C16-32.000-8-1515-X-R
    AKER(安碁科技)
    SMD1612_4P
    无源晶振 32MHz ±15ppm 8pF 100Ω -40℃~+85℃
C16-32.000-8-1515-X-R 数据手册
Specification Title: No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC All dimensions are millimeters. CAD: Review: Appr: Page: Microprocessor Crystal Unit Low Profile 1.6 x 1.2 millimeter Surface Mount - 4 Pad General Product Specification TCR EG JL 1/4 Date: August 01, 2022 Series Name: C16 Series Electrical Specifications: Frequency Range Mode of Oscillation Fundamental 24.000 to 60.000 MHz 24.000 to 60.000 MHz Standard ±30 ±50 Frequency Tolerance at 25°C ±20 Optional PPM Max (Note 1) ±15 ±10 Standard ±50 ±100 ±30 Frequency Stability over Temperature Range Optional ±25 PPM Max (Note 1) ±20 ±15 Operating Temperature Range Standard -20 to +70 Extended -40 to +85 -40 to +125 Storage Temperature Range ℃ -55 to +125 Aging ±3 Load Capacitance 6 to 47 and Series Resonance Shunt Capacitance 3.0 Equivalent Series Resistance(ESR) pF See ESR Table Ohm 100 uW Max 500 at 100 Vdc ± 15 Vdc M Ohm Drive Level Insulation Resistance PPM Max/Year Frequency Range and ESR Values: Frequency Range in MHz ESR Ohm Max Mode of Operation 24.000 to 29.999 150 Fundamental 30.000 to 31.999 100 Fundamental 32.000 to 39.999 80 Fundamental 40.000 to 60.000 60 Fundamental Ltr Revisions RoHS Compliant Pb - Lead Free www.aker-usa.com Date Appr Mechanical Outline: < S ID E > 1 .6 ± 0 .1 5 C e ra m ic B ase 1.2 ± 0.15 #4 M etal L id #3 AKER #1 #2 0 .4 M ax . 1 .0 5 0 .5 #2 #4 #3 0 .5 # 2 :G N D 0.6 0.4 0.8 0.3 #1 0 .7 5 # 4 :N C Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date: August 01, 2022 P/N: www.aker-usa.com C16 Series Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: August 01, 2022 P/N: www.aker-usa.com C16 Series How to build a Part Number: Series Package C 16 Parameter 1.6 x 1.2 mm - 4 Pad - Frequency 24.000 to 60.000 MHz - Load Capacitance 6 10 12 16 18 20 32 S 6pF 10 pF 12 pF 16 pF 18 pF 20 pF 32 pF Series - Standard Frequency Tolerance (Note 1) Option Standard Frequency Stability (Note 1) Option 30 25 20 15 10 50 100 30 25 20 15 ±30PPM ±25PPM ±20PPM ±15PPM ±10PPM ±50PPM ±100PPM ±30PPM ±25PPM ±20PPM ±15PPM - Standard Option Temperature Range Option Option See Notes X X1 X2 Packaging M R R3 -20 to +70 ℃ -40 to +85 ℃ -40 to +125 ℃ -40 to +105 ℃ 250pcs Reel 1000pcs Reel 3000pcs Reel Part Number Example: C16-40.000-10-3030-X-R C16- 1.6 x 1.2 mm SMD Seam Seal Crystal Unit - 4 Pad 40.000 MHz Nominal Frequency 10 pF Load Capacitance 3030: ±30 PPM Frequency Tolerance and ±30 PPM Frequency Stability -40 to +85℃ Temperature Range R: Tape and Reel Packaging - 1000pcs Notes: 1- Frequency Tolerance and Stability options are limited due to physical size. * ±10 PPM Temperature Stability is only available from -30 to +85° C. 2- Standard Temperature Range does not need to be included in Part Number description. 3- Product is shipped in Tape and Reel configuration. 4- Quantities less than 250pcs are shipped in tape only. 5- Specification subject to change without notice. Page: 4/4 Date: August 01, 2022 P/N: www.aker-usa.com C16 Series
C16-32.000-8-1515-X-R 价格&库存
很抱歉,暂时无法提供与“C16-32.000-8-1515-X-R”相匹配的价格&库存,您可以联系我们找货
  • 1+6.092631+0.79203
  • 10+5.2763710+0.68591
  • 25+4.9940425+0.64921
  • 50+4.7876850+0.62239
  • 100+4.58921100+0.59659
  • 250+4.34017250+0.56421
  • 500+4.16070500+0.54088
库存:8779
  • 1000+3.988561000+0.51850
  • 2000+3.823602000+0.49706
  • 3000+3.730323000+0.48493
  • 5000+3.616115000+0.47009
  • 7000+3.542817000+0.46056
  • 10000+3.4667610000+0.45067
库存:8779
