74009 BK002
74009 BK002
    ALPHAWIRE(阿尔法电线)
    8(4 对双绞线) 芯 多线对,Cat5e 线缆 黑色 22 AWG 500.0'(152.4m)
74009 BK002 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 74009 Construction Diameters (In) 1) Component 1 4 X 1 PAIR a) Conductor 22 (SOLID) AWG Bare Copper 0.026 b) Insulation 0.011" Wall, Nom. Polyolefin 0.048 Pair (1) Color(s) Pair Color Pair Color 1 BLUE WHITE/BLUE 3 GREEN WHITE/GREEN 2 ORANGE 4 WHITE/ORANGE BROWN WHITE/BROWN Color c) Pair 2/Cond Cabled Together (1) Twists: Staggered Lays 2) Cable Assembly 4 Components Cabled a) Twists: 4.0 Twists/foot (min) 3) Jacket 0.043" Wall, Nom.,PVC a) Color(s) BLACK b) Ripcord 1 End 810 Denier Nylon c) Print ALPHA WIRE-* P/N 74009 4PR 22 AWG VERIFIED (UL) CAT 5E PLTC OR CMR-CMX OUTDOOR OR C(UL) CMR --ISO/IEC 11801 CAT 5E SUN RES OIL RES --- US PATENT 6273977 CE ROHS (2 FT, 7 DIGIT SEQUENTIAL NUMBER) FT [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] * = Factory Code Applicable Specifications 0.301 (0.316 Max.) 1) UL CMR 75°C PLTC 75°C CMX 75°C OIL RES I 2) CSA International C(UL) TYPE CMR 75°C FT4 3) Other ISO/IEC 11801 Category 5e Horizontal Cable TIA-568-C.2 Cat5e NEMA WC-63.1 Category 5e 4) CE: EU Low Voltage Directive 2014/35/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011and the amending Directive 2015/863/EU of 4 June 2015 . No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: Exempt from warning labels based on the Consent Judgment. Please see Alpha's CA Prop 65 Statement for more information. Properties Physical & Mechanical Properties 1) Temperature Range -25 to 75°C 2) Bend Radius 4X Cable Diameter 3) Pull Tension 40 Lbs, Maximum 4)Sunlight Resistance 5)Cable Weight Yes 30 Lbs/1000Ft Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Characteristic Impedance 100 Ω +/- 15 3) Mutual Capacitance 15 pF/ft @1 kHz, Nominal 4)Velocity of Propagation 70 % 5) Propagation Delay 510 nS/100m, Maximum 6)Delay Skew 25 nS/100m, Maximum 7)Conductor DCR 8)DCR Unbalance 9 Ω/100m @20°C, Maximum 3% @20°C, Maximum Max. Min. Min. Frequenc Attenuatio Min. PSNEXT( ACR(dB) y(MHz) n(dB/100 NEXT(dB) dB) m) 1 2 65.3 65.3 63.3 4 4 56.3 56.3 52.3 8 5.7 51.8 51.8 46.1 10 6.4 50.3 50.3 43.9 16 8.1 47.3 47.3 39.1 20 9.2 45.8 45.8 35.2 25 10.3 44.3 44.3 34.1 31.25 11.6 42.9 42.9 31.3 62.5 16.8 38.4 38.4 21.6 100 21.7 35.3 35.3 17.1 Min. Frequenc Min. PSACR(d y (MHz) RL(dB) B) 1 63.3 Min. Min. PSELFEX ELFEXT(d T(dB) B) 20 63.8 60.8 4 52.3 23 51.7 48.7 8 46.1 24.5 45.7 42.7 10 43.9 25 43.8 40.8 16 39.1 25 39.7 36.7 20 25 35.2 34.1 25 37.7 34.7 24.3 35.8 32.8 31.25 31.3 23.6 33.9 30.9 62.5 21.6 21.5 27.8 24.8 100 17.1 20.1 23.8 20.8 Other Packaging Flange x Traverse x Barrel (inches) a) 500 FT 12 x 10 x 5 Continuous length [Spool dimensions may vary slightly]   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 74009 74009, RoHS-Compliant Commencing With 9/30/2013 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
74009 BK002 价格&库存
很抱歉,暂时无法提供与“74009 BK002”相匹配的价格&库存,您可以联系我们找货
74009 BK002
  • 500+14.88320500+1.86155
  • 1000+14.141211000+1.76874
  • 1500+13.721191500+1.71621
  • 2500+13.264922500+1.65914
库存:500
74009 BK002
  • 1+127.418991+15.93720
  • 2+121.388832+15.18296
  • 3+117.942013+14.75185
  • 5+113.753465+14.22795
  • 7+111.063557+13.89151
库存:8
74009 BK002
  • 1+596.508141+74.60950
  • 2+567.838342+71.02357
  • 3+551.586283+68.99081
库存:4
