Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032
Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com
Customer Specification
PART NO. 75033
Construction
Diameters (In)
1) Component 1
2 X 1 PAIR
a) Conductor
22 (19/34) AWG Tinned Copper
0.0135" Wall, Nom. Polyethylene,
b) Insulation
High Density
0.032
0.059
(1) Color(s)
Pair
Color
Pair
1
WHITE/ORANGE
2
- ORANGE
Color
Pair
Color
WHITE/GREEN GREEN/WHITE
c) Pair
2/Cond Cabled Together
(1) Twists:
16.0 Twists/foot (approx.)
2) Cable Assembly
2 Components Cabled
a) Twists:
2.0 Twists/foot (min)
b) Orientation:
Components to be arranged from
INSIDE LAYER to OUTSIDE LAYER
c) Core Wrap
Foam Polypropylene Tape, 25%
Overlap, Min.
3) Shield:
Alum/Mylar Tape, 25% Overlap, Min.
a) Foil Direction
Foil Facing Out
b) Braid
Tinned Copper,75% Coverage, Min.
4) Jacket
0.040" Wall, Nom.,TPE
a) Color(s)
TEAL
b) Print
ALPHA WIRE-A3 P/N 75033 HIGH FLEX CAT5E SF/UTP 2P
22AWG E163860 C(UL)US CMX-OUTDOOR - CM 75C SUN RES
OR TYPE PLTC OIL RES I/II OR TYPE ITC
OR AWM 2463 80C 600V CE ROHS
(SEQ FOOTAGE)
[Note: Product may have c(UL) or CSA markings depending upon plant of
manufacture.]
0.310+/- 0.017
Applicable Specifications
1) UL
CM
75°C
CMX-Outdoor
75°C
OIL RES I/II
SUN RES
2) Other
AWM/STYLE 2463
80°C / 600 VRMS
PLTC
75°C
ITC
75°C
ISO/IEC 11801 Category 5
ANSI/TIA-568.2-D Category 5e
3) CE:
EU Low Voltage Directive 2014/35/EU
Environmental
1) CE: EU Directive 2011/65/EU(RoHS2), EU Directive 2015/863/EU (RoHS3):
This product complies with European Directive 2011/65/EU (RoHS Directive)
of the European Parliament and of the Council of 8 June 2011 and the
amending Directive 2015/863/EU of 4 June 2015 . No Exemptions are
required for RoHS Compliance on this item.
2) REACH Regulation (EC 1907/2006):
This product does not contain Substances of Very High Concern (SVHC)
listed on the European Union's REACH candidate list in excess of 0.1%
mass of the item.
Properties
Physical & Mechanical Properties
1) Temperature Range
-40 to 80°C
2) Bend Radius
8X Cable Diameter(static), 7X Cable Diameter(dynamic)
3) Pull Tension
27 Lbs, Maximum
4) Sunlight Resistance
Yes
5) Cable Weight
46 Lbs/1000Ft
Electrical Properties
(For Engineering purposes only)
1) Voltage Rating
600 VRMS
2) Characteristic Impedance
100 Ω +/- 15
3) Capacitance Unbalance
330 pf/100m @1 kHz, Maximum
4) Velocity of Propagation
66 %
5) Conductor DCR
9.38 Ω/100m @20°C, Maximum
6) DCR Unbalance
5 % Maximum
7) Skew
45 ns/100m Maximum
Frequency
[MHz]
Max. Insertion
Loss
[dB]
Min. NEXT
[dB]
Min. PSNEXT
[dB]
Min. ACRF
[dB]
Min. PSACRF
[dB]
Min. Return
Loss
[dB]
1
2.4
65.3
62.3
63.8
60.8
20.0
4
4.9
56.3
53.3
51.8
48.8
23.0
8
6.9
51.8
48.8
45.7
42.7
24.5
10
7.8
50.3
47.3
43.8
40.8
25.0
16
9.9
47.2
44.2
39.7
36.7
25.0
45.8
42.8
37.8
34.8
25.0
25
12.5
44.3
41.3
35.8
32.8
24.2
31.25
14.1
42.9
39.9
33.9
30.9
23.3
62.5
20.4
38.4
35.4
27.9
24.9
20.7
100
26.4
35.3
32.3
23.8
20.8
19.0
Other
Packaging
Flange x Traverse x Barrel (inches)
a) 1000 FT
16 x 11 x 8 Continuous length
b) 100 FT
12 x 4.5 x 3.5 Continuous length
[Spool dimensions may vary slightly]
www.alphawire.com
Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication,
information and specifications described herein are subject to errors or omissions and to changes without notice, and
the listing of such information and specifications does not ensure product availability.
Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties,
whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential,
indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of
such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection
with the use, or inability to use, the information or specifications described herein.
ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical
information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and
subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges
and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no
portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In
the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019
ALPHA WIRE - all rights reserved.
EU/UK/China ROHS CERTIFICATE OF COMPLIANCE
To Whom It May Concern:
Alpha Wire Part Number: 75033
75033, RoHS-Compliant Commencing With 1/1/0001 Production
Note: all colors and put-ups
This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the
European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use
of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to
amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3).
This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of
the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part
number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T
11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011.
Substance
Maximum Control Value
Lead
0.1% by weight (1000 ppm)
Mercury
Cadmium
0.01% by weight (100 ppm)
Hexavalent Chromium
0.1% by weight (1000 ppm )
Polybrominated Biphenyls (PBB)
Polybrominated Diphenyl Ethers (PBDE) ,
Including Deca-BDE
Bis(2-ethylhexyl) phthalate (DEHP)
Butyl benzyl phthalate (BBP)
Dibutyl phthalate (DBP)
Diisobutyl phthalate (DIBP)
The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief
at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any
other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a
warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for
determining the applicability of legislation and regulations based on their individual usage of the product.
Authorized Signatory for the Alpha Wire:
Dave Watson, Director of Engineering
Alpha Wire
2200 US Highway 27 South
Richmond, IN 47374
Tel: 1-908-925-8000
1/9/2024
