SpectraBright Series
0606 Package Size
SMD RGB and Bi-Color LEDs
Space-Saving, Multi-Status Indication and Multicolor/Brightness
Options Enhance Design Possibilities.
Application
• Automated Guided Vehicles
• EV Charging Stations
• Navigations Systems
• Industrial Controls
• IoT/Smart Home Systems
• Medical Devices
• Mil-Aero
• Telecom
• Status Indicator
Key Features
• Package size 0606
• Tape and reel packaged for high-speed auto insertion
• Through-hole, SMD
• Clear lens
• Tri-color: RGB
• Bi-color: Red/Green
• Enjoy high visibility in a range of working environments thanks to a wide, 120° viewing angle
• High and low intensity options available. Mcd ranging from 15 to 160 mcd
• For custom LED color contact VCC
• MIL-STD-750 D:1026, and MIL-STD-883 D:1005 Standards
• RoHS, REACH Compliant
vcclite.com | 1.800.522.5546
SpectraBright 0606 | 11/22 | Page 1 of 10
Ordering Data
Part Number
Color
Brightness
Lens Type
Viewing Angle (deg)
Mil
Size L x W (mm)
Height (mm)
SB0606WC01-RGB
RGB
High
Water Clear
120
1616
1.6 x 1.6
0.6
SB0606WC02-RGB
RGB
Low
Water Clear
120
1616
1.6 x 1.6
0.6
SB0606WC01-RG
Red/Green
High
Water Clear
120
1616
1.6 x 1.6
0.6
SpectraBright 0606 | 11/22 | Page 2 of 10
Product Dimensions
SB0606WC01-RG
SB0606WC02-RGB
YG
SB0606WC01-RGB
Notes:
1. All dimensions are in mm
2. Tolerance is ±0.1 mm unless otherwise noted
3. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice.
SpectraBright 0606 | 11/22 | Page 3 of 10
Product Specifications
Color
Dominant Wavelength
(nm) @ IF=20mA
Luminous Intensity
(mcd) IF=20mA
Forward Voltage
(Vf) @ If=20mA
Viewing
Angle
(deg)
SB0606WC01-RGB
RGB
R=635, G=518, B=460
R=160, G=600, B=125
R=2V, G=3V, B=3V
120
SB0606WC02-RGB
RGB
R=635, G=518, B=460
R=35, G=75, B=20
R=3V, G=3V, B=3V
120
SB0606WC01-RG
Red/Green
R=625, G=568
R=160, G=40
R=2V, G=2V
120
Part
Number
SpectraBright 0606 | 11/22 | Page 4 of 10
SB0606WC01-RG
SpectraBright 0606 | 11/22 | Page 5 of 10
SB0606WC02-RGB
SpectraBright 0606 | 11/22 | Page 6 of 10
SB0606WC01-RGB
SpectraBright 0606 | 11/22 | Page 7 of 10
Precautions
Reliability Test
Classification
Test Item
Test Condition
Test Time
Reference Standard
Operation Life
25ma Ta= Under Room
Temperature As Per Datasheet
Maximum Rating
1000 HRS
(-24 HRS, +72 HRS)
MIL-STD-750
D:1026
MIL-STD-883
D:1005
High Temperature,
High Humidity Storage
IR-Reflow In-Board, 2 Tlmes
Ta=85? ˚C RH=85%IR-Reflow
In-Board, 2 Times Ta=85? ˚C
RH=85%
1000 HRS
(±2 HRS)
JESD22-A101
High Temperature
Storage
Ta=105±5˚C
1000 HRS
(-24 HRS, +72 HRS)
MIL-STD-883
D:1008
JIS C 7021:B-10
Low Temperature
Storage
Ta=-40±5˚C
1000 HRS
(-24 HRS, +72 HRS)
JIS C 7021:B-10
Temperature Cycling
100˚C ~ 25˚C ~ -40˚C ~ 25˚C
30mins 5mins 30mins 5mins
100/Cycles
MIL-STD-202F:107D
MIL-STD-750D:1051
Thermal Shock
100 ± 5˚C ~ -40˚C ± 5˚C
10mins
10mins
100/Cycles
MIL-STD-202F:107D
MIL-STD-750D:1051
ReflowPb Free Process
260˚C: 10
Peak temperature range 260˚C
10s max
MIL-STD-750
D:2031.2
J-STD-020C
Endurance Test
Soldering Profile
SpectraBright 0606 | 11/22 | Page 8 of 10
Precautions
Soldering
• Reflow soldering should not be done more than 2 times.
• Manual soldering is only suggested on repair and rework. The maximum soldering temperature should not exceed
300˚C within 3 sec. And the maximum capacity of soldering iron is 30W in power.
• During the soldering process, do not touch the lens at high temperature.
• After soldering, any mechanical force on the lens or any excessive vibration shall not be accepted to apply, also the
circuit board shall not be bent as well.
Application
• A LED is a current-operated device. The slight shift of voltage will cause big change of current, which will damage
LEDs. Customer should use resistors in series for the Over-Current-Proof.
• In order to ensure intensity uniformity on multiple LEDs connected in parallel in
an application, it is recommended to use individual resistor separately, as shown in Circuit A below. The brightness of
each LED shown in Circuit B might appear difference due to the differences in the I-V characteristics of those LEDs
Circuit model A
Circuit model B
• High temperature may reduce LEDs’ intensity and other performances, so keeping it away from heat source to get
good performance is necessary.
Rank Tolerance
REF / VF: ±0.02V
CAT / IV: ±10%
X / Y: ±0.005
Storage
• Before opening original package, it is recommended to store them in the following environment: Temperature:
5°C~30°C,Humidity: 85%RH max. When the inventory over 3 months,Should be done before treatment using
dehumidification, Temperature: 60°C/8 hours.
• 5~ 30˚C ; 60% after opening original package, the storage ambient for the LEDs should be in 5~30˚C temperature and
60% or less relative humidity.
• In order to avoid moisture absorption, it is recommended that the LEDs that out of the original package should be
stored in a sealed container with appropriate desiccant, or in desiccators with nitrogen ambient.
• The LEDs should be used within 168hrs (7days) after opening the package. Once been mounted, soldering should be
quick.
• If the moisture absorbent material (silica gel) has faded away or the LEDs stored out of original package for more than
168hrs (7 days), baking treatment should be performed using the conditions: 60˚C at least 24 hours.
SpectraBright 0606 | 11/22 | Page 9 of 10
Tape and Reel Specifications
YG
4000 pieces per reel
Notes:
Compliances and Approvals
SpectraBright 0606 | 11/22 | Page 10 of 10
很抱歉,暂时无法提供与“SB0606WC01-RGB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+3.347444000+0.43185
