902-5M NC032
902-5M NC032
    ALPHAWIRE(阿尔法电线)
    M12 DIE CAST 8PORT 2SIG LED
902-5M NC032 数据手册
Customer Specification  PART NO: 902 Series  M12‐A Die Cast Passive I/O Box Issue: 1 Issue Date: 8/20/2016 Effective Date: 8/20/2016   Dimensions  Technical Data Box Configuration  Ports  Channels per Port  LED  Code Type  Housing  Contact  Receptacle Shell  O‐Ring  Electrical  Contact Resistance  Voltage Rating  Current Rating  Insulation Resistance  UL File  Cable Construction  Conductor Size  Outer Jacket Material    8  2  Yes  A  Die Cast Zinc  Copper Alloy, Gold Plated  Copper Alloy, Nickel Plated  FKM    ≤5mΩ  30V DC  4A per port/8A max. Total @ 40°C  >109Ω  E485582    3 x 1.0mm2 & 16 x 0.50mm2  Zero Halogen PUR  ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification  PART NO: 902 Series  M12‐A Die Cast Passive I/O Box Outer Diameter  Color  Suitable for C‐Track  Environmental  Degree of Protection  Operating Temperature  Range  RoHS  REACH Regulation (EC  1907/2006)  Accessories Included  2 Dust Covers for unused  sockets  10 attachable labels  Ordering Information  902‐5M NC032  902‐10M NC032  902‐CN NC032  .453”  Black  Yes    IP 65/ IP 67  ‐40C (‐40F)/ +80C (+176F) (C‐Track and UL  Max. 60C (+140F)  All materials used in the manufacture of  this part meet the requirements of  European Directive 2011/65/EU regarding  the restriction of use of certain hazardous  substances in electrical and electronic  equipment. Exemption used; 6a.  This product does not contain Substances  of Very High Concern (SVHC) listed on the  European Union’s REACH candidate list in  excess of 0.1% mass of the item.        Description  5 Meters  10 Meters  Connectorized  Quantity  Each  Each  Each  ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2 Customer Specification  Issue: 1 Issue Date: 8/20/2016 Effective Date: 8/20/2016  PART NO: 902 Series  M12‐A Die Cast Passive I/O Box          Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time  of this publication, information and specifications described herein are subject to error or omission  and to change without notice, and the listing of such information and specifications does not  ensure product availability. Alpha provides the information and specification herein on an “AS IS”  basis, with no representations or warranties, whether express, statutory or implied. In no event  will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or  exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such  damages, whether in an action under contact, negligence or any other theory, arising out of or in  connection with the use, or inability to use, the information or specification described herein.    ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 3
902-5M NC032 价格&库存
很抱歉,暂时无法提供与“902-5M NC032”相匹配的价格&库存,您可以联系我们找货
