S7A3305-125.000-P-R
S7A3305-125.000-P-R
    AKER(安碁科技)
    SMD6
    振荡器 125 MHz LVPECL XO(标准) 3.3V 启用/禁用 6-SMD,无引线
S7A3305-125.000-P-R 数据手册
Specification Title: Clock Oscillator LVPECL - Complimentary Output 7.0 x 5.0 millimeter Surface Mount General Product Specification No.11-3 Jianguo Rd., Tanzi Dist., 42760 Taiwan All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 Date: August 01,2022 Part Number: S7A LVPECL Series Electrical Specifications: Frequency Range 13.500 ~ 800.000 MHz Frequency Stability ±25 ~ ±100 ppm ±3 ppm Max. Aging per Year Standard -20 ~ +70 Extended -40 ~ +85 Operating Temperature Range °C -55 ~ +125 Storage Temperature Range 2.5 ± 5% 3.3 ± 5% VDD 70 70 mA Max. Logic High (Voh) 1.475 2.275 VDD Min. Logic Low (Vol) 1.095 1.680 VDD Max. Supply Voltage Input Current Output Voltage Output Symmetry (Duty Cycle) 45 ~ 55 Output Type LVPECL 50 Output Load ( Connect to VDD - 2V ) Rise and Fall Time % ohm 13.500 to 99.999MHz 1.0 1.0 100.000 to 160.000MHz 0.5 0.5 160.001 to 800.000MHz 0.5 0.5 ns Max. Tri-State Enable-Disable Function Input Enable Voltage 1.75 2.31 VDD Min. Input Disable Voltage 0.75 0.99 VDD Max. Phase Jitter (12 KHz to 20 MHz) 13.500 to 99.999MHz 1 100.000 to 160.000MHz 1 160.001 to 800.000MHz 2 ps Max. RMS Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage change, output load change, shock, vilbration, and 1st year aging at +25°C. Ltr Revisions RoHS Compliant Pb - Lead Free www.aker-usa.com Date Appr Mechanical Outline and Solder Pad Layout: 7.0 ± 0.15 5.0 ± 0.15 #6 #5 Ceramic Base Metal Lid #4 AKER #1 #2 #3 1.4 Max. 5.08 5.08 #2 #3 #6 #5 #4 2.0 1.17 4.20 3.63 #1 1.4 2.54 Pin Connection PIN No. Enable/Disable Function PIN #1 PIN #4 & #5 HIGH or OPEN Operating LOW High Impedance Connection #1 Enable/Disable #2 NC #3 GND #4 Output - Q #5 Output - QN #6 VDD 1.8 Package is Seam Sealed Ceramic-Metal. Terminator Pads are Ni/Au. Dimensions are millimeters. Page: 2/4 Date : August 01,2022 www.aker-usa.com P/N: S7A LVPECL Series 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B B-B SECTION 7.9 16.0 AKER AKER AKER AKER A 7.5 Pin #1 A B 1.7 8.0 2.0 5.4 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : August 01,2022 www.aker-usa.com P/N: S7A LVPECL Series How to build a Part Number: Series Package S 7A Parameter 7.0 x 5.0 mm - 6 Pad Supply Voltage 33 25 +3.3 VDD ± 5% +2.5 VDD ± 5% Temperature Stability 10 05 025 ±100 ppm ±50 ppm ±25 ppm - Frequency 13.500~800.000 MHz - Output Load P LVPECL - Temperature Range See Notes X -20 ~ +70 °C -40 ~ +85 °C - Packaging M R 250pcs Reel 1000pcs Reel Part Number Example: S7A3305-156.250-P-X-R S7A: 7.0 x 5.0 mm SMD Package - 6 Pad 33: +3.3±5% VDD Supply Voltage 05: ±50 ppm Temperature Stability 156.250 MHz Nominal Frequency P: LVPECL Output X: -40 ~ + 85°C Extended Temperature Range R: Tape and Reel Packaging - 1000pcs Reel Notes: 1- Standard Duty Cycle and Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 250pcs are shipped in tape only. 4- Specification subject to change without notice. Page: 4/4 Date : August 01,2022 www.aker-usa.com P/N: S7A LVPECL Series
S7A3305-125.000-P-R 价格&库存
很抱歉,暂时无法提供与“S7A3305-125.000-P-R”相匹配的价格&库存,您可以联系我们找货
S7A3305-125.000-P-R
  • 1000+19.740541000+2.46990
  • 2000+18.927202000+2.36814
  • 3000+18.467393000+2.31061
库存:1000
S7A3305-125.000-P-R
  • 1+30.047871+3.75953
  • 10+26.1276610+3.26905
  • 25+24.7113025+3.09183
  • 50+23.6878150+2.96378
  • 100+22.70839100+2.84123
  • 250+21.47647250+2.68710
  • 500+21.44844500+2.68359
库存:1000
