A
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
B
VIEW A
MASS
5%
5,7 g
Technical requirements 4
45 $ 1 $
shell : Composite nickel plated
clamp : Composite
- Electrical :
7,1 Min
Housing (shell) electrical continuity
Between backshell and plug :
< 3m ^
27
,5
Ma
x
17 Max
- Material& finishes :
20,5 Max
4
R14 0,1
VIEW A
B
Detail
31 Max
C
D
E
F
G
H
B.4; Validé
35,5 Max
0,5 Min
11,3 Max
3
Shell
4 Min
- Climatic :
Operating temperature range :
-55°C to +175°C
Salt spray (corrosion) : 500 hrs
Clamp
3
- Mechanical :
Compliant EN4165
B
DETAIL
SCALE 3/1
- Environmental :
RoHS and REACH compliant
Fluid resistance : See standard
EN 4165-001 (table 40)
Angular
position
indication
2
EN4165 PART NUMBER TABLE
BASIC SERIE
CountryJurisdiction
& Control List
FR
NOT LISTED
backshell part number
SOURIAU
EN4165-026 M 20 A
M : Composite nickel plated
P/N : 8MQ2B1M26-20A
20 : Backshell with angle of 45°
A : With cable tie device
SOURIAU PART NUMBER TABLE
BASIC SERIE
2 : Serie 2
8MQ 2 B 1 M 26 20 A
1
26 : According EN4165-026
ISS
DATE
drawing update for EN4165 creation backshell
Latest modification - by:
N.AUFFRET
General linear
Tolerances:
E
NPRDS / PROJECT
BE133702A
WWW.SOURIAU.COM
D
A3
CUSTOMER DRAWING
MOD N $
BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809
FORMAT
F
E.FOREST
Date:21/09/16
BACKSHELL WITH ANGLE OF 45°
3/2
24230AC
Add marking and codification EN4165 version
Scale
G
08/07/19
TITLE
laser marking
EN4165-026M20A
date code
(only for EN4165 version)
1 : Mono module
H
B
Designed by:
B : Backshell
2
C
SOURIAU DRG N°
C006-8MQ-A
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2B1M2620A”相匹配的价格&库存,您可以联系我们找货
