A
B
C
D
E
F
G
H
MASS
9,55 min
8
10,6 g maxi
8
Technical Characteristics
Material& finishes
Shell : Composite nickel plated
Locking slide : Composite
Electrical
18,65 max
7
25,5 max
Housing (shell) electrical continuity : < 3m ^
7
Shielding effectiveness : > 50dB attenuation
from 100 to 1 000 MHz
Climatic
Operating temperature range : -55°C to +175°C
Salt spray (corrosion) : 500 hrs
Mechanical
6
19,30 Max
18,61 max
Date code (YY-WW)
Compliant EN4165 - BACC65 - ARINC 809
Mating/Unmating: 500 operations
6
Delivered with protective cap
Environmental
RoHS and REACH compliant
Fluid resistance : See standard EN 4165-001 (table 40)
Locking slide
5
5
Plug part number
SOURIAU or EN4165
EN4165 PART NUMBER TABLE
4
EN4165 M
Range :
Plating :
M - Composite nickel plated
Shell Type :
6 - Plug
Module Quantity :
1 - Mono module
Serie :
2 - Serie 2
Polarization :
N, A, B, C, D, E, F, G
6
Shell
View of
"N" polarization
Marking on receptacle
1
A
N
4
Polarization color
(see table)
3
3
8MQ 2
Range :
2
Serie :
S
2 - Serie 2
1
M
6
N
Polarization
1 - Mono module
Plating :
Shell Type :
6 - Plug
Polarization :
ur
N
B
B
table
Module Quantity :
P/N : SEE TABLE
A
colour
Type of component : S - Shell
lo
LA
RZ
Co
AT
IO
N
SOURIAU PART NUMBER TABLE
PO
B.2; Validé
Shells are compliant for use with modules polarization N, A, B, C, D
27,5 max
21/05/19
ISS
DATE
Designed by:
C
D
TITLE
E
F
Scale
G
3/1
drawing update for EN4165 creation plug
Latest modification - by:
N.AUFFRET
E.FOREST
Date:27/09/19
1
H
G
F
E
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N $
2
PLUG 8MQ TYPE 6
BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809
Dimensions in mm
General linear
Tolerances:
www.souriau.com
CountryJurisdiction
& Control List
FR
NOT LISTED
24230AB
Add marking and codification EN4165 version
SOURIAU DRG N°
C003-8MQ-A
B
NPRDS / PROJECT
BE133702A
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2S1M0D1G1”相匹配的价格&库存,您可以联系我们找货
