A
B
C
D
E
F
G
H
C.2; Validé
MASS
18,25
4
11
# 0,75
Short receptacle
3,475
10,25
13,35 Max
2
CountryJurisdiction
& Control List
FR
NOT LISTED
2 = Serie 2
R = Male module delivered with contacts
U = Female module delivered with contacts
None = Without peripheral sealing
E = With peripheral sealing
1
Gold plated, 0.8µm mini
Tin plated over gold - SnPb
Tin plated over gold - Sn100
Tin plated over gold - SAC305
E
ISS
DATE
Update of contact position
Latest modification - by:
N.AUFFRET
2
H.SIMIER
Date:30/03/17
General linear
Tolerances:
3/1
NPRDS / PROJECT
BE164803A
WWW.SOURIAU.COM
A3
CUSTOMER DRAWING
MOD N $
GAMME 8MQ
FORMAT
D
23536BH
MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 04-12
Scale
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
F
04/10/18
TITLE
(other dimensions are available S = Delivered with protection cap
for male and female module)
contact
contact
contact
contact
C
Designed by:
N, A, B, C, D = polarization
Pin
Pin
Pin
Pin
3
P/N : SEE TABLE
Layout
Dash = No grounding
ECHELLE 3/2
1- According to EN4165
2- Voltage proof test (Sea level) :
- #12 > 1500 V r.m.s.
3- Insulation resistance > 5000 M ^
4- Climatic sequence : -55°C/+175°C
5- Fluid resistance : See standard
EN 4165-001 (table 40)
6- Contact retention in insert :
- #12 = 110 N
7- Materials : Thermoplastic and silicone
8- Delivered with protection cap
Tin plated area for
version 046/046E/046S
BASIC SERIE 8MQ 2 M 04-12 R N E S
G
Female module
Technical requirements
M = Module
H
9
ECHELLE 3/2
2,975
3
16,46 Max
None
046
046E
046S
Male module
P/N Marking
on this face
15,05 Max
22,4 Max
(g)
4
2,975
3,475
Female module dimension
5%
# 0,7
14,2 Max
Contact surface
with panel
C
SOURIAU DRG N°
C012-8MQ-A
B
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“8MQ2M1220RNE”相匹配的价格&库存,您可以联系我们找货
