Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 9854C
Construction
Diameters (In)
1) Component 1
3 X 1 PAIR
a) Conductor
28 (7/36) AWG TC
0.015
b) Insulation
0.0085" Wall, Nom.
Polypropylene(PP)
0.033
(1) Color(s)
Pair
Color
Pair
Color
Pair
Color
1
WHITE-GRAY
2
YELLOWORANGE
3
GREEN-BLUE
c) Pair
2/Cond Cabled Together
(1) Twists:
12.0 Twists/foot (min)
Individually Applied:
d) Shield:
Alum/Mylar Tape, 25% Overlap, Min.
(1) Foil Direction
Foil Facing Out
2) Component 2
1 X 1 PAIR
a) Conductor
24 (7/32) AWG TC
0.024
b) Insulation
0.010" Wall, Nom. PVC, Semi Rigid
0.044
Pair
Pair
(1) Color(s)
Pair
Color
1
BLACK-RED
Color
c) Pair
(1) Twists:
9.6 Twists/foot (min)
d) Shield:
(1) Foil Direction
Foil Facing Out
3) Cable Assembly
4 Components Cabled
Color
a) Twists:
4.0 Twists/foot (min)
b) Drain Wire
24 (7/32) AWG TC under core wrap
common to pairs
c) Core Wrap
Clear Mylar Tape, 25% Overlap, Min.
4) Shield:
A/P/A Tape, 25% Overlap, Min.
a) Braid
#36 AWG TC,90% Coverage, Min.
5) Jacket
0.032" Wall, Nom.,PVC
a) Color(s)
SLATE
b) Print
ALPHA WIRE-* P/N 9854C
IEEE 802.3 TRANSCEIVER CABLE 3PR28 1PR24
SHIELDED 75C (UL) CM OR AWM 2919 LOW VOLTAGE
COMPUTER CABLE OR C(UL) CMG FT4
CE ROHS
* = Factory Code
[Note: Product may have c(UL) or CSA markings depending upon plant of
manufacture.]
0.250 (0.265 Max.)
Applicable Specifications
1) UL
2) CSA International
CM
75°C
AWM/STYLE 2919
80°C / 30 VRMS
C(UL) TYPE CMG
75°C
FT4
3) CE:
EU Low Voltage Directive 2006/95/EC
Environmental
1) CE: EU Directive 2011/65/EU(RoHS2):
This product complies with European Directive 2011/65/EU (RoHS Directive)
of the European Parliament and of the Council of 8 June 2011. No
Exemptions are required for RoHS Compliance on this item. Consult Alpha
Wire's web site for RoHS C of C.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC)
listed on the European Union's REACH candidate list in excess of 0.1%
mass of the item. For up-to-date information, please see Alpha's REACH
SVHC Declaration.
3) California Proposition 65:
The outer surface materials used in the manufacture of this part meet the
requirements of California Proposition 65.
Properties
Physical & Mechanical Properties
1) Temperature Range
-20 to 80°C
2) Bend Radius
10X Cable Diameter
3) Pull Tension
18.8 Lbs, Maximum
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
300 VRMS
2) Component 1
a) Characteristic Impedance
78 Ω +/- 5
b) Mutual Capacitance
19.7 pf/ft @1 kHz, Nominal
c) Velocity of Propagation
66 %
d) Conductor DCR
65 Ω/1000ft @20°C, Nominal
e) Attenuation, Max dB/100ft
1.7 @ 1 MHz
3.5 @ 5 MHz
4.8 @ 10 MHz
3) Component 2
a) Conductor DCR
25 Ω/1000ft @20°C, Nominal
4) OA Shield DCR
3.2 Ω/1000ft @20°C, Nominal
Other
Packaging
Flange x Traverse x Barrel (inches)
a) 1000 FT
12 x 12 x 3.5 Continuous length
[Spool dimensions may vary slightly]
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication,
information and specifications described herein are subject to errors or omissions and to changes without notice, and
the listing of such information and specifications does not ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties,
whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential,
indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of
such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection
with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical
information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and
subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges
and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no
portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In
the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019
ALPHA WIRE - all rights reserved.
EU/UK/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: 9854C
9854C, RoHS-Compliant Commencing With 11/1/2004 Production
Note: all colors and put-ups
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the
European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use
of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to
amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3).
This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of
the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part
number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T
11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
Bis(2-ethylhexyl) phthalate (DEHP)
Butyl benzyl phthalate (BBP)
Dibutyl phthalate (DBP)
Diisobutyl phthalate (DIBP)
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief
at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any
other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a
warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Authorized Signatory for the Alpha Wire:
Dave Watson, Director of Engineering
Alpha Wire
2200 US Highway 27 South
Richmond, IN 47374
Tel: 1-908-925-8000
1/9/2024
