8MQ2A1C25A
8MQ2A1C25A
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    连接器 编码板 用于 8MQ2 系列 红色
8MQ2A1C25A 数据手册
A B C D E F G H A.2; Validé COLOUR CODING PLATE General dimensions Polarization N (Black) Polarization A 23,25-23,35 6,47-6,57 6,47-6,57 4,23-4,33 4,23-4,33 4,23-4,33 6,47-6,57 6,47-6,57 1,99-2,09 18,2 min. 20,25-20,35 10,12-10,18 4 20,9 min. (Red) Polarization B (Blue) Polarization C (Green) 2,55 max. A 0,90-1,00 5,35-5,45 5,35-5,45 3,11-3,21 3,11-3,21 5,35-5,45 3,11-3,21 Polarization D (Yellow) Polarization E (Pink) Polarization F (Clear green) Polarization G (Clear grey) 10,12-10,18 3 Detail 0,90-1,00 4 4,23-4,33 1,99-2,09 1,99-2,09 4,23-4,33 1,99-2,09 3 4,23-4,33 0,04-0,14 1,99-2,09 1,90-2,00 A 2 DETAIL ECHELLE 3/1 R0,55-0,65 1,16-1,26 Technical Characteristics Material& finishes MASS 5,35-5,45 0,90-1,00 3,11-3,21 1,2 g max. Climatic Operating temperature range : -55°C to +175°C Salt spray (corrosion) : 500 hrs Mechanical Compliant EN4165 - BACC65 - ARINC 809 Adapted to short and extended receptacles 1 Environmental A BASIC SERIE 8MQ 2 A 1 C 25 N G 2 = Serie 2 TITLE A = Accessory 1 = Number of cavities -- 5,35-5,45 2 24230S Latest modification - by: N.AUFFRET -- Date:09/08/17 BASIC SERIE 8MQ - EN4165 General linear Tolerances: NPRDS / PROJECT BE133702A WWW.SOURIAU.COM FORMAT D A3 CUSTOMER DRAWING MOD N $ COLOUR CODING PLATE - ACCESSORY 3/2 N, A, B, C, D, E, F, G = polarization E 3,11-3,21 First issue Scale C = Colour coding plate F DATE Designed by: SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) H 09/08/17 ISS 25 = Based on standard EN4165 RoHS and REACH compliant Fluid resistance : See standard EN 4165-001 (table 40) 5,35-5,45 P/N : SEE TABLE CountryJurisdiction & Control List FR NOT LISTED Material : Composite 5,35-5,45 C SOURIAU DRG N° C030-8MQ-A B This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
8MQ2A1C25A 价格&库存
很抱歉,暂时无法提供与“8MQ2A1C25A”相匹配的价格&库存,您可以联系我们找货
