AF15510 NA003
AF15510 NA003
    ALPHAWIRE(阿尔法电线)
    天然 玻璃纤维,涂丙烯酸 带编织层 套管 0.102"(2.59mm) 250'(76.20m)
AF15510 NA003 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. AF-155-10 Construction 1) Tubing Type Acrylic Coated Fiberglass Sleeving 2) Tubing Material Fiberglass Braid coated with Acrylic 3) Minimum ID(In) 0.102 4) Maximum ID(In) 0.112 5) Minimum Wall Thickness(In) 0.008 6) Color(s) NATURAL Applicable Specifications 1) Military MIL-I-3190/3 Grade C1 2) Other NEMA TF-1 Type 6 Environmental 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -40 to 155°C 2) Elongation 150%, Min ASTM D638 3) Low Temperature Flex(-10°C) no cracking AMS-DTL-23053 2500 V, Min Average ASTM D149 Electrical Properties 1) Dielectric Strength 1500 V, Min Individual 2) Volume Resistivity 1x10 10 ohm-cm, Min ASTM D876 3) Dielectric Constant 2.5 IEC 250 1) Corrosion(0°C,16hrs) no corrosion AMS-DTL-23053 2) Fungus Resistance Pass AMS-DTL-23053 3) Halogen Free No 4) Lead Free Yes Chemical Properties Other Packaging   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: AF-155-10 AF-155-10, RoHS-Compliant Commencing With 1/1/2002 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
AF15510 NA003
物料型号为 AF-155-10。
以下是关于该物料的详细信息:
- 器件简介:Alpha Wire 提供的物料,具有 Acrylic Coated Fiberglass Sleeving 构造,由 Fiberglass Braid coated with Acrylic 制成。
- 引脚分配:文档中未提供引脚分配信息。
- 参数特性: - 内径 (ID) 范围:0.102 至 0.112 英寸 - 壁厚:最小 0.008 英寸 - 颜色:NATURAL - 温度范围:-40 至 155°C - 伸长率:最小 150% - 低温柔性 (-10°C):无裂纹 - 介电强度:最小平均值 2500V,最小个体值 1500V - 体积电阻率:最小 1x10^10 ohm-cm - 介电常数:2.5 - 功能详解:文档中未提供功能详解信息。
- 应用信息:适用于 MIL-I-3190/3 Grade C1 和 NEMA TF-1 Type 6 规格。
- 封装信息:文档中未提供封装信息
此外,该物料符合欧盟 RoHS 2 指令和 REACH 法规 (EC1907/2006),不含有超过 0.1% 质量分数的高关注物质 (SVHC)。
还符合加利福尼亚州第 65 号提案要求,外表面材料满足要求。
Alpha Wire 提供了关于该物料的 RoHS 合规证书,确认自 2002 年 1 月 1 日起生产的产品符合 RoHS 指令。
请注意,Alpha Wire 提供的信息和规格是基于发布时的最佳知识、信息和信念,并且可能存在错误或遗漏,且不保证产品可用性。
AF15510 NA003 价格&库存
很抱歉,暂时无法提供与“AF15510 NA003”相匹配的价格&库存,您可以联系我们找货
AF15510 NA003
  • 1+2111.892331+262.38297
