8MQ2M0816UCS046E
8MQ2M0816UCS046E
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, UNSEALED, WITH FE
8MQ2M0816UCS046E 数据手册
A B C D E F G H C.2; Validé 3,81 Technical requirements 3 1- According to EN4165 2- Voltage proof test (Sea level) : - #20 > 1500 V r.m.s. - #22 > 1300 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #20 = 67 N - #22 = 44 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap 2 - CountryJurisdiction & Control List FR NOT LISTED 2 = Serie 2 Female module dimension M = Module R = Male module delivered with contacts U = Female module delivered with contacts None = Without peripheral sealing E = With peripheral sealing 1 = = = = Pin Pin Pin Pin contact contact contact contact : : : : G F Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 E ISS DATE Update of contact position -- Latest modification - by: N.AUFFRET 2 H.SIMIER Date:30/03/17 General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ GAMME 8MQ FORMAT D 23536BH MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 09-36 Scale SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H 04/10/18 TITLE S = Delivered with protection cap None 046 046E 046S C Designed by: N, A, B, C, D = polarization (other dimensions are available for male and female module) 3 P/N : SEE TABLE Layout Dash = No grounding 22,40 Max 6,6 ECHELLE 3/2 ECHELLE 3/2 Tin plated area for version 046/046E/046S BASIC SERIE 8MQ 2 M 09-36 R N E S 5 P/N Marking on this face 15,05 Max 16,46 Max (g) 4 14,20 Max 3,81 3,81 #22 : 4 Short receptacle 13,35 Max # 0,7 5% Female module 3,81 11 # Male module n 0,8 Max Contact surface with panel # 0,75 #20 : 18,25 n 0,65 Max MASS C SOURIAU DRG N° C010-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M0816UCS046E 价格&库存
很抱歉,暂时无法提供与“8MQ2M0816UCS046E”相匹配的价格&库存,您可以联系我们找货
