5858 YL005
5858 YL005
    ALPHAWIRE(阿尔法电线)
    16 AWG 电子线 电线 19/29 黄色 600V 100.0'(30.5m)
5858 YL005 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 5858 Construction Diameters (In) 1) Component 1 1 X 1 HOOKUP a) Conductor 16 (19/29) AWG Silver Plated Copper 0.057 b) Insulation 0.012" Wall, Nom. PTFE 0.080+/- 0.007 (1) Color(s) WHITE, BLACK, RED, GREEN, YELLOW, BLUE, BROWN ORANGE, SLATE, VIOLET, GREEN/YELLOW Applicable Specifications 1) UL AWM/STYLE 1213 105°C VW-1 2) Military MIL-W-16878/4 (Type E) 3) Other NEMA HP3-EXBJE 200°C / 600 VRMS Environmental 1) EU Directive 2011/65/EU(RoHS2), EU Directive 2015/863/EU (RoHS3): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU and the amending Directive 2015/863/EU of 4 June 2015 regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. 3) California Proposition 65: This product may contain substances known to the State of California to cause Cancer or Reproductive Harm, but is exempt from labeling based on the Consent Judgement. See the Alpha Wire website for more information. Properties Physical & Mechanical Properties 1) Temperature Range -60 to 200°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 19.1 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Inductance 0.04 μH/ft, Nominal 3) Conductor DCR 4.4 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 6.5 x 6 x 1.9 Max. 3 separate pieces; Min length/piece 100 FT. b) 500 FT 6.5 x 2 x 1.9 Max. 2 separate pieces; Min length/piece 100 FT. c) 100 FT 3.5 x 3 x 1.125 Continuous length [Spool dimensions may vary slightly] Notes: a) 500 ft put-ups and Green/Yellow by special order only, minimus may apply   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 5858 5858, RoHS-Compliant Commencing With 3/1/2005 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
5858 YL005
物料型号:5858
器件简介:Alpha Wire公司生产的线缆,具有多种颜色选择,包括白色、黑色、红色等。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 导体:16 AWG银镀铜,直径0.057英寸。 - 绝缘:0.012英寸壁厚,名义PTFE,总直径0.080英寸±0.007英寸。 - 温度范围:-60至200°C。 - 弯曲半径:10倍电缆直径。 - 拉力:最大19.1磅。
功能详解:文档中未提供详细的功能解释,但根据参数特性,该线缆适用于需要耐高温和良好电气性能的应用。
应用信息:适用于多种环境和应用,包括UL AWM/STYLE 1213、MIL-W-16878/4(Type E)和NEMA HP3-EXBJE等标准。
封装信息:提供不同长度的卷装选项,包括1000英尺、500英尺和100英尺,具体包装尺寸可能略有变化。
5858 YL005 价格&库存
很抱歉,暂时无法提供与“5858 YL005”相匹配的价格&库存,您可以联系我们找货
5858 YL005
  • 1+4721.954351+612.05519
