10982-18-1-2000-002-1-TD
    CNC
    18AWG 电子线 电线 实心 白色 300V 2000.0'(609.6m)
10982-18-1-2000-002-1-TD 数据手册
P/N 10982-20-1-2000-0XX-1-TD (Conductor: Tinned Solid) (Insulation: MPPE) UL10982 MPPE Wire 80°C 300V (20AWG) CONSTRUCTION: Tinned Solid copper conductor, 1/0.813 mm strands. Overall Diameter=1.50+/-0.10mm Insulation Thickness: 0.38mm CERTIFICATION & APPROVALS: DUAL-RATED AWM: Can be used in USA and Canada UL Subject 758 UL FILE NO:E108485 CSA Standard CSA FILE NO:LL84687 Printed Markings: AWG 10982 ( ) AWG 80°C 30V E108485-S REI HSING VW-1 ROHS REACH Passes UL VW-1 & CSA FT1 Vertical Flame Test. Rated Temperature: 80℃ ~ -10℃ PHYSICAL & ELECTRICAL PROPERTIES: Rated Voltage: 300V Insulation Potential Strength: 2000 VAC/min. Flexibility: MPPE Insulation Maximum Conductor Resistance: 36ohm/km Resistant to: Oil, hot & cold, lighter, flexing. APPLICATIONS: MPPE Wire, Halogen Free and pass VW-1 flame test, insulation lighter, properties better, no irradiation. Suitable for internal wires of electronic & electrical equipment. PACKAGING: ENVIRONMENTAL APPROVALS: 2000ft per reel. Conforms to all current RoHS directives as laid out in EU Directive 2011/65/EC. Current SGS reports for this wire are available upon request. P/N's & COLORS 10982-20-1-2000-001-1-TD BLACK 10982-20-1-2000-002-1-TD WHITE 10982-20-1-2000-006-1-TD 10982-20-1-2000-007-1-TD BROWN GREEN 10982-20-1-2000-003-1-TD YELLOW 10982-20-1-2000-008-1-TD ORANGE 10982-20-1-2000-004-1-TD 10982-20-1-2000-005-1-TD RED BLUE 10982-20-1-2000-010-1-TD 10982-20-1-2000-011-1-TD VIOLET GREEN + YELLOW
10982-18-1-2000-002-1-TD 价格&库存
很抱歉,暂时无法提供与“10982-18-1-2000-002-1-TD”相匹配的价格&库存,您可以联系我们找货
  • 1+13.257361+1.71351
  • 2+12.627582+1.63211
  • 3+12.261113+1.58474
  • 5+11.844105+1.53084
  • 7+11.561697+1.49434
  • 10+11.2805010+1.45800
库存:23
  • 2000+1.834602000+0.23712
  • 4000+1.743954000+0.22541
  • 6000+1.692646000+0.21878
  • 10000+1.6297410000+0.21065
  • 14000+1.5893314000+0.20542
  • 20000+1.5473520000+0.20000
库存:2000
  • 1+129.606141+16.75149
  • 2+123.842072+16.00649
  • 5+115.586655+14.93949
  • 10+110.5089310+14.28319
  • 20+104.7961020+13.54482
  • 50+98.4451650+12.72396
  • 100+93.36350100+12.06716
  • 200+88.91753200+11.49252
  • 500+83.20161500+10.75375
库存:6
  • 1+25.340551+3.27525
  • 2+24.113022+3.11659
  • 3+23.433433+3.02876
  • 5+22.616505+2.92317
  • 7+22.097127+2.85604
  • 10+21.5437410+2.78452
库存:10
