TX22-18010S-26.000-X-R
    AKER(安碁科技)
    SIP4
    振荡器 26 MHz 削峰正弦波 TCXO 1.8V 启用/禁用 4-SMD,无引线
TX22-18010S-26.000-X-R 数据手册
Specification Title: Temperature Compensated Crystal Oscillator No.11-3 Jianguo Rd., T.E.P.Z. 42760 Taiwan, ROC All dimensions are millimeters. CAD: TCR Review: EG Appr: JL Page: 1/4 TCXO - Ceramic Package 2.5 x 2.0 millimeter Surface Mount Date: August 01,2022 Part Number: TX22 Series Electrical Specifications: Frequency Range 10.000 to 52.000 Frequency Tolerance ±2.0 Frequency Stability vs. Operating Temperature ±0.5 ~ ±2.0 Frequency Stability vs. Supply Voltage Change ±0.2 Frequency Stability vs. 10% Load Change ±0.2 Aging per Year ±1.0 Operating Temperature Range MHz Standard -20 to +70 Extended -40 to +85 Storage Temperature Range ppm Max. °C -55 to +125 1.8 ± 5% 2.5 ± 5% Supply Voltage VDC 3.3 ± 5% 1.68 ~ 3.63 Input Current 2.5 mA Max. Output Level 0.8 Vp-p Min. Output Waveform Clipped Sinewave Output Load Phase Noise 10KΩ // 10pF @100Hz Offset -114 @1KHz Offset -131 @10KHz Offset -148 Start Up Time 2 Ltr Revisions RoHS Compliant Pb - Lead Free www.aker-usa.com dBc/Hz Typ. ms Max. Date Appr Mechanical Outline and Solder Pad Layout: 2.5 ± 0.15 2.0 ± 0.15 #4 Ceramic Base Metal Lid #3 AKER #1 #2 0.95 Max. 0.95 1.625 #4 #3 0.575 0.675 0.9 #2 0.65 #1 1.225 1.0 PIN No. Connection #1 NC / GND #2 GND #3 Output #4 VDC Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. Page: 2/4 Date : August 01,2022 P/N: TX22 Series www.aker-usa.com 1.5 2.0 1.75 Carrier Tape Dimensions: 4.0 B-B SECTION AKER AKER AKER AKER AKER AKER AKER AKER A 2.75 Pin #1 A 8.0 3.5 B B 1.0 4.0 0.8 2.25 A-A SECTION Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date : August 01,2022 P/N: TX22 Series www.aker-usa.com How to build a Part Number: Series TX Parameter Package 22 2.5 x 2.0 mm - Supply Voltage Temperature Stability Output Waveform 18 1.8 VDC ± 5% 25 2.5 VDC ± 5% 33 3.3 VDC ± 5% M 1.68 ~ 3.63 VDC 005 ±0.5 ppm 010 ±1.0 ppm 020 ±2.0 ppm S Clipped Sinewave - Frequency 10.000~52.000 MHz - Temperature Range See Notes -20 to +70 °C X -40 to +85 °C - Packaging R 1000pcs Reel R3 3000pcs Reel Part Number Example: TX22-3320S-26.000-X-R TX22: 2.5 x 2.0 mm SMD Package 33: +3.3 VDC Supply Voltage 020: ±2.0 ppm Temperature Stability S: Clipped Sinewave Output 26.000 MHz Nominal Frequency X: -40 to + 85°C Temperature Range R: Tape and Reel Packaging Notes: 1- Standard Temperature Range do not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. 3- Quantities less than 1000 pieces are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date : August 01,2022 P/N: TX22 Series www.aker-usa.com
TX22-18010S-26.000-X-R 价格&库存
很抱歉,暂时无法提供与“TX22-18010S-26.000-X-R”相匹配的价格&库存,您可以联系我们找货
  • 1000+12.328601000+1.54253
  • 2000+11.819942000+1.47889
  • 3000+11.532363000+1.44291
  • 5000+11.180225000+1.39885
  • 7000+10.954357000+1.37059
库存:1633
  • 1+18.790871+2.35108
  • 10+16.3204610+2.04199
  • 25+15.4335725+1.93102
  • 50+14.7963850+1.85130
  • 100+14.18446100+1.77473
  • 250+13.41414250+1.67835
  • 500+12.85965500+1.60898
库存:1633
