461019 WH001
461019 WH001
    ALPHAWIRE(阿尔法电线)
    10 AWG 电子线 电线 19/0.0234" 白色 600V 1000.0'(304.8m)
461019 WH001 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 461019 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 10 (19/.0234) AWG Bare Copper 0.117 b) Insulation 0.032" Wall, Nom. PVC 0.181+/- 0.004 (1) Print ALPHA WIRE-* 10 AWG E163872-* (UL) MTW OR TW OR AWM 1015/1230 105C 600V VW-1 OR C(RU) AWM I A/B 105C 600V FT1 OR TEW 105C 600V FT1 CE ROHS * = Factory Code (2) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET Applicable Specifications 1) UL AWM/STYLE 1015 105°C / 600 VRMS AWM/STYLE 1230 105°C Dry / 60°C Wet / 600 VRMS MTW 90°C Dry / 60°C Wet / 600 VRMS VW-1 2) CSA International TW 60°C Dry / 60°C Wet / 600 VRMS AWM I A/B 80°C / 300 VRMS FT1 TEW-105 Environmental 105°C / 600 VRMS 1) EU Directive 2011/65/EU(RoHS2), EU Directive 2015/863/EU (RoHS3): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU and the amending Directive 2015/863/EU of 4 June 2015 regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. Properties Physical & Mechanical Properties 1) Temperature Range -40 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 82 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.04 μH/ft, Nominal 3) Conductor DCR 1.02 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 5000 FT 18 x 14.25 x 8 Continuous length b) 1000 FT 12 x 5.94 x 5 Continuous length c) 500 FT 10.5 x 5 x 3.5 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] Notes: a) Certain colors and put-up combinations may only be available by special order, minimums may apply.   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 461019 461019, RoHS-Compliant Commencing With 7/1/2005 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
461019 WH001
物料型号:461019
器件简介:Alpha Wire生产的1X1 HOOKUP线缆,由10根19/.0234 AWG裸铜导体组成,绝缘层为0.032英寸壁厚的PVC,标称外径为0.181英寸。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 颜色选项:白色、黑色、红色、绿色、黄色、蓝色、棕色、橙色、石板色、紫色。 - 温度范围:-40至105摄氏度。 - 弯曲半径:10倍电缆直径。 - 拉力:最大82磅。 - 电压等级:600 VRMS。 - 电感:0.04 H/英尺(标称)。 - 导体直流电阻:1.02欧姆/1000英尺@20摄氏度(标称)。
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未提供具体的应用信息
封装信息: - 包装方式:法兰x横向x桶装(英寸)。 - 5000英尺:18x 14.25x8连续长度。 - 1000英尺:12x5.94x5连续长度。 - 500英尺:10.5x5x3.5连续长度。 - 散装(按订单生产):卷轴尺寸可能略有变化。
环境合规性: - 符合欧盟指令2011/65/EU(RoHS2)和2015/863/EU(RoHS3)关于限制在电子电气设备中使用某些有害物质的指令。 - 不含REACH法规(EC1907/2006)中列出的高关注物质(SVHC),超过物品质量的0.1%。
461019 WH001 价格&库存
很抱歉,暂时无法提供与“461019 WH001”相匹配的价格&库存,您可以联系我们找货
461019 WH001
  • 1000+10.134851000+1.31367
