UTL6TH103G1S
UTL6TH103G1S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    4(3 + PE) 针位圆形连接器 插头外壳 面板安装
UTL6TH103G1S 数据手册
36,25 0,7 LOCKING LATCH SHELL 26,1 0,5 7 SEALING IN UNMATED CONDITIONS OPEN FACE SEALING POLLUTION DEGREE CORROSION SALT SPRAY FLAMMABILITY OUTDOOR SUITABILITY (UV RESIST) SCOOP PROOF 9,5 0,5 1,4 0,05 UL94 UL746C -40°C TO 105°C 500 MATE / UNMATE CYCLES IP68 1BAR DURING 1WEEK IP69K IP67 WITH CAPS IP67 WITH R*M25* CONTACTS 4 MIN 1000H MATERIAL RATING: 5VA MATERIAL RATING: (f1) NOMINAL CURRENT IEC61984 NOMINAL VOLTAGE NOMINAL VOLTAGE UL1977 IEC61984 IEC61984 600V 250VAC 4KV 4 FOR CLASS II 500VAC 6KV 4 FOR CLASS I CONNECTOR BREAKING CAPACITY UL1977 IEC61984 277V 13A WITH AWG14/16 WIRES 250VAC 13A 4KV 4 6 16,45+0,1 0 5 5 x 1 MALE GROUND CONTACT 4 O'RING UTL10SEAL (*) A-A COUPE ECHELLE 2/1 4 REAR NUT UTL10NUT (*) THREADED PLUG UTL6TH103G1S (*) (**) x3 FEMALE PHASE CONTACTS 3 3 PANEL THICKNESS 6mm MAX CountryJurisdiction & Control List FR NOT LISTED VIEW IN MOUNTED AND MATED CONDITIONS P/N : 40,25 1 2 B 23/02/18 ISS DATE Designed by: TITLE Scale 1/1 A-A UTL5 103G1 S Update -- Latest modification - by: R.M. R.M. Date: 04/04/17 1 SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) G F E D C FORMAT A2 CUSTOMER DRAWING MOD N $ 2 PANEL PLUG SIZE 10 UTL CONNECTOR General linear Tolerances: WWW.SOURIAU.COM COUPE ECHELLE 2/1 H 7 IP2X 16A WITH AWG14 WIRE / 13A WITH AWG16 WIRE 16A WITH 2.5MM² WIRE / 13A WITH 1.5MM² WIRE AT 60°C 1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING 2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT 3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES 4. CONTACTS TO BE ORDERED SEPARETELY. 5. WARNING: PHASE CONTACTS ARE FEMALE VERSION AND GROUND CONTACT IS MALE VERSION 6. UNIT IN MM 7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm 8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY 9. (**) : FOR x100 pcs BULK PACKAGING ADD SUFFIX B -> UTL6TH103G1SB 17,2+0,2 0 22+0,2 0 IEC61984/UL1977 IEC61984 IEC60529 DIN40050 IEC60529 IEC60529 IEC61984 8 ROHS COMPLIANT ECHELLE 3/1 PANEL CUT OUT 20.5 g IEC60529 UL1977 NUT O'RING 5% ELECTRICAL TOUCH PROOF NOMINAL CURRENT 6 MATING SEAL # 0.3 # BLACK POLYAMID NBR BLACK ANODIZED ALUMINIUM ALLOY SILICON STAINLESS STEEL PERFORMANCES CHARACTERISTICS MECHANICAL TEMPERATURE CLASS DURABILITY SEALING IN MATED CONDITIONS 25,6 0,3 22,25 MASS MATERIALS SHELL O'RING NUT MATING SEAL LOCKING LATCH 16,1 0,3 12,5 0,5 A WIRING FACE B C D E F G H MATING FACE 8 B.5; Validé NOTES SOURIAU DRG N° UTL1-0088A-C B NPRDS / PROJECT IC155105C This document is the property of SOURIAU It must not be reproduced or communicated without permission SHEET 1 / 1 A 1
UTL6TH103G1S 价格&库存
很抱歉,暂时无法提供与“UTL6TH103G1S”相匹配的价格&库存,您可以联系我们找货
