8MQ2M9901AA
8MQ2M9901AA
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    背板连接器 - ARINC 插件 引脚组件 16-22D
8MQ2M9901AA 数据手册
A B C D E F G H C.2; Validé MASS 18,25 4 11 # 0,75 Short receptacle 3,475 10,25 13,35 Max 2 - CountryJurisdiction & Control List FR NOT LISTED 2 = Serie 2 R = Male module delivered with contacts U = Female module delivered with contacts None = Without peripheral sealing E = With peripheral sealing 1 : : : : Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 E ISS DATE Update of contact position -- Latest modification - by: N.AUFFRET 2 H.SIMIER Date:30/03/17 General linear Tolerances: 3/1 NPRDS / PROJECT BE164803A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ GAMME 8MQ FORMAT D 23536BH MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 04-12 Scale SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) F 04/10/18 TITLE (other dimensions are available S = Delivered with protection cap for male and female module) contact contact contact contact C Designed by: N, A, B, C, D = polarization Pin Pin Pin Pin 3 P/N : SEE TABLE Layout Dash = No grounding = = = = ECHELLE 3/2 1- According to EN4165 2- Voltage proof test (Sea level) : - #12 > 1500 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #12 = 110 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap Tin plated area for version 046/046E/046S BASIC SERIE 8MQ 2 M 04-12 R N E S G Female module Technical requirements M = Module H 9 ECHELLE 3/2 2,975 3 16,46 Max None 046 046E 046S Male module P/N Marking on this face 15,05 Max 22,4 Max (g) 4 2,975 3,475 Female module dimension 5% # 0,7 14,2 Max Contact surface with panel # C SOURIAU DRG N° C012-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M9901AA
1. 物料型号:8MQ M 104-12 R N E S BASIC SERIE 2. 器件简介:文档描述了一种具有直接触点的模块,适用于PCB连接,有男/女模块之分,并且有多种材料和表面处理选项。 3. 引脚分配:文档中提到了不同的引脚接触类型,包括无周边密封和有周边密封的选项。 4. 参数特性: - 根据EN4165标准 - 电压测试:#12>1500Vr.m.s. - 绝缘电阻>5000 MΩ - 气候序列:-55°C/+175°C - 流体阻力:见标准EN4165-001(able40) - 接触保持力:#12=110N - 材料:热塑性塑料和硅胶 - 提供保护帽 5. 功能详解:文档提供了模块的详细尺寸和布局信息,以及如何根据不同的配置选择模块。 6. 应用信息:适用于需要直接触点的PCB连接应用。 7. 封装信息:提供了不同引脚接触的选项,包括金镀、锡镀、锡铅镀等。
8MQ2M9901AA 价格&库存
很抱歉,暂时无法提供与“8MQ2M9901AA”相匹配的价格&库存,您可以联系我们找货
