36,25 0,7
LOCKING LATCH
SHELL
26,1 0,5
7
SEALING IN UNMATED CONDITIONS
OPEN FACE SEALING
POLLUTION DEGREE
CORROSION SALT SPRAY
FLAMMABILITY
OUTDOOR SUITABILITY (UV RESIST)
SCOOP PROOF
9,5 0,5
1,4 0,05
UL94
UL746C
-40°C TO 105°C
500 MATE / UNMATE CYCLES
IP68 1BAR DURING 1WEEK
IP69K
IP67 WITH CAPS
IP67 WITH R*M25* CONTACTS
4
MIN 1000H
MATERIAL RATING: 5VA
MATERIAL RATING: (f1)
NOMINAL CURRENT
IEC61984
NOMINAL VOLTAGE
NOMINAL VOLTAGE
UL1977
IEC61984
IEC61984
600V
250VAC 4KV 4 FOR CLASS II
500VAC 6KV 4 FOR CLASS I
CONNECTOR BREAKING CAPACITY
UL1977
IEC61984
277V 13A WITH AWG14/16 WIRES
250VAC 13A 4KV 4
6
16,45+0,1
5
x 1 MALE
GROUND
CONTACT
4
O'RING
UTL10SEAL (*)
A-A
COUPE
ECHELLE 2/1
4
REAR NUT
UTL10NUT (*)
THREADED PLUG
UTL6TH103G1S (*) (**)
x3 FEMALE
PHASE
CONTACTS
3
3
PANEL THICKNESS
6mm MAX
CountryJurisdiction
& Control List
FR
NOT LISTED
VIEW IN MOUNTED AND
MATED CONDITIONS
P/N :
40,25 1
2
B
23/02/18
ISS
DATE
Designed by:
TITLE
Scale
1/1
A-A
UTL5 103G1 S
Update
Latest modification - by:
R.M.
R.M.
Date: 04/04/17
1
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
G
F
E
D
C
FORMAT
A2
CUSTOMER DRAWING
MOD N $
2
PANEL PLUG SIZE 10
UTL CONNECTOR
General linear
Tolerances:
WWW.SOURIAU.COM
COUPE
ECHELLE 2/1
H
7
IP2X
16A WITH AWG14 WIRE / 13A
WITH AWG16 WIRE
16A WITH 2.5MM² WIRE / 13A
WITH 1.5MM² WIRE AT 60°C
1. COUNTERPART REFERENCE UTL RECEPTACLE OR FREE HANGING
2. CONNECTORS ARE DELIVERED AS PRE-ASSEMBLED KIT
3. CONNECTOR BLOCKS ACCEPTS TRIM TRIO CONTACTS #16, R*M* OR S*M* TYPES
4. CONTACTS TO BE ORDERED SEPARETELY.
5. WARNING: PHASE CONTACTS ARE FEMALE VERSION AND GROUND CONTACT IS MALE VERSION
6. UNIT IN MM
7. MAX WIRE INSULATOR DIAMETER : Ø3.7mm
8. (*) : OPTIONAL ORDERING PART NUMBERS TO BE ORDERED SEPARATELY
9. (**) : FOR x100 pcs BULK PACKAGING ADD SUFFIX B -> UTL6TH103G1SB
17,2+0,2
IEC61984/UL1977
IEC61984
IEC60529
DIN40050
IEC60529
IEC60529
IEC61984
8
ROHS COMPLIANT
ECHELLE 3/1
PANEL CUT OUT
20.5 g
IEC60529
UL1977
NUT
O'RING
5%
ELECTRICAL
TOUCH PROOF
NOMINAL CURRENT
6
MATING SEAL
# 0.3
BLACK POLYAMID
NBR
BLACK ANODIZED ALUMINIUM ALLOY
SILICON
STAINLESS STEEL
PERFORMANCES CHARACTERISTICS
MECHANICAL
TEMPERATURE CLASS
DURABILITY
SEALING IN MATED CONDITIONS
25,6 0,3
22,25
MASS
MATERIALS
SHELL
O'RING
NUT
MATING SEAL
LOCKING LATCH
16,1 0,3
12,5 0,5
A
WIRING FACE
B
C
D
E
F
G
H
MATING FACE
8
B.5; Validé
NOTES
SOURIAU DRG N°
UTL1-0088A-C
B
NPRDS / PROJECT
IC155105C
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SHEET
1 / 1
A
1
很抱歉,暂时无法提供与“UTL5103G1S”相匹配的价格&库存,您可以联系我们找货
