390462 WH005
390462 WH005
    ALPHAWIRE(阿尔法电线)
    4 AWG 电子线 电线 133/25 白色 25kV 100.0'(30.5m)
390462 WH005 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 390462 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 4 (133(7x19)/25) AWG Tinned Copper 0.269 b) Insulation 0.062" Wall, Nom. Silicone Rubber 0.393+/- 0.006 (1) Print (D) 390462 25KVDC 0.062 WALL 4 AWG (2) Color(s) WHITE, BLACK, RED Applicable Specifications Environmental 1) EU Directive 2011/65/EU(RoHS2), EU Directive 2015/863/EU (RoHS3): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU and the amending Directive 2015/863/EU of 4 June 2015 regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. Properties Physical & Mechanical Properties 1) Temperature Range -40 to 150°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 334 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 25000 VDC 2) Inductance 0.04 μH/ft, Nominal 3) Conductor DCR 0.27 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 18 x 14.25 x 8 Max. 2 separate pieces; Min length/piece 250 FT. b) 500 FT 13.5 x 10 x 4 Continuous length c) 100 FT 12 x 5.94 x 5 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] Notes: a) Certain colors and put-up combinations may only be available by special order, minimums may apply.   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 390462 390462, RoHS-Compliant Commencing With 7/1/2005 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
390462 WH005
- 物料型号: 390462 - 构造: - 导体: 4根133(7x19)/25 AWG镀锡铜,直径0.269英寸 - 绝缘: 0.062英寸壁厚,标称硅橡胶,外径0.393英寸 - 打印: 390462 25KVDC 0.062 WALL 4 AWG - 颜色: 白色、黑色、红色 - 适用规范: - 符合欧盟RoHS 2和RoHS 3指令,限制电子电气设备中某些有害物质的使用 - 不含REACH法规候选清单上超过0.1%质量分数的高关注物质(SVHC) - 物理和机械特性: - 温度范围: -40至150°C - 弯曲半径: 10倍电缆直径 - 最大拉力: 334磅 - 电气特性(仅限工程用途): - 电压等级: 25000VpC - 电感: 0.04 H/英尺,标称 - 导体直流电阻(DCR): 0.27 Q/1000英尺 @20°C,标称 - 包装信息: - 1000英尺: 最大尺寸18 x 14.25 x 8英寸,最多2段,每段最短250英尺 - 500英尺: 连续长度,尺寸13.5 x 10 x 4英寸 - 100英尺: 连续长度,尺寸12 x 5.94 x 5英寸 - 散装(定制): 卷轴尺寸可能略有变化
390462 WH005 价格&库存
很抱歉,暂时无法提供与“390462 WH005”相匹配的价格&库存,您可以联系我们找货
