PMS16 BK080
PMS16 BK080
    ALPHAWIRE(阿尔法电线)
    线缆密封套 聚酰胺(PA),尼龙 M16x1.5 黑色
PMS16 BK080 数据手册
ALPHA WIRE COMPANY CUSTOMER PRODUCT SPECIFICATION Part Numbers: PMS12-PMS25 Spec Number: PMS METRIC Page 1 of 1 Pages Issue: Issue Date: Effective Date: 2 02/27/2018 02/27/2018 A. Technical Details 1) Material a) Body PA 6 (Polyamide 6) b) Cap PA 6 (Polyamide 6) c) Seal CR (Chloroprene Rubber) 2) Color a) Gray, RAL 7001 b) Black, RAL 9005 3) Protection Class a) IP 68 5 Bar, 30 min b) IP 66 4) Flammability a) V2 (According to UL94) 5) Temperature Rating a) Permanent -20°C to +100°C b) Intermittent -30°C to +150°C 6) Thread Type a) Metric according to EN 60423 7) Approvals a) UL UL 514 b) CSA CSA C22.2 Size M-12x1.5 Clamping Range Ø min-max mm 3,0-6,5 Thread Length TL mm 8 Thread Ø TD mm 12,0 M-16x1.5 5,0-10,0 10 16,0 22 M-20x1.5 10,0-14,0 10 20,0 M-25x1.5 13,0-18,0 10 25,0 B. Packaging Requirements 1) Standard Package Spanner Width SW CAP SW BODY mm mm 15 15 Outer Ø D mm 17,1 Height H mm 57,0 Part Number 22 25,2 81,5 PMS16 27 27 31,0 106,0 PMS20 33 33 38,0 117,5 PMS25 10 glands per package Although Alpha Wire ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com PMS12
PMS16 BK080 价格&库存
很抱歉,暂时无法提供与“PMS16 BK080”相匹配的价格&库存,您可以联系我们找货
PMS16 BK080
  • 10+26.24183
库存:180
