2 - Serie 2 1.2 maxi (see table for polarization colour) ur 3 Serie : S Keying colour coding plate KEYING COLOUR CODING PLATE Marking on receptacle 8MQ 2 6.0 maxi NUT PLATE SCALE 2/1 SOURIAU PART NUMBER TABLE Range : Receptacle View of "N" polarization IO 4 Plating : MASS (g) Receptacle part number SOURIAU or EN4165 lo Range : 6 Date code (YY-WW) Co 5 EN4165 PART NUMBER TABLE PO C.3; Validé Shell are compliant for use with modules polarization N, A, B, C, D SOURIAU DRG N° C002-8MQ-A B NPRDS / PROJECT BE133702A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 2 A 1 A B C D E F G H C.3; Validé PANEL CUT-OUT Panel cut out general dimensions 6,52 0,05 4,28 0,05 6,52 0,05 6,52 0,05 2,04 0,05 4 0,05 2,04 0,05 2,04 0,05 20,4 0,95 0,1 20,4 0,1 4,28 0,05 20,4 3,16 0,05 0,05 3,16 0,05 5,4 Polarization F 0,1 0,1 4,28 5,4 3,16 0,05 0,05 Polarization E 1,21 0,05 0,1 20,4 0,1 0,95 0,05 0,09 0,05 3,16 0,05 Polarization G 3 0,05 4,28 0,05 0,05 2,04 0,05 0,1 3 4x R3 0,05 20,4 5,4 0,05 5,4 0,05 5,4 0,05 20,4 5,4 0,1 0,05 Polarization D 2,04 7 4,28 0,05 20,4 0,95 Free mounting cut out dimensions 0,1 4,28 0,1 0,1 23,3 0,1 7 0,05 20,4 21 6,52 20,4 18,3 0,1 20,3 2x R4,55 0,03 Polarization C 0,1 2x R0,6 Polarization B 0,1 3,1 0,1 0,1 4 4x 1,95 0,05 Polarization A 20,4 2x R3 Polarization N 3,16 0,05 0,05 5,4 0,05 2 2 Oriented panel cut out dimensions P/N : SEE PART NUMBER TABLE Panel thickness : 2mm max C 21/05/19 ISS DATE Designed by: 20,4 0,1 2x R3 TITLE drawing update for EN4165 creation receptacle Latest modification - by: N.AUFFRET 1 7 0,1 7 NPRDS / PROJECT General linear Tolerances: BE133702A WWW.SOURIAU.COM CountryJurisdiction & Control List FR NOT LISTED H G SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) F E SOURIAU DRG N° FORMAT D A3 CUSTOMER DRAWING MOD N $ BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 1/1 0,1 E.FOREST Date:07/09/16 RECEPTACLE 8MQ TYPE 0 Scale 2x R4,55 24230AB Add marking and codification EN4165 version C C002-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 2 / 2 A 1
8MQ2S1M0B1U0
物料型号:STC8H 器件简介:STC8H系列单片机是宏晶科技推出的一款高效能、低功耗的8位微控制器,适用于需要高性能运算和控制的应用场景。
引脚分配:该系列单片机具有多种封装形式,引脚数量和功能因型号而异,但通常包括电源引脚、地引脚、I/O引脚、通信接口引脚等。
参数特性:工作电压范围宽,支持多种工作频率,具有丰富的内置功能模块,如定时器、串行通信接口等。
功能详解:STC8H系列单片机具备高速的CPU运行速度,支持多种中断源,具有较大的程序和数据存储空间。
应用信息:适用于工业控制、智能家居、消费电子等领域。
封装信息:提供多种封装选项,如QFP、DIP等,以适应不同的应用需求。
8MQ2S1M0B1U0 价格&库存
很抱歉,暂时无法提供与“8MQ2S1M0B1U0”相匹配的价格&库存,您可以联系我们找货
