PPC13 BK080
PPC13 BK080
    ALPHAWIRE(阿尔法电线)
    线缆密封套 聚酰胺(PA),尼龙 PG13.5 黑色
PPC13 BK080 数据手册
ALPHA WIRE COMPANY CUSTOMER PRODUCT SPECIFICATION Part Numbers: PPC7-PPC29 Spec Number: PPC Page 1 of 1 Pages Issue: Issue Date: Effective Date: A. Technical Details 1) Material a) Body b) Cap c) Seal 2) Color a) Gray, RAL 7001 b) Black, RAL 9005 3) Protection Class a) IP 68 b) IP 66 4) Flammability a) V2 5) Temperature Rating a) Permanent b) Intermittent 6) Thread Type a) PG according to DIN 40430 7) Approvals a) UL b) CSA Size PG 7 PG 9 PG 11 PG 13.5 PG16 PG 21 PG 29 Clamping Range Ø min-max mm inch 3,0-6,5 0.118-0.256 4,0-8,0 0.157-0.315 5,0-10,0 0.197-0.394 6,0-12,0 0.236-0.472 10,0-14,0 0.394-0.551 13,0-18,0 0.512-0.709 18,0-25,0 0.709-0.984 Thread Length TL mm inch 8 0.315 8 0.315 8 0.315 10 0.394 10 0.394 11 0.433 11 0.433 B. Packaging Requirements 1) Standard Package Thread Ø TD mm inch 12,5 0.492 15,2 0.598 18,6 0.732 20,4 0.803 22,5 0.886 28,3 1.114 37,0 1.457 2 02/27/2018 02/27/2018 PA 6 (Polyamide 6) PA 6 (Polyamide 6) CR (Chloroprene Rubber) 5 Bar, 30 min (According to UL94) -20°C to +100°C -30°C to +150°C UL 514 CSA C22.2 Spanner Width SW CAP SW BODY mm Inch mm Inch 15 0.591 15 0.591 19 0.748 19 0.748 22 0.866 22 0.866 24 0.945 24 0.945 27 1.063 27 1.063 33 1.299 33 1.299 42 1.654 42 1.654 Outer Ø D mm inch 16,9 0.665 21,9 0.862 25,0 0.984 27,0 1.063 30,9 1.216 38,0 1.496 47,3 1.862 Height H mm inch 22,0 0.866 26,5 1.043 29,0 1.142 29,0 1.142 31,0 1.22 37,0 1.457 41,0 1.614 10 glands per package Although Alpha Wire ("Alpha") makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an "AS IS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. 711 Lidgerwood Ave Elizabeth, NJ 07207-0711 Toll Free 1-800-52 ALPHA • T: 1-908-925-8000 • F: 908-925-5411 • Email: info@alphawire.com www.alphawire.com Part Number PPC7 PPC9 PPC11 PPC13 PPC16 PPC21 PPC29
PPC13 BK080 价格&库存
很抱歉,暂时无法提供与“PPC13 BK080”相匹配的价格&库存,您可以联系我们找货
PPC13 BK080
  • 10+18.27316
库存:110
