8MQ2M1220UCES
8MQ2M1220UCES
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, UNSEALED, WITH MA
8MQ2M1220UCES 数据手册
A B C D E F G H C.2; Validé MASS 2,54 18,25 11 Short receptacle (g) Male module 6,2 Female module 8,1 4 2,54 # 0,7 2,54 16,46 Max 14,20 Max Technical requirements 1,27 1- According to EN4165 2- Voltage proof test (Sea level) : - #22 > 1300 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #22 = 44 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap Tin plated area for version 046/046E/046S 2 BASIC SERIE 8MQ 2 M 20-22 R N E S Female module dimension - CountryJurisdiction & Control List FR NOT LISTED 2 = Serie 2 M = Module R = Male module delivered with contacts U = Female module delivered with contacts None = Without peripheral sealing E = With peripheral sealing 1 = = = = Pin Pin Pin Pin contact contact contact contact : : : : F Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 E ISS DATE Update of contact position -- Latest modification - by: N.AUFFRET 2 23536BH H.SIMIER Date:28/03/17 GAMME 8MQ General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM FORMAT D A3 CUSTOMER DRAWING MOD N $ MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 20-22 Scale SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) G 04/10/18 TITLE S = Delivered with protection cap None 046 046E 046S C Designed by: N, A, B, C, D = polarization (other dimensions are available for male and female module) 3 P/N : SEE TABLE Layout Dash = No grounding 22,4 Max SCALE 3/2 SCALE 3/2 1,27 3 2,54 2,54 P/N Marking on this face 15,05 Max H 5% 2,54 # 0,75 13,35 Max 4 Contact surface with panel # C SOURIAU DRG N° C008-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M1220UCES
1. 物料型号:文档中提到了型号“23536BH”。 2. 器件简介:文档描述了一种模块化连接器,包括公头和母头模块,以及它们与PCB的接触布局。 3. 引脚分配:文档中提到了引脚接触的配置,例如“Pin contact 046”、“Pin contact 046E”、“Pin contact 0465”等。 4. 参数特性:包括电压测试(>1300 V r.m.s.)、绝缘电阻(>5000 MΩ)、气候序列(-55°C/+175°C)、流体阻力(参照EN 4165-001标准)、接触保持力(#22 = 44 N)等。 5. 功能详解:文档提供了连接器的详细功能描述,包括其技术要求和材料规格。 6. 应用信息:文档提到了连接器的应用,如“MODULES WITH STRAIGHT PCB CONTACTS-LAYOUT20-22”,表明它适用于直线PCB接触的模块。 7. 封装信息:文档中提到了封装的尺寸和重量,例如公头模块重6.2克,母头模块重8.1克。
8MQ2M1220UCES 价格&库存
很抱歉,暂时无法提供与“8MQ2M1220UCES”相匹配的价格&库存,您可以联系我们找货
