8MQ2B1M2610A
8MQ2B1M2610A
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    连接器 底壳 用于 8MQ2 系列 合成物,镀镍
8MQ2B1M2610A 数据手册
20 Max ,5 27 A A 26,5 Max Detail B C D E F G H B.4; Validé SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) MASS # 5% 4,3 g x Ma 4 Technical requirements 4 - Material& finishes : 4 Min 0,5 Min 7,1 Min shell : Composite nickel plated clamp : Composite - Electrical : Housing (shell) electrical continuity Between backshell and plug : < 3m ^ 11,3 Max - Climatic : 3 A DETAIL SCALE 3/1 Shell Clamp Operating temperature range : -55°C to +175°C Salt spray (corrosion) : 500 hrs 3 - Mechanical : Compliant EN4165 - Environmental : RoHS and REACH compliant Fluid resistance : See standard EN 4165-001 (table 40) 2 EN4165 PART NUMBER TABLE BASIC SERIE backshell part number SOURIAU EN4165-026 M 10 A M : Composite nickel plated 10 : Straight backshell A : With cable tie device SOURIAU PART NUMBER TABLE BASIC SERIE 2 : Serie 2 1 1 : Mono module M : Composite nickel plated 26 : According EN4165-026 08/07/19 ISS DATE drawing update for EN4165 creation backshell Latest modification - by: N.AUFFRET General linear Tolerances: E NPRDS / PROJECT BE133702A WWW.SOURIAU.COM D A3 CUSTOMER DRAWING MOD N $ BASIC SERIE 8MQ - Based on EN4165/BACC65BV/ARINC 809 FORMAT F E.FOREST Date:21/09/16 STRAIGHT BACKSHELL 3/2 A : With cable tie device 24230AC Add marking and codification EN4165 version Scale 10 : Straight backshell G B TITLE laser marking EN4165-026M10A + date code (only for EN4165 version) 2 P/N : 8MQ2B1M26-10A Designed by: 8MQ 2 B 1 M 26 10 A B : Backshell H CountryJurisdiction & Control List FR NOT LISTED C SOURIAU DRG N° C005-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2B1M2610A 价格&库存
很抱歉,暂时无法提供与“8MQ2B1M2610A”相匹配的价格&库存,您可以联系我们找货
