74010 BK002
74010 BK002
    ALPHAWIRE(阿尔法电线)
    8(4 对双绞线) 芯 多线对,Cat6 线缆 黑色 23 AWG 500.0'(152.4m)
74010 BK002 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 74010 Construction Diameters (In) 1) Component 1 1 X 4 PAIR a) Conductor 23 (SOLID) AWG Bare Copper 0.022 b) Insulation 0.009" Wall, Nom. Polyolefin 0.038 Pair (1) Color(s) Pair Color Pair Color 1 BLUE WHITE/BLUE 3 GREEN WHITE/GREEN 2 ORANGE 4 WHITE/ORANGE BROWN WHITE/BROWN c) Pair Bonded Pair (1) Twists: Staggered Lays d) Cabling 4 PAIR Cabled (1) Orientation: Parallel e) Jacket 0.018" Wall, Nom.,PVC (1) Color(s) WHITE (2) Ripcord 1 End 810 Denier Nylon 2) Jacket 0.035" Wall, Nom.,PVC Color 0.475X0.265 (0.489X0.289 Max.) a) Color(s) BLACK b) Ripcord 1 End 810 Denier Nylon c) Print ALPHA WIRE-* P/N 74010 4PR 23 AWG 75C (UL) CMR OR C(UL) CMR  --- TIA-568-C.2  & ISO/IEC 11801 CAT 6 SUN RES OIL RES II --- US PATENT 6273977, 5821467 CE     ROHS (2 FT, 7 DIGIT SEQUENTIAL NUMBER) FT [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] * = Factory Code Applicable Specifications 1) UL CMR 75°C 2) CSA International C(UL) TYPE CMR 75°C FT4 3) Other TIA-568-C.2 Cat6 ISO/IEC 11801 Category 6 4) CE: EU Low Voltage Directive 2014/35/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011and the amending Directive 2015/863/EU of 4 June 2015 . No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: Exempt from warning labels based on the Consent Judgment. Please see Alpha's CA Prop 65 Statement for more information. Properties Physical & Mechanical Properties 1) Temperature Range -25 to 75°C 2) Bend Radius 4X Cable Diameter 3) Pull Tension 32 Lbs, Maximum 4)Sunlight Resistance Yes 5)Cable Weight 30 Lbs/1000Ft Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Characteristic Impedance 100 Ω +/- 15 3) Mutual Capacitance 15 pF/ft @1 kHz, Nominal 4)Velocity of Propagation 5) Conductor DCR 70 % 27.4 Ω/1000ft @20°C, Nominal Max. Min. Min. Frequenc Attenuatio Min. PSNEXT( ACR(dB) y(MHz) n(dB/100 NEXT(dB) dB) m) 1 1.9 74.3 72.3 70 4 3.7 65.3 63.3 59 8 5.3 60.3 58.3 53 10 5.9 59.3 57.3 51 16 7.5 56.3 54.3 46 20 8.4 54.8 52.8 44 25 9.5 53.4 51.4 42 31.25 10.6 51.9 49.9 39 62.5 15.4 47.4 45.4 30 100 19.8 44.3 42.3 25 155 25.1 41.5 39.5 14 200 29 39.9 37.9 10 Min. Frequenc Min. PSACR(d y (MHz) RL(dB) B) Min. Min. PSELFEX ELFEXT(d T(dB) B) 1 70 20 67.8 64.8 4 59 23 55.7 52.7 8 53 24.5 49.7 46.7 10 51 25 47.8 44.8 16 46 25 43.7 40.7 20 44 25 41.7 38.7 25 42 24.3 39.8 36.8 31.25 39 23.6 37.9 34.9 62.5 30 21.5 31.8 28.8 100 25 21 27.8 24.8 155 14 21 23.9 20.9 200 10 21 21.7 18.7 Other Packaging Flange x Traverse x Barrel (inches) a) 500 FT 16 x 11 x 8 Continuous length [Spool dimensions may vary slightly]   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 74010 74010, RoHS-Compliant Commencing With 9/30/2013 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
74010 BK002
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,输出端光电晶体管导通。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 3.6mm。
74010 BK002 价格&库存
很抱歉,暂时无法提供与“74010 BK002”相匹配的价格&库存,您可以联系我们找货
74010 BK002
    • 1+698.121781+90.36459
    • 2+664.467322+86.00837
    • 3+645.435633+83.54492
    • 5+622.146035+80.53032
    库存:5
    74010 BK002
    • 1+144.115891+18.65430
    库存:1
