10982-20-1-2000-007-1-TD
    CNC
    20AWG 电子线 电线 实心 绿色 300V 2000.0'(609.6m)
10982-20-1-2000-007-1-TD 数据手册
P/N 10982-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: MPPE) UL10982 MPPE Wire 80°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813 mm strands. Overall Diameter=1.50+/-0.10mm Insulation Thickness: 0.38mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 10982 ( ) AWG 80°C 30V E108485-S REI HSING VW-1 ROHS REACH Passes UL VW-1 & CSA FT1 Vertical Flame Test. Rated Temperature: 80℃ ~ -10℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: MPPE Insulation Maximum Conductor Resistance: 36ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: MPPE Wire, Halogen Free and pass VW-1 flame test, insulation lighter, properties better, no irradiation. Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10982-20-1-2000-001-1-TD BLACK 10982-20-1-2000-002-1-TD WHITE 10982-20-1-2000-006-1-TD 10982-20-1-2000-007-1-TD BROWN GREEN 10982-20-1-2000-003-1-TD YELLOW 10982-20-1-2000-008-1-TD ORANGE 10982-20-1-2000-004-1-TD 10982-20-1-2000-005-1-TD RED BLUE 10982-20-1-2000-010-1-TD 10982-20-1-2000-011-1-TD VIOLET GREEN + YELLOW
10982-20-1-2000-007-1-TD 价格&库存
很抱歉,暂时无法提供与“10982-20-1-2000-007-1-TD”相匹配的价格&库存,您可以联系我们找货
  • 1+94.618421+12.25694
  • 1+49.777341+6.44820
  • 2+47.245842+6.12026
  • 4+45.156694+5.84963
  • 10+42.1561910+5.46095
  • 20+40.3020620+5.22076
  • 40+38.2187740+4.95089
  • 100+35.90236100+4.65082
  • 200+34.04888200+4.41072
  • 400+32.42758400+4.20069
库存:13
  • 1+18.883041+2.44613
  • 1+162.037511+20.99046
  • 2+154.288442+19.98664
  • 3+149.953793+19.42512
  • 5+144.595185+18.73097
  • 7+141.173357+18.28770
  • 10+137.6231610+17.82780
库存:26
