215HR NC032
215HR NC032
    ALPHAWIRE(阿尔法电线)
    4 针位圆形连接器 插头,公引脚 螺钉
215HR NC032 数据手册
Customer Specification PART NO: 215 Series M8 Male 4 Pin Field Attachable Issue: 1 Issue Date: 4/18/2016 Effective Date: 5/18/2016 Drawing Technical Data Part Number 215HR Mechanical Housing Insert Shell Contact O-Ring Connection Conductor AWG Range Electrical Contact Resistance Nom. Current @ 40°C Cable Diameter Range 0.138" – 0.197" (3.5 – 5.0 mm) Polyamide Polyurethane Copper Alloy, Nickel Plated Copper Alloy, Gold Plated FKM Screw Terminal 26 (0.14 mm2) to 20 (0.75mm2) ≤ 5 mΩ 4A ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 1 Customer Specification PART NO: 215 Series M8 Male 4 Pin Field Attachable Nominal Voltage Rated Voltage Test Voltage Insulation Resistance Environmental Degree of Protection Operating Temperature Range CE Issue: 1 issue Date: 8/4/2016 Effective Date: 8/4/2016 REACH Regulation (EC 1907/2006) Ordering Information 215HR NC032 30 V 36 V 0.8 kV eff./60 s > 109 Ω IP 67/NEMA 6P -40C (-40F)/ +85C (+185F) All materials used in the manufacture of this part meet the requirements of European Directive 2011/65/EU regarding the restriction of use of certain hazardous substances in electrical and electronic equipment. Exemption used; 6a. This product does not contain Substances of Very High Concern (SVHC) listed on the European Union’s REACH candidate list in excess of 0.1% mass of the item. Each Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described herein are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specification herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contact, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specification described herein. ••••••••••••••••••••••••••••••••••••••• Alpha Wire | 711 Lidgerwood Ave, Elizabeth, NJ 07207 www.alphawire.com | 1-800-52 ALPHA 2
215HR NC032 价格&库存
很抱歉,暂时无法提供与“215HR NC032”相匹配的价格&库存,您可以联系我们找货
