3550 MC005
3550 MC005
    ALPHAWIRE(阿尔法电线)
    扁平带状电缆 多重 10 导线 0.039"(1.00mm) 扁平缆线 100.0'(30.48m)
3550 MC005 数据手册
Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. 3550 Construction Diameters (In) 1) Component 1 10 X 1 COND a) Conductor 26 (7/34) AWG TC 0.019 b) Insulation 0.010" Wall, Nom. PVC 0.039 (1) Color(s) Cond Color Cond Color Cond Color 1 BROWN 5 GREEN 9 WHITE 2 RED 6 BLUE 10 BLACK 3 ORANGE 7 VILOET 4 YELLOW 8 SLATE 2) Cable Assembly 10 Components assembled parallel. 0.039 +/- 0.002 x 0.390 +/- 0.020 Applicable Specifications 1) UL AWM/STYLE 2713 80°C / 150 VRMS VW-1 2) Military a) Component 1 MIL-DTL-16878/1 (Type B) 105°C / 600 VRMS Environmental 1) EU Directive 2011/65/EU(RoHS2): All materials used in the manufacture of this part are in compliance with European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -55 to 105°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 21.8 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 600 VRMS 2) Capacitance 28 pf/ft @1 kHz, Nominal Conductor to Conductor 3) Inductance 0.2 µH/ft, Nominal 4) Conductor DCR 41 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 100 FT 11 x 0.5 x 3 Continuous length [Spool dimensions may vary slightly]   www.alphawire.com Alpha Wire | 1320 City Center Drive, Suite 100, Carmel, IN 46032 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure there accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARYNotice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time. By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE. In the case of conflicting contractual provisions, this notice shall govern the status of this document. ©2019 ALPHA WIRE - all rights reserved. EU/UK/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: 3550 3550, RoHS-Compliant Commencing With 3/1/2005 Production  Note:  all colors and put-ups This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive (commonly known as RoHS 2), with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. This certification extends to amending Directive 2015/863/EU which expanded the list of restricted substances to 10 items (commonly known as RoHS 3). This product also complies with UK - RoHS. The reader is referred to these Directives for the specific definitions and extents of the Directives. No Exemptions are required for RoHS Compliance on this item. Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 11364-2014. This product is also in compliance with China RoHS 2 per GB/T 26572-2011. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) Bis(2-ethylhexyl) phthalate (DEHP) 0.1% by weight (1000 ppm)  Butyl benzyl phthalate (BBP) 0.1% by weight (1000 ppm) Dibutyl phthalate (DBP)  0.1% by weight (1000 ppm)  Diisobutyl phthalate (DIBP) 0.1% by weight (1000 ppm)  The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire: Dave Watson, Director of Engineering  Alpha Wire  2200 US Highway 27 South  Richmond, IN 47374 Tel: 1-908-925-8000 1/9/2024
3550 MC005
物料型号为3550,由Alpha Wire生产。
器件简介包括10根并行组件构成的电缆组件,导体规格为26 AWG,绝缘层为0.010英寸PVC,标称外径为0.039英寸。
引脚分配为10根并行线。
参数特性包括温度范围-55至105°C,弯曲半径为10倍电缆直径,最大拉力为21.8磅。
功能详解涉及电气特性,如600 VRMS的电压额定值、28 pf/ft的电容、0.2 H/ft的电感以及41 Q/1000ft的导体直流电阻。
应用信息包括UL AWM/STYLE 2713、MIL-DTL-16878/1 Type B等规格。
封装信息为Flange x Traverse x Barrel,例如100FT的尺寸为11x0.5x3英寸。
此外,该产品符合RoHS、REACH和加州65号提案的环保要求。
3550 MC005 价格&库存
很抱歉,暂时无法提供与“3550 MC005”相匹配的价格&库存,您可以联系我们找货
3550 MC005
  • 1+10953.266601+1423.88922
  • 2+10408.357302+1353.05277
  • 3+10099.832393+1312.94553
  • 5+9721.431665+1263.75466
  • 7+9478.361127+1232.15628
  • 10+9225.8622210+1199.33224
库存:4
