8MQ2M2022UBS046S
8MQ2M2022UBS046S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    MQUICK MODULE, UNSEALED, WITH MA
8MQ2M2022UBS046S 数据手册
n 0,65 Max 4,4 13,35 Max 3,5 3,5 3 Tin plated area for version 046/046E/046S 2,62 - 2 1 Gold plated, 0.8µm mini Tin plated over gold - SnPb Tin plated over gold - Sn100 Tin plated over gold - SAC305 SOURIAU shall not be liable for any non-conformity or damage due to a usethe of Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H G F E 04/10/18 ISS DATE TITLE S = Delivered with protection cap : : : : E Designed by: None = Without peripheral sealing E = With peripheral sealing contact contact contact contact 9,7 ECHELLE 3/2 2 P/N : SEE TABLE N, A, B, C, D = polarization Pin Pin Pin Pin Female module CountryJurisdiction & Control List FR NOT LISTED R = Male module delivered with contacts U = Female module delivered with contacts = = = = 8 1- According to EN4165 2- Voltage proof test (Sea level) : 3 - #22 > 1300 V r.m.s. - #16 > 1500 V r.m.s. 3- Insulation resistance > 5000 M ^ 4- Climatic sequence : -55°C/+175°C 5- Fluid resistance : See standard EN 4165-001 (table 40) 6- Contact retention in insert : - #22 = 44 N - #16 = 110 N 7- Materials : Thermoplastic and silicone 8- Delivered with protection cap 2,62 Layout Dash = No grounding None 046 046E 046S Male module ECHELLE 3/2 2,62 M = Module (other dimensions are available for male and female module) (g) 4 2 = Serie 2 22,40 Max 5% Technical requirements BASIC SERIE 8MQ 2 M 99-01 R N E S Female module dimension # P/N Marking on this face #22 : 4,4 14,20 Max n 1,25 Max 4 #16 : 15,05 Max 2,62 16,46 Max A Short receptacle B # 0,7 C # 0,75 D 11 E F G H E.2; Validé 18,25 Contact surface with panel MASS Update of contact position - Latest modification - by: N.AUFFRET H.SIMIER Date:11/08/16 BASIC SERIE 8MQ Scale General linear Tolerances: 2/1 NPRDS / PROJECT BE133701A WWW.SOURIAU.COM A3 CUSTOMER DRAWING MOD N $ MODULES WITH STRAIGHT PCB CONTACTS - LAYOUT 99-01 FORMAT D 23536BH C SOURIAU DRG N° C013-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2M2022UBS046S
1. 物料型号:文档中没有明确列出物料型号,但提到了型号“8MQ 2 M 99-01 R N E”和“23536BH”。
2. 器件简介:文档描述了一种连接器模块,包括公头和母头模块,以及它们的重量和尺寸。
3. 引脚分配:文档中提到了引脚接触的类型,例如“Pin contact 046”、“046E”、“046S”,但没有提供详细的引脚分配图。
4. 参数特性: - 电压测试:#22 > 1300 V r.m.s., #16 > 1500 V r.m.s. - 绝缘电阻:>5000 MΩ - 气候序列:-55°C/+175°C - 流体阻力:参考标准EN 4165-001 (table 40) - 接触保持力:#22 = 44 N, #16 = 110 N - 材料:热塑性材料和硅橡胶 - 带有保护帽
5. 功能详解:文档提供了连接器的技术要求,包括电压证明测试、绝缘电阻、气候序列、流体阻力、接触保持力等。
6. 应用信息:文档提到了连接器的应用环境,如气候序列和流体阻力标准。
7. 封装信息:文档提供了连接器的尺寸信息,如最大长度、宽度等,以及不同的接触类型和材料。
8MQ2M2022UBS046S 价格&库存
很抱歉,暂时无法提供与“8MQ2M2022UBS046S”相匹配的价格&库存,您可以联系我们找货
