8MQ2M0412SNES
8MQ2M0412SNES
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, UNSEALED, WITH FE
8MQ2M0412SNES 数据手册
A B Short receptacle C 11 D 18,25 E F G H C.2; Validé Contact surface with panel MASS # 0,75 4,62 # 0,7 4,62 2,31 5% (g) Male module 8,6 Female module 10,3 4 P/N Marking on this face 14,2 Max 3,77 13,35 Max 3,77 4 2,31 # Technical requirements 3 15,05 Max 16,46 Max 1- According to EN4165 2- Voltage proof test (Sea level) : - #16 > 1500 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #16 = 110 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap Tin plated area for version 046/046E/046S BASIC SERIE 8MQ 2 M 08-16 R N E S Female module dimension 2 - CountryJurisdiction & Control List FR NOT LISTED 2 = Serie 2 M = Module R = Male module delivered with contacts U = Female module delivered with contacts None = Without peripheral sealing E = With peripheral sealing 1 = = = = Pin Pin Pin Pin contact contact contact contact : : : : G F Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 E ISS DATE Update of contact position -- Latest modification - by: N.AUFFRET 2 H.SIMIER Date:30/03/17 General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ GAMME 8MQ FORMAT D 23536BH MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 08-16 Scale SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H 04/10/18 TITLE S = Delivered with protection cap None 046 046E 046S C Designed by: N, A, B, C, D = polarization (other dimensions are available for male and female module) 3 P/N : SEE TABLE Layout Dash = No grounding 22,4 Max ECHELLE 3/2 ECHELLE 3/2 C SOURIAU DRG N° C011-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M0412SNES
1. 物料型号:文档中提到了多个型号,例如“23536BH”和“8MQ 2 08-16 M R N E S BASIC SERIE”。
2. 器件简介:文档描述了一种模块化连接器,包括公头和母头模块,以及短插座。
3. 引脚分配:文档中提到了不同的引脚接触类型,如“None”,“046”,“046E”,和“046S”,它们分别代表不同的电镀层。
4. 参数特性:包括最大尺寸、重量、技术要求等。例如,公头模块重量为8.6克,母头模块为10.3克。
5. 功能详解:文档详细描述了连接器的技术要求,如电压测试、绝缘电阻、气候序列、流体阻力等。
6. 应用信息:文档提到了连接器的应用,如与面板接触的表面尺寸、引脚保持力等。
7. 封装信息:提供了连接器的尺寸信息和极化选项,以及是否带有周边密封或保护帽。
8MQ2M0412SNES 价格&库存
很抱歉,暂时无法提供与“8MQ2M0412SNES”相匹配的价格&库存,您可以联系我们找货
