8MQ2S1M0N1G1
8MQ2S1M0N1G1
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK EXTENDED RECEPTACLE, COMP
8MQ2S1M0N1G1 数据手册
Material & finishes External keying for panel cut out (see sheet 2) 23,30 # 0,05 A B C D E F G H 28,85 # 0,11 8 18.65 max 8 • Shell : Composite nickel plated • Keying colour coding plate : Composite • Sealing gasket : Silicone elastomer • Nut plate : Stainless steel Electrical Climatic 18.61 max 10,060-0,07 • Housing (shell) electrical continuity : < 3m ^ • Shielding effectiveness : > 50dB attenuation from 100 to 1 000 MHz 10,060-0,07 18,05 # 0,06 20,30 # 0,05 7 25,85 # 0,11 7 • Operating temperature range : -55°C to +175°C • Salt spray (corrosion) : 500 hrs Mechanical • Compliant EN4165 - BACC65 - ARINC 809 • Mating/Unmating: 500 operations • Delivered with protective cap Environmental • RoHS and REACH compliant • Fluid resistance : See standard EN 4165-001 (table 40) 6 13.50 max 20,15 # 0,06 4x Part n 3,1 Internal keying for plug Date code (YY-WW) 5 EN4165 PART NUMBER TABLE Marking on receptacle EN4165 M Range : 1 A 4 Plating : M - Composite nickel plated Shell Type : 7 - Long receptacle Module Quantity : 1 - Mono module Serie : 2 - Serie 2 Polarization : N, A, B, C, D, E, F, G Option for coding color plate 0 : Delivered without keying colour coding plate 1 : Delivered with keying colour coding plate Option for sealing gasket U : Delivered without sealing gasket G : Delivered with sealing gasket Option for nut plate 0 : Delivered without nut plate 1 : Delivered with nut plate N 0 U 0 Polarization color band (see table) MASS (g) Receptacle 7.5 maxi Keying colour coding plate 1.2 maxi Sealing gasket 0.8 maxi Nut plate 1.0 maxi 5 Receptacle part number SOURIAU or EN4165 Only for ordering 7 6 15,45 min View of "N" polarization NUT PLATE 4 SCALE 2/1 KEYING COLOUR CODING PLATE (see table for polarization colour) RECEPTACLE 3 3 SOURIAU PART NUMBER TABLE SEALING GASKET U 0 Type of component : S - Shell 2 1 - Mono module Plating : M - Composite nickel plated colour Shell Type : 7 - Long receptacle table Polarization : N, A, B, C, D, E, F, G Option for coding color plate 0 : Delivered without keying colour coding plate 1 : Delivered with keying colour coding plate Option for sealing gasket U : Delivered without sealing gasket G : Delivered with sealing gasket Option for nut plate 0 : Delivered without nut plate 1 : Delivered with nut plate 1 Module Quantity : Polarization G B N 21/05/19 ISS A DATE Designed by: B TITLE C D Scale E F 3/1 drawing update for EN4165 creation receptacle Latest modification - by: H.SIMIER E.FOREST Date:20/09/16 F E D C FORMAT A2 CUSTOMER DRAWING MOD N $ 2 RECEPTACLE 8MQ TYPE 7 BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 Dimensions in mm General linear Tolerances: www.souriau.com SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) 24230AB Add marking and codification EN4165 version G CountryJurisdiction & Control List FR NOT LISTED H P/N : SEE PART NUMBER TABLE ur 0 lo N N 7 IO M Co 2 - Serie 2 1 RZ Serie : S LA 8MQ 2 Range : Only for ordering AT Marking on receptacle PO B.3; Validé Technical Characteristics Shell are compliant for use with modules polarization N, A, B, C, D SOURIAU DRG N° C004-8MQ-A B NPRDS / PROJECT BE133702A This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 2 A 1 A B C D E F G H B.3; Validé PANEL CUT-OUT Panel cut out general dimensions 6,52 0,05 4,28 0,05 6,52 0,05 6,52 0,05 2,04 0,05 4 0,05 2,04 0,05 2,04 0,05 20,4 0,95 0,1 20,4 0,1 4,28 0,05 20,4 3,16 0,05 0,05 3,16 0,05 5,4 Polarization F 0,1 0,1 4,28 5,4 3,16 0,05 0,05 Polarization E 1,21 0,05 0,1 20,4 0,1 0,95 0,05 0,09 0,05 3,16 0,05 Polarization G 3 0,05 4,28 0,05 0,05 2,04 0,05 0,1 3 4x R3 0,05 20,4 5,4 0,05 5,4 0,05 5,4 0,05 20,4 5,4 0,1 0,05 Polarization D 2,04 7 4,28 0,05 20,4 0,95 Free mounting cut out dimensions 0,1 4,28 0,1 0,1 23,3 0,1 7 0,05 20,4 21 6,52 20,4 18,3 0,1 20,3 2x R4,55 0,03 Polarization C 0,1 2x R0,6 Polarization B 0,1 3,1 0,1 0,1 4 4x 1,95 0,05 Polarization A 20,4 2x R3 Polarization N 3,16 0,05 0,05 5,4 0,05 2 2 Oriented panel cut out dimensions P/N : SEE PART NUMBER TABLE Panel thickness : 2mm max B 20/09/16 ISS DATE Designed by: 20,4 0,1 2x R3 TITLE drawing update for EN4165 creation receptacle Latest modification - by: H.SIMIER 1 7 0,1 7 NPRDS / PROJECT General linear Tolerances: BE133702A WWW.SOURIAU.COM CountryJurisdiction & Control List FR NOT LISTED H G SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) F E SOURIAU DRG N° FORMAT D A3 CUSTOMER DRAWING MOD N $ BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 1/1 0,1 H.SIMIER Date:20/09/16 RECEPTACLE 8MQ TYPE 7 Scale 2x R4,55 -- Add marking and codification EN4165 version C C004-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 2 / 2 A 1
8MQ2S1M0N1G1 价格&库存
很抱歉,暂时无法提供与“8MQ2S1M0N1G1”相匹配的价格&库存,您可以联系我们找货
