10982-18-1-2000-001-1-TD
    CNC
    18AWG 电子线 电线 实心 黑色 300V 2000.0'(609.6m)
10982-18-1-2000-001-1-TD 数据手册
P/N 10982-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: MPPE) UL10982 MPPE Wire 80°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813 mm strands. Overall Diameter=1.50+/-0.10mm Insulation Thickness: 0.38mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 10982 ( ) AWG 80°C 30V E108485-S REI HSING VW-1 ROHS REACH Passes UL VW-1 & CSA FT1 Vertical Flame Test. Rated Temperature: 80℃ ~ -10℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: MPPE Insulation Maximum Conductor Resistance: 36ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: MPPE Wire, Halogen Free and pass VW-1 flame test, insulation lighter, properties better, no irradiation. Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10982-20-1-2000-001-1-TD BLACK 10982-20-1-2000-002-1-TD WHITE 10982-20-1-2000-006-1-TD 10982-20-1-2000-007-1-TD BROWN GREEN 10982-20-1-2000-003-1-TD YELLOW 10982-20-1-2000-008-1-TD ORANGE 10982-20-1-2000-004-1-TD 10982-20-1-2000-005-1-TD RED BLUE 10982-20-1-2000-010-1-TD 10982-20-1-2000-011-1-TD VIOLET GREEN + YELLOW
10982-18-1-2000-001-1-TD 价格&库存
很抱歉,暂时无法提供与“10982-18-1-2000-001-1-TD”相匹配的价格&库存,您可以联系我们找货
  • 1+113.437521+14.67574
  • 2+108.008642+13.97339
  • 3+104.993783+13.58335
库存:3
  • 1+15.336181+1.98409
  • 2+14.514982+1.87785
  • 5+13.644725+1.76526
  • 10+12.9472410+1.67502
  • 20+12.3708020+1.60045
  • 50+11.5462950+1.49378
  • 100+11.03907100+1.42816
  • 200+10.46839200+1.35433
  • 500+9.83399500+1.27226
库存:7
